Poblem: Install a foreman proxy for TFTP and not host any content or puppet components.
Foreman and Proxy versions: 5.0.1
Distribution and version: Rocky Linux 9
I have built a successful Foreman server. I have some remote sites and TFTP cross site is sufficiently slow that I can’t provision systems across the WAN. I believe this is a good use case for a smart proxy. I manually installed Linux (just like on the Foreman server) and attempted to run the command to install just the smart proxy, but foreman seems to want to install some puppet things (specifically requiring certificates) resulting in failures.
I’m sure I’m missing something. Hope someone can provide some guidance as to what I’m doing wrong.
The command I used to install the smart proxy:
foreman-installer \
--enable-foreman-proxy \
--no-enable-puppet \
--foreman-proxy-foreman-base-url https://adnyforeman.archnewyork.com \
--foreman-proxy-trusted-hosts adnyforeman.archnewyork.com \
--foreman-proxy-oauth-consumer-key ------------------------------------------------------- \
--foreman-proxy-oauth-consumer-secret --------------------------------------------------- \
--puppet-server false \
--puppet-server-ca false \
--foreman-proxy-manage-puppet-group false \
--foreman-proxy-puppet false \
--foreman-proxy-puppetca false \
--foreman-proxy-tftp true \
--foreman-proxy-tftp-managed true \
--foreman-proxy-dhcp-managed false \
--foreman-proxy-dns-managed false
And the output:
2026-11-03 16:30:51 [NOTICE] [root] Loading installer configuration. This will take some time.
2026-11-03 16:30:54 [NOTICE] [root] Running installer with log based terminal output at level NOTICE.
2026-11-03 16:30:54 [NOTICE] [root] Use -l to set the terminal output log level to ERROR, WARN, NOTICE, INFO, or DEBUG. See --full-help for definitions.
2026-11-03 16:30:56 [NOTICE] [checks] System checks passed
2026-11-03 16:30:58 [NOTICE] [configure] Starting system configuration.
2026-11-03 16:31:03 [NOTICE] [configure] 250 configuration steps out of 314 steps complete.
2026-11-03 16:31:04 [ERROR ] [configure] Systemd start for foreman-proxy failed!
2026-11-03 16:31:04 [ERROR ] [configure] journalctl log for foreman-proxy:
2026-11-03 16:31:04 [ERROR ] [configure] Nov 03 16:31:03 adnygoshenproxy systemd[1]: Starting Foreman Proxy...
2026-11-03 16:31:04 [ERROR ] [configure] Nov 03 16:31:04 adnygoshenproxy smart-proxy[21273]: Errors detected on startup, see log for details. Exiting: No such file or directory @ rb_sysopen - /etc/puppetlabs/puppet/ssl/private_keys/adnygoshenproxy.archnewyork.org.pem
2026-11-03 16:31:04 [ERROR ] [configure] Nov 03 16:31:04 adnygoshenproxy systemd[1]: foreman-proxy.service: Main process exited, code=exited, status=1/FAILURE
2026-11-03 16:31:04 [ERROR ] [configure] Nov 03 16:31:04 adnygoshenproxy systemd[1]: foreman-proxy.service: Failed with result 'exit-code'.
2026-11-03 16:31:04 [ERROR ] [configure] Nov 03 16:31:04 adnygoshenproxy systemd[1]: Failed to start Foreman Proxy.
2026-11-03 16:31:04 [ERROR ] [configure] /Stage[main]/Foreman_proxy::Service/Service[foreman-proxy]/ensure: change from 'stopped' to 'running' failed: Systemd start for foreman-proxy failed!
2026-11-03 16:31:05 [NOTICE] [configure] System configuration has finished.
