Help need foreman-rake db:migrate issue prior to 1.16 upgrade already on 1.15.x
API controllers newer than Apipie cache! Run apipie:cache rake task to regenerate cache.
rake aborted!
TypeError: no implicit conversion of nil into String
/usr/share/foreman/config/initializers/assets.rb:73:in `join' /usr/share/foreman/config/initializers/assets.rb:73:in `block (4 levels) in <top (required)>'
/usr/share/foreman/config/initializers/assets.rb:72:in `map' /usr/share/foreman/config/initializers/assets.rb:72:in `block (3 levels) in <top (required)>'
/usr/share/foreman/config/initializers/assets.rb:69:in `each' /usr/share/foreman/config/initializers/assets.rb:69:in `block (2 levels) in <top (required)>'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/lazy_load_hooks.rb:36:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/lazy_load_hooks.rb:36:in `execute_hook'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/lazy_load_hooks.rb:45:in `block in run_load_hooks'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/lazy_load_hooks.rb:44:in `each'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/lazy_load_hooks.rb:44:in `run_load_hooks'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/application/finisher.rb:62:in `block in <module:Finisher>'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/initializable.rb:30:in `instance_exec'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/initializable.rb:30:in `run'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/initializable.rb:55:in `block in run_initializers'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/initializable.rb:54:in `run_initializers'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/application.rb:352:in `initialize!'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/railtie.rb:194:in `public_send'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/railtie.rb:194:in `method_missing'
/usr/share/foreman/config/environment.rb:5:in `<top (required)>' /opt/rh/sclo-ror42/root/usr/share/gems/gems/polyglot-0.3.4/lib/polyglot.rb:65:in `require'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/dependencies.rb:274:in `block in require'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/dependencies.rb:240:in `load_dependency'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/dependencies.rb:274:in `require'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/application.rb:328:in `require_environment!'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/application.rb:457:in `block in run_tasks_blocks'
Tasks: TOP => db:migrate => environment
foreman-rake db:migrate --trace
** Invoke db:migrate (first_time)
** Execute environment
rake aborted!
/opt/rh/rh-ruby22/root/usr/share/ruby/tsort.rb:226:in `block in tsort_each' /opt/rh/rh-ruby22/root/usr/share/ruby/tsort.rb:348:in `block (2 levels) in each_strongly_connected_component'
/opt/rh/rh-ruby22/root/usr/share/ruby/tsort.rb:429:in
`each_strongly_connected_component_from'
/opt/rh/rh-ruby22/root/usr/share/ruby/tsort.rb:347:in `block in each_strongly_connected_component'
/opt/rh/rh-ruby22/root/usr/share/ruby/tsort.rb:345:in `each' /opt/rh/rh-ruby22/root/usr/share/ruby/tsort.rb:345:in `call' /opt/rh/rh-ruby22/root/usr/share/ruby/tsort.rb:345:in
`each_strongly_connected_component'
/opt/rh/rh-ruby22/root/usr/share/ruby/tsort.rb:224:in `tsort_each' /opt/rh/rh-ruby22/root/usr/share/ruby/tsort.rb:203:in `tsort_each' /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/initializable.rb:54:in `run_initializers'
/usr/share/foreman/config/environment.rb:5:in `<top (required)>' /opt/rh/rh-ruby22/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:54:in `require'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/task.rb:240:in `call'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/task.rb:240:in `block in execute'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/task.rb:235:in `each'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/task.rb:235:in `execute'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/task.rb:179:in `block in invoke_with_call_chain'
/opt/rh/rh-ruby22/root/usr/share/ruby/monitor.rb:211:in `mon_synchronize' /opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/task.rb:172:in `invoke_with_call_chain'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/task.rb:201:in `block in invoke_prerequisites'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/task.rb:199:in `each'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/task.rb:199:in `invoke_prerequisites'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/task.rb:178:in `block in invoke_with_call_chain'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/task.rb:165:in `invoke'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:150:in `invoke_task'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:106:in `block (2 levels) in top_level'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:106:in `each'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:106:in `block in top_level'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:115:in `run_with_threads'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:100:in `top_level'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:78:in `block in run'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:176:in `standard_exception_handling'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:75:in `run'
/opt/rh/rh-ruby22/root/usr/bin/rake:33:in `<main>'
Foreman Installer checked items
1. [✓] Configure foreman
2. [✓] Configure foreman_cli
4. [✓] Configure foreman_proxy
5. [✓] Configure puppet
6. [✓] Configure foreman_plugin_ansible
11. [✓] Configure foreman_plugin_default_hostgroup
16. [✓] Configure foreman_plugin_expire_hosts
25. [✓] Configure foreman_plugin_remote_execution
27. [✓] Configure foreman_plugin_setup
36. [✓] Configure foreman_compute_vmware
45. [✓] Configure foreman_proxy_plugin_dynflow
50. [✓] Configure foreman_proxy_plugin_remote_execution_ssh
Everything in the interactive foreman-installer
3. [✗] Configure foreman_cli_openscap
7. [✗] Configure foreman_plugin_azure
8. [✗] Configure foreman_plugin_bootdisk
9. [✗] Configure foreman_plugin_chef
10. [✗] Configure foreman_plugin_cockpit
12. [✗] Configure foreman_plugin_dhcp_browser
13. [✗] Configure foreman_plugin_digitalocean
14. [✗] Configure foreman_plugin_discovery
15. [✗] Configure foreman_plugin_docker
17. [✗] Configure foreman_plugin_hooks
18. [✗] Configure foreman_plugin_host_extra_validator
19. [✗] Configure foreman_plugin_memcache
20. [✗] Configure foreman_plugin_monitoring
21. [✗] Configure foreman_plugin_omaha
22. [✗] Configure foreman_plugin_openscap
23. [✗] Configure foreman_plugin_ovirt_provision
24. [✗] Configure foreman_plugin_puppetdb
26. [✗] Configure foreman_plugin_salt
28. [✗] Configure foreman_plugin_tasks
29. [✗] Configure foreman_plugin_templates
30. [✗] Configure foreman_compute_ec2
31. [✗] Configure foreman_compute_gce
32. [✗] Configure foreman_compute_libvirt
33. [✗] Configure foreman_compute_openstack
34. [✗] Configure foreman_compute_ovirt
35. [✗] Configure foreman_compute_rackspace
37. [✗] Configure foreman_proxy_plugin_abrt
38. [✗] Configure foreman_proxy_plugin_ansible
39. [✗] Configure foreman_proxy_plugin_chef
40. [✗] Configure foreman_proxy_plugin_dhcp_infoblox
41. [✗] Configure foreman_proxy_plugin_dhcp_remote_isc
42. [✗] Configure foreman_proxy_plugin_discovery
43. [✗] Configure foreman_proxy_plugin_dns_infoblox
44. [✗] Configure foreman_proxy_plugin_dns_powerdns
46. [✗] Configure foreman_proxy_plugin_monitoring
47. [✗] Configure foreman_proxy_plugin_omaha
48. [✗] Configure foreman_proxy_plugin_openscap
49. [✗] Configure foreman_proxy_plugin_pulp
regenerate cache.
rake aborted!
`call'
`execute_hook'
`each'
`run_load_hooks'
`instance_exec'
`run'
`run_initializers'
`initialize!'
`public_send'
`method_missing'
`require'
`block in require'
`load_dependency'
`require'
regenerate cache.
rake aborted!
`call'
`execute_hook'
`each'
`run_load_hooks'
`instance_exec'
`run'
`run_initializers'
`initialize!'
`public_send'
`method_missing'
`require'
`require'
`require'
`block in require'
`load_dependency'
`require'
`call'
`block in execute'
`each'
`execute'
`each'
`invoke'
`invoke_task'
`each'
`run_with_threads'
`top_level'
`block in run'
`run'
regenerate cache.
rake aborted!
run_load_hooks'
`require'
regenerate cache.
rake aborted!
run_load_hooks'
tsort_each'
`require'
`require'
`require'
`call'
`block in execute'
`each'
`execute'
`each'
`invoke'
`invoke_task'
`each'
`run_with_threads'
`top_level'
`block in run'
`run'
we had another thread where someone was mentioning that the template plugin might cause this error - can you try to removing it and see if thats the issue?
··· On Wed, Dec 6, 2017 at 10:03 PM, Jeff Stasko <staskoj@valassis.com> wrote:
"Foreman users" group.
I tried to search for another thread first I must have missed my apologies
foreman-rake templates:cleanup --trace
rake aborted!
Don't know how to build task 'templates:cleanup'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/task_manager.rb:62:in `[]'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:149:in `invoke_task'
··· On Wednesday, December 6, 2017 at 3:10:05 PM UTC-5, ohad wrote:
On Wed, Dec 6, 2017 at 10:03 PM, Jeff Stasko <sta...@valassis.com > <javascript:>> wrote:
regenerate cache.
rake aborted!
run_load_hooks'
`instance_exec'
`run'
`run_initializers'
`initialize!'
`public_send'
`method_missing'
`require'
regenerate cache.
rake aborted!
run_load_hooks'
`instance_exec'
`run'
tsort_each'
`run_initializers'
`initialize!'
`public_send'
`method_missing'
`require'
`require'
`require'
`call'
`block in execute'
`each'
`execute'
`each'
`invoke'
`invoke_task'
`each'
`run_with_threads'
`top_level'
`block in run'
`run'
the issue?
email to foreman-user...@googlegroups.com <javascript:>.
To post to this group, send email to forema...@googlegroups.com
<javascript:>.
more informational it is related to this specific rubygem - since you mention plugins I started removing some of the ones I used this plugin as soon as it removed clears the issue above.
tfm-rubygem-foreman_default_hostgroup noarch                            4.0.0-1.fm1_13.el7 @foreman-plugins 39 k
I admit it would have been better to remove one at a time but
regenerate cache.
rake aborted!
run_load_hooks'
`instance_exec'
`run'
`run_initializers'
`initialize!'
`public_send'
`method_missing'
`require'
regenerate cache.
rake aborted!
run_load_hooks'
`instance_exec'
`run'
tsort_each'
`run_initializers'
`initialize!'
`public_send'
`method_missing'
`require'
`require'
`require'
`call'
`block in execute'
`each'
`execute'
`each'
`invoke'
`invoke_task'
`each'
`run_with_threads'
`top_level'
`block in run'
`run'
the issue?
<javascript:>.
