All:
I am trying to replace foreman's built in CA with our in house CA which
includes an Intermediate certificate and am having no luck.
What works::
- invoking https://foreman.awt.local as a local user or as a user on
another system works - I can load the foreman web client.
- Invoking https://forman.awt.local:8443/features as a local user or as
a user on another system works - I get a list of features
What doesn't work is trying to create a smart-proxy from within the web
app. Doing so results in an error and the production.log message:
Failed to save: Unable to communicate with the proxy: ERF12-2530
[ProxyAPI::ProxyException]: Unable to detect features
([RestClient::SSLCertificateNo
tVerified]: SSL_connect returned=1 errno=0 state=error: certificate verify
failed) for proxy https://dev-foreman.awt.local:8443/features, Please check
the proxy is configured and running o
n the host.
Here is my foreman settings.yml
### File managed with puppet ###
## Module: 'foreman'
:unattended: true
:login: true
:require_ssl: true
:locations_enabled: false
:organizations_enabled: false
:puppetrun: false
:puppetssldir: /etc/puppetlabs/puppet/ssl
# The following values are used for providing default settings during db
migrate
:oauth_active: true
:oauth_map_users: false
:oauth_consumer_key: kSAzFYd2My8ec9abyK7VadTcscD2hxAe
:oauth_consumer_secret: oBXX7DsRKbtAi8t5CtBrDuVeQBXDJ4EB
# Websockets
:websockets_encrypt: on
:websockets_ssl_key: /usr/local/share/ca-certificates/foreman/foreman_key.
pem
:websockets_ssl_cert: /usr/local/share/ca-certificates/foreman/foreman_cert.
pem
# SSL-settings
:ssl_certificate: /usr/local/share/ca-certificates/foreman/foreman_cert.pem
:ssl_ca_file: /usr/local/share/ca-certificates/foreman/foreman_ssl_ca.pem
:ssl_priv_key: /usr/local/share/ca-certificates/foreman/foreman_key.pem
# Log settings for the current environment can be adjusted by adding them
# here. For example, if you want to increase the log level.
:logging:
:level: debug
# Individual logging types can be toggled on/off here
:loggers:
:dynflow:
:pool_size: 5
and my foreman-proxy settings:
## Module: 'foreman_proxy'
:settings_directory: /etc/foreman-proxy/settings.d
# SSL Setup
# if enabled, all communication would be verified via SSL
# NOTE that both certificates need to be signed by the same CA in order for
this to work
# see SSL - Smart Proxy - Foreman for more
information
:ssl_private_key: /usr/local/share/ca-certificates/foreman/foreman_key.pem
# Use this option only if you need to disable certain cipher suites.
# Note: we use the OpenSSL suite name, take a look at:
https://www.openssl.org/docs/manmaster/apps/ciphers.html#CIPHER-SUITE-NAMES
# for more information.
#:ssl_disabled_ciphers: [CIPHER-SUITE-1, CIPHER-SUITE-2]
# the hosts which the proxy accepts connections from
# commenting the following lines would mean every verified SSL connection
allowed
:trusted_hosts:
- dev-foreman.awt.local
# Endpoint for reverse communication
:foreman_url: https://dev-foreman.awt.local
# SSL settings for client authentication against Foreman. If undefined, the
values
# from general SSL options are used instead. Mainly useful when Foreman uses
# different certificates for its web UI and for smart-proxy requests.
:foreman_ssl_ca: /usr/local/share/ca-certificates/foreman/foreman_ssl_ca.pem
:foreman_ssl_cert: /usr/local/share/ca-certificates/foreman/foreman_cert.pm
:foreman_ssl_key: /usr/local/share/ca-certificates/foreman/foreman_key.pem
# by default smart_proxy runs in the foreground. To enable running as a
daemon, uncomment 'daemon' setting
:daemon: true
# Only used when 'daemon' is set to true.
# Uncomment and modify if you want to change the default pid file
'/var/run/foreman-proxy/foreman-proxy.pid'
#:daemon_pid: /var/run/foreman-proxy/foreman-proxy.pid
# host and ports configuration
# Host or IP to bind ports to (e.g. *, localhost, 0.0.0.0, ::, 192.168.1.20)
:bind_host: '*'
# http is disabled by default. To enable, uncomment 'http_port' setting
# https is enabled if certificate, CA certificate, and private key are
present in locations specifed by
# ssl_certificate, ssl_ca_file, and ssl_private_key correspondingly
# default values for https_port is 8443
:https_port: 8443
#:http_port: 8000
# Log configuration
# Uncomment and modify if you want to change the location of the log file
or use STDOUT or SYSLOG values
:log_file: /var/log/foreman-proxy/proxy.log
# Uncomment and modify if you want to change the log level
# WARN, DEBUG, ERROR, FATAL, INFO, UNKNOWN
:log_level: DEBUG
# Log buffer size and extra buffer size (for errors). Defaults to 3000
messages in total,
# which is about 500 kB request.
:log_buffer: 2000
:log_buffer_errors: 1000
Here's my foreman cert (openssl x509 -noout -text -in foreman_cert.pem
Certificate:
Data:
Version: 3 (0x2)
Serial Number:
37:8e:aa:65:d0:69:79:53:31:d8:dd:47:2a:66:19:0e:f9:f0:ad:f9
Signature Algorithm: sha256WithRSAEncryption
Issuer: CN=AWT Intermediate Certificate Authority
Validity
Not Before: Dec 16 02:32:06 2017 GMT
Not After : Jan 15 02:32:31 2018 GMT
Subject: CN=dev-foreman.awt.local
Subject Public Key Info:
Public Key Algorithm: rsaEncryption
Public-Key: (2048 bit)
Modulus:
00:b6:e9:e9:87:5b:df:6c:b0:1a:c4:0f:9a:91:75:
c8:43:f2:18:69:6b:89:44:56:31:0b:c7:f4:0d:50:
52:0a:19:df:c1:77:30:cd:1b:10:64:5b:fa:74:b6:
2c:a2:38:a3:6e:b8:9c:6b:3b:7d:d3:c8:40:68:9e:
40:0d:64:fa:37:d0:d2:dc:5f:9c:7d:5d:e0:8d:ea:
da:7a:31:fd:a9:ed:9f:ee:99:b0:9e:40:c2:6e:d1:
05:7b:34:ee:4a:d5:9d:dd:5c:ac:be:13:a5:bb:72:
f5:4e:f2:31:e4:08:6b:58:d3:8e:d0:c3:39:64:20:
08:c7:27:0c:74:99:d5:32:b1:bc:4a:f4:84:b2:5d:
1c:bb:5a:54:a5:91:0a:08:6c:c1:8a:6e:43:21:d0:
d6:a6:84:c3:2e:14:0d:a3:a8:68:c8:aa:0c:79:05:
e6:51:73:1b:69:96:79:39:82:e9:20:24:cc:88:0e:
e0:5a:11:6d:08:ed:0b:7a:13:1c:f7:28:68:b6:8f:
e4:50:88:1e:de:d6:5e:5f:f7:53:da:51:03:a3:a5:
50:5c:41:a5:69:ab:53:6c:a8:40:4f:aa:82:4d:91:
32:95:e2:92:73:a5:38:17:f6:1f:93:37:b3:cd:5f:
12:e9:5f:6a:cd:c2:55:2d:45:3c:a1:50:ea:7d:c1:
56:07
Exponent: 65537 (0x10001)
X509v3 extensions:
X509v3 Key Usage: critical
Digital Signature, Key Encipherment, Key Agreement
X509v3 Extended Key Usage:
TLS Web Server Authentication, TLS Web Client Authentication
X509v3 Subject Key Identifier:
CF:7B:F3:97:54:AC:20:38:C7:CB:92:FB:A8:C5:A8:45:D1:59:0B:C9
X509v3 Authority Key Identifier:
keyid:C0:41:49:9D:44:AB:32:36:EB:81:27:E0:18:F6:E6:9E:5B:9E:
74:BF
Authority Information Access:
CA Issuers - URI:http://127.0.0.1:8200/v1/pki_int/ca
X509v3 Subject Alternative Name:
DNS:dev-foreman.awt.local
X509v3 CRL Distribution Points:
Full Name:
URI:http://127.0.0.1:8200/v1/pki_int/crl
43:7a:fb:bb:1c:2c:1a:13:eb:48:93:bd:68:c7:8f:e9:62:18:
42:44:22:c4:cd:56:c6:5c:e6:fc:ac:fd:92:cf:7e:0e:50:03:
07:1b:bf:17:b2:32:53:74:83:c2:9b:d7:5b:f4:d3:e6:70:89:
fd:e2:1e:25:4c:c0:bc:81:53:da:ae:e1:68:cf:62:33:af:d2:
df:66:5c:86:3f:14:7e:e4:11:e5:60:17:ea:d7:fb:28:80:ca:
8a:80:23:c6:1b:37:f0:f5:91:5f:55:88:1d:fe:1f:0f:b5:1d:
0b:3f:1f:4d:0e:34:33:68:52:67:c3:29:a8:5a:c2:87:47:a4:
9b:e1:80:61:33:14:7d:3f:3e:a7:6d:f6:2f:ab:41:d7:8f:14:
35:e9:e0:d6:12:fc:f8:f9:f6:64:ad:94:72:55:f8:d7:ed:a8:
11:f0:ee:b2:49:b7:d4:64:56:7e:df:34:ed:1a:fe:04:7a:87:
07:37:19:ac:bb:0f:9f:c6:a4:4d:72:92:c5:9d:20:16:b2:6b:
db:27:61:f9:62:d1:95:3d:1f:29:88:74:9a:89:43:57:07:cd:
18:77:77:8a:72:f3:49:a3:40:ba:33:ce:5b:b2:50:ff:42:c7:
a8:8a:59:ca:7e:25:93:52:64:4f:67:7d:96:3c:f3:cd:79:1d:
99:2d:89:e7
and my ca (openssl x509 -noout -text -in foreman_ssl_ca.pem
Certificate:
Data:
Version: 3 (0x2)
Serial Number:
6b:03:b3:1b:27:0a:dd:96:c6:5a:c4:f4:48:f4:dc:dd:19:d6:5b:91
Issuer: CN=aussieswithtails.com
Validity
Not Before: Dec 15 01:56:06 2017 GMT
Not After : Jan 16 01:56:36 2018 GMT
Subject: CN=AWT Intermediate Certificate Authority
Modulus:
00:cc:e7:17:86:74:a5:25:50:a7:5b:1e:ef:28:a2:
24:72:6d:1d:06:d6:cb:5e:a4:14:d2:fe:31:4c:ab:
ae:cd:06:26:77:c9:11:f6:42:cf:56:f8:35:c7:e0:
a8:d8:80:8c:61:4f:62:79:e9:0f:5c:ea:60:68:00:
6f:31:63:68:74:9a:8e:6c:a4:f4:e6:3a:ef:01:a7:
1f:d2:97:b2:6b:83:a6:f0:fe:63:d5:51:3a:24:c2:
38:10:d7:2a:99:fd:40:e8:e7:31:4c:95:52:69:37:
1b:2c:65:f4:68:fa:e2:c9:76:1f:fb:3e:d9:d7:51:
e2:92:75:d4:d9:f6:fe:2e:0a:e8:8a:d9:1c:aa:ab:
2f:b4:f4:28:f5:6c:e0:f6:9f:4e:0c:c5:1b:30:90:
3f:16:12:5f:a0:22:f0:4a:7f:ea:8b:c3:03:17:00:
de:ab:b3:d8:e3:02:55:a8:64:e1:91:c2:7d:59:4d:
54:8f:45:7f:93:8a:40:98:bf:9b:bb:30:83:43:d4:
57:35:4a:3d:5c:d2:61:62:c5:39:46:03:ee:a5:25:
c1:bb:a9:3f:60:35:03:14:51:17:f2:7b:fb:36:9c:
a4:88:85:a6:eb:4f:c3:f5:24:44:41:90:8b:1b:1d:
1d:45:7c:e5:a8:74:54:92:b3:71:96:d0:5e:50:87:
31:dd
X509v3 extensions:
Certificate Sign, CRL Sign
X509v3 Basic Constraints: critical
CA:TRUE
C0:41:49:9D:44:AB:32:36:EB:81:27:E0:18:F6:E6:9E:5B:9E:74:BF
keyid:0B:A4:90:CE:FA:61:FD:69:4F:11:F7:98:25:2D:20:FF:D8:AF:
58:D4
CA Issuers - URI:http://vault.example.com:8200/v1/pki/ca
DNS:AWT Intermediate Certificate Authority
Full Name:
URI:http://vault.example.com:8200/v1/pki/crl
73:09:4b:32:e2:39:ad:1c:4a:79:5c:c8:b1:e6:de:4a:32:55:
42:cc:e7:82:1c:e7:58:40:40:da:39:10:57:c8:14:ec:b4:72:
39:3c:92:6d:eb:65:b2:36:40:da:f0:24:c3:ac:c9:9d:37:55:
c6:6b:d9:55:d0:e2:74:8f:b4:48:ad:15:f4:6f:76:fb:84:69:
ee:b6:b3:31:f3:8d:6d:ac:5a:0c:75:81:98:17:20:9b:f6:33:
be:61:6d:0f:0f:78:c2:b5:90:45:22:82:55:94:57:96:00:ee:
68:65:95:b8:d0:72:45:46:07:69:36:47:d3:a4:ae:ce:ad:e5:
87:79:5a:64:e9:6f:e4:56:64:a7:01:f8:40:47:3e:58:ae:52:
9b:71:4a:61:d8:fa:b2:f5:5e:1a:e4:56:c9:5c:21:37:06:e2:
d2:a2:7a:7e:90:9f:8b:e9:93:a5:1b:ab:99:e3:c0:cb:96:ff:
19:0d:e5:fa:04:84:ed:ab:f7:9e:15:3b:91:44:ab:2c:aa:b9:
66:a8:06:ab:10:14:db:01:c0:5e:6a:b7:62:bf:ab:1e:35:14:
49:34:fc:5a:03:8b:b3:22:c9:97:f4:17:fc:87:21:6c:39:18:
26:60:9a:57:62:2f:48:0c:4a:87:1a:c6:39:1b:6f:1b:39:7a:
c6:14:b6:70
The root certificate is trusted. All certificates and keys were generated
through Hashicorp's Vault tool
I'm pretty much an ssl newbie so I may have made an obvious error.
Any assistance would be much appreciated.
-steve
