Help using forklift for katello dev box
This is my old boxes.yaml stanza, could someone help me translate it to the
latest forklift format? I'm blocked on testing because I can't disable
selinux and so want to set up a new dev box.
katello:
box: centos7
shell: 'yum -y install ruby && cd /vagrant && ./setup.rb'
installer: >-
–katello-devel-use-rvm=false
–katello-devel-github-username=thomasmckay
–katello-devel-enable-ostree=true
options: >-
–scenario katello-devel
–disable-selinux
–koji-repos
memory: 8192
cpus: 4
hostname: katello.example.com
networks:
- type: 'private_network'
options:
ip: 192.168.100.219
libvirt__network_name: provisioning
What's actually broken though?
the latest forklift format? I’m blocked on testing because I can’t disable
katello:
box: centos7
shell: 'yum -y install ruby && cd /vagrant && ./setup.rb’
installer: >-
options: >-
–disable-selinux
–koji-repos
memory: 8192
cpus: 4
networks:
- type: 'private_network’
options:
ip: 192.168.100.219
"foreman-dev" group.
I was told the 'options' section is no longer relevant. I'd just like to
know how to convert this old format to new.
··· On Sat, Oct 22, 2016 at 8:03 AM, Eric D Helms wrote:
What’s actually broken though?
katello:
box: centos7
installer: >-
options: >-
–disable-selinux
–koji-repos
memory: 8192
cpus: 4
networks:
options:
ip: 192.168.100.219
My PR to move the devel setup to Ansible has not been merged yet (
https://github.com/Katello/forklift/pull/279) so what you have is still
valid. Which is why I ask what the issue you are running in to is.
··· On Sat, Oct 22, 2016 at 8:08 AM, Tom McKay wrote:
I was told the ‘options’ section is no longer relevant. I’d just like to
On Sat, Oct 22, 2016 at 8:03 AM, Eric D Helms eric.d.helms@gmail.com > wrote:
katello:
box: centos7
installer: >-
options: >-
–disable-selinux
–koji-repos
memory: 8192
cpus: 4
networks:
options:
ip: 192.168.100.219
Groups “foreman-dev” group.
an email to foreman-dev+unsubscribe@googlegroups.com.
Eric D. Helms
Red Hat Engineering
Ph.D. Student - North Carolina State University
I see… I'm trying to turn this into a dev install so that I can hopefully
turn off selinux and have it actually work:
registry:
box: centos7
ansible:
group: 'server'
variables:
foreman_installer_module_prs:
"katello/capsule/101,theforeman/foreman_proxy/303"
foreman_installer_options: "–capsule-docker-registry-port=5001"
atomic_registry_registry_port: "5000"
playbook:
- 'playbooks/katello.yml'
- 'playbooks/katello_atomic_registry.yml'
On Sat, Oct 22, 2016 at 8:03 AM, Eric D Helms eric.d.helms@gmail.com >> wrote:
katello:
box: centos7
installer: >-
options: >-
–disable-selinux
–koji-repos
memory: 8192
cpus: 4
networks:
options:
ip: 192.168.100.219
Eric D. Helms
Red Hat Engineering
I think you have a couple options:
  1. Use my PR and review it to see about achieving what you want
  2. Spin up a dev box and then 'ansible-playbook -l registry
    playbooks/atomic_registry.yaml'
··· On Sat, Oct 22, 2016 at 8:32 AM, Tom McKay wrote:
I see… I’m trying to turn this into a dev install so that I can
hopefully turn off selinux and have it actually work:
registry:
box: centos7
ansible:
group: 'server’
variables:
foreman_installer_module_prs: "katello/capsule/101,
playbook:
- ‘playbooks/katello.yml’
- ‘playbooks/katello_atomic_registry.yml’
On Sat, Oct 22, 2016 at 8:03 AM, Eric D Helms eric.d.helms@gmail.com >>> wrote:
to the latest forklift format? I’m blocked on testing because I can’t
disable selinux and so want to set up a new dev box.
katello:
box: centos7
installer: >-
options: >-
–disable-selinux
–koji-repos
memory: 8192
cpus: 4
networks:
options:
ip: 192.168.100.219
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
I will try with your PR…
I see the katello_devel/tasks/main.yml runs the installer. How do other
playbooks add to this? This is probably also applicable to my
atomic_registry playbook as well: If I wanted to have it alter the
parameters to the foreman-installer (ie. change registry port), how is that
accomplished? Also need to enable ostree.
I can be on IRC today, if that is easier.
Running these PRs together:
https://github.com/Katello/forklift/pull/325
Fatal: [registry]: FAILED! => {"failed": true, "msg": "The conditional
check 'skip_installer == False' failed. The error was: error while
evaluating conditional (skip_installer == False): 'skip_installer' is
undefined\n\nThe error appears to have been in
'/home/thomasmckay/code/forklift/playbooks/roles/katello_devel/tasks/main.yml':
line 12, column 3, but may\nbe elsewhere in the file depending on the exact
syntax problem.\n\nThe offending line appears to be:\n\n\n- name: 'Run
devel installer'\n ^ here\n"}
registry:
box: centos7
ansible:
group: 'devel'
variables:
katello_devel_github_username: "thomasmckay"
foreman_installer_module_prs: "katello/capsule/101"
playbook:
- 'playbooks/katello_devel.yml'
  2. Spin up a dev box and then ‘ansible-playbook -l registry
    playbooks/atomic_registry.yaml’
registry:
box: centos7
ansible:
group: ‘server’
variables:
foreman_installer_module_prs: “katello/capsule/101,theforema
n/foreman_proxy/303”
foreman_installer_options: “–capsule-docker-registry-port=5001”
atomic_registry_registry_port: “5000”
playbook:
to know how to convert this old format to new.
On Sat, Oct 22, 2016 at 8:03 AM, Eric D Helms eric.d.helms@gmail.com >>>> wrote:
katello:
box: centos7
shell: ‘yum -y install ruby && cd /vagrant && ./setup.rb’
installer: >-
options: >-
–disable-selinux
–koji-repos
memory: 8192
cpus: 4
networks:
- type: ‘private_network’
options:
ip: 192.168.100.219
send an email to foreman-dev+unsubscribe@googlegroups.com.
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
I have updated my PR to make use of Stephen's new foreman_installer role
that centralizes calls to foreman_installer. Given that you can run
multiple playbooks, and that our installer is idempotent you have a few
options:
  1. Use the foreman_installer_options under 'variables' section in the box
    definition similar to what oyu have below (that ought to work with my
    refactor)
  2. Call the foreman-installer AFTER the devel setup with the options you
    need (the installer stores all the previous, so you ought to be able to run
    it again, updating any new options you want)
  3. Create a new playbook that you configure with everything you need
Try re-running what you have against my updates to my PR. Note that I
changed the playbook to simply 'devel'
Fatal: [registry]: FAILED! => {“failed”: true, “msg”: “The conditional
check ‘skip_installer == False’ failed. The error was: error while
evaluating conditional (skip_installer == False): ‘skip_installer’ is
undefined\n\nThe error appears to have been in ‘/home/thomasmckay/code/
forklift/playbooks/roles/katello_devel/tasks/main.yml’: line 12, column
3, but may\nbe elsewhere in the file depending on the exact syntax
problem.\n\nThe offending line appears to be:\n\n\n- name: ‘Run devel
installer’\n ^ here\n”}
registry:
box: centos7
ansible:
group: 'devel’
variables:
playbook:
- ‘playbooks/katello_devel.yml’
registry:
box: centos7
ansible:
group: 'server’
variables:
foreman_installer_module_prs: "katello/capsule/101,theforema
playbook:
On Sat, Oct 22, 2016 at 8:11 AM, Eric D Helms ericdhelms@gmail.com >>> wrote:
still valid. Which is why I ask what the issue you are running in to is.
On Sat, Oct 22, 2016 at 8:08 AM, Tom McKay thomasmckay@redhat.com >>>> wrote:
On Sat, Oct 22, 2016 at 8:03 AM, Eric D Helms eric.d.helms@gmail.com >>>>> wrote:
katello:
box: centos7
installer: >-
options: >-
–disable-selinux
–koji-repos
memory: 8192
cpus: 4
networks:
options:
ip: 192.168.100.219
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
> options:
> 1) Use the foreman_installer_options under 'variables' section in the box
> refactor)
This option seems most appropriate so went with that.
First run I got puppet_repositories_version is undefined. I defined it to
4, then next run I get "bin/sh: /opt/puppetlabs/puppet/bin/gem: No such
file or directory".
Any pointers on that?
I am on the atomic-registry PR and then I rebased it to your PR. Here is
the boxes.yaml
registry:
box: centos7
ansible:
group: 'devel'
variables:
puppet_repositories_version: 4
playbook:
- 'playbooks/devel.yml'
  1. Call the foreman-installer AFTER the devel setup with the options you
··· On Sat, Oct 22, 2016 at 10:28 AM, Eric D Helms wrote: > On Sat, Oct 22, 2016 at 9:35 AM, Tom McKay wrote: > need (the installer stores all the previous, so you ought to be able to run > it again, updating any new options you want) > 3) Create a new playbook that you configure with everything you need > > > Try re-running what you have against my updates to my PR. Note that I > changed the playbook to simply 'devel' > > > >> >> I can be on IRC today, if that is easier. >> >> Running these PRs together: >> https://github.com/Katello/forklift/pull/279 >> https://github.com/Katello/forklift/pull/325 >> >> Fatal: [registry]: FAILED! => {"failed": true, "msg": "The conditional >> check 'skip_installer == False' failed. The error was: error while >> evaluating conditional (skip_installer == False): 'skip_installer' is >> undefined\n\nThe error appears to have been in >> '/home/thomasmckay/code/forklift/playbooks/roles/katello_devel/tasks/main.yml': >> line 12, column 3, but may\nbe elsewhere in the file depending on the exact >> syntax problem.\n\nThe offending line appears to be:\n\n\n- name: 'Run >> devel installer'\n ^ here\n"} >> >> registry: >> box: centos7 >> ansible: >> group: 'devel' >> variables: >> katello_devel_github_username: "thomasmckay" >> foreman_installer_module_prs: "katello/capsule/101" >> foreman_installer_options: "--capsule-docker-registry-port=5001" >> atomic_registry_registry_port: "5000" >> playbook: >> - 'playbooks/katello_devel.yml' >> - 'playbooks/katello_atomic_registry.yml' >> >> >> >> On Sat, Oct 22, 2016 at 8:58 AM, Eric D Helms >> wrote: >> >>> I think you have a couple options: >>> >>> 1) Use my PR and review it to see about achieving what you want >>> 2) Spin up a dev box and then 'ansible-playbook -l registry >>> playbooks/atomic_registry.yaml' >>> >>> >>> On Sat, Oct 22, 2016 at 8:32 AM, Tom McKay >>> wrote: >>> >>>> I see... I'm trying to turn this into a dev install so that I can >>>> hopefully turn off selinux and have it actually work: >>>> >>>> registry: >>>> box: centos7 >>>> ansible: >>>> group: 'server' >>>> variables: >>>> foreman_installer_module_prs: "katello/capsule/101,theforema >>>> n/foreman_proxy/303" >>>> foreman_installer_options: "--capsule-docker-registry-port=5001" >>>> atomic_registry_registry_port: "5000" >>>> playbook: >>>> - 'playbooks/katello.yml' >>>> - 'playbooks/katello_atomic_registry.yml' >>>> >>>> >>>> On Sat, Oct 22, 2016 at 8:11 AM, Eric D Helms >>>> wrote: >>>> >>>>> My PR to move the devel setup to Ansible has not been merged yet ( >>>>> https://github.com/Katello/forklift/pull/279) so what you have is >>>>> still valid. Which is why I ask what the issue you are running in to is. >>>>> >>>>> On Sat, Oct 22, 2016 at 8:08 AM, Tom McKay >>>>> wrote: >>>>> >>>>>> I was told the 'options' section is no longer relevant. I'd just like >>>>>> to know how to convert this old format to new. >>>>>> >>>>>> On Sat, Oct 22, 2016 at 8:03 AM, Eric D Helms >>>>> > wrote: >>>>>> >>>>>>> What's actually broken though? >>>>>>> >>>>>>> On Oct 22, 2016 7:48 AM, "Tom McKay" wrote: >>>>>>> >>>>>>>> This is my old boxes.yaml stanza, could someone help me translate >>>>>>>> it to the latest forklift format? I'm blocked on testing because I can't >>>>>>>> disable selinux and so want to set up a new dev box. >>>>>>>> >>>>>>>> katello: >>>>>>>> box: centos7 >>>>>>>> shell: 'yum -y install ruby && cd /vagrant && ./setup.rb' >>>>>>>> installer: >- >>>>>>>> --katello-devel-use-rvm=false >>>>>>>> --katello-devel-github-username=thomasmckay >>>>>>>> --katello-devel-enable-ostree=true >>>>>>>> options: >- >>>>>>>> --scenario katello-devel >>>>>>>> --disable-selinux >>>>>>>> --koji-repos >>>>>>>> memory: 8192 >>>>>>>> cpus: 4 >>>>>>>> hostname: katello.example.com >>>>>>>> networks: >>>>>>>> - type: 'private_network' >>>>>>>> options: >>>>>>>> ip: 192.168.100.219 >>>>>>>> libvirt__network_name: provisioning >>>>>>>> >>>>>>>> -- >>>>>>>> You received this message because you are subscribed to the Google >>>>>>>> Groups "foreman-dev" group. >>>>>>>> To unsubscribe from this group and stop receiving emails from it, >>>>>>>> send an email to foreman-dev+unsubscribe@googlegroups.com. >>>>>>>> For more options, visit https://groups.google.com/d/optout. >>>>>>>> >>>>>>> -- >>>>>>> You received this message because you are subscribed to the Google >>>>>>> Groups "foreman-dev" group. >>>>>>> To unsubscribe from this group and stop receiving emails from it, >>>>>>> send an email to foreman-dev+unsubscribe@googlegroups.com. >>>>>>> For more options, visit https://groups.google.com/d/optout. >>>>>>> >>>>>> >>>>>> -- >>>>>> You received this message because you are subscribed to the Google >>>>>> Groups "foreman-dev" group. >>>>>> To unsubscribe from this group and stop receiving emails from it, >>>>>> send an email to foreman-dev+unsubscribe@googlegroups.com. >>>>>> For more options, visit https://groups.google.com/d/optout. >>>>>> >>>>> >>>>> >>>>> >>>>> -- >>>>> Eric D. Helms >>>>> Red Hat Engineering >>>>> Ph.D. Student - North Carolina State University >>>>> >>>>> -- >>>>> You received this message because you are subscribed to the Google >>>>> Groups "foreman-dev" group. >>>>> To unsubscribe from this group and stop receiving emails from it, send >>>>> an email to foreman-dev+unsubscribe@googlegroups.com. >>>>> For more options, visit https://groups.google.com/d/optout. >>>>> >>>> >>>> -- >>>> You received this message because you are subscribed to the Google >>>> Groups "foreman-dev" group. >>>> To unsubscribe from this group and stop receiving emails from it, send >>>> an email to foreman-dev+unsubscribe@googlegroups.com. >>>> For more options, visit https://groups.google.com/d/optout. >>>> >>> >>> >>> >>> -- >>> Eric D. Helms >>> Red Hat Engineering >>> Ph.D. Student - North Carolina State University >>> >>> -- >>> You received this message because you are subscribed to the Google >>> Groups "foreman-dev" group. >>> To unsubscribe from this group and stop receiving emails from it, send >>> an email to foreman-dev+unsubscribe@googlegroups.com. >>> For more options, visit https://groups.google.com/d/optout. >>> >> >> -- >> You received this message because you are subscribed to the Google Groups >> "foreman-dev" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to foreman-dev+unsubscribe@googlegroups.com. >> For more options, visit https://groups.google.com/d/optout. >> > > > > -- > Eric D. Helms > Red Hat Engineering > Ph.D. Student - North Carolina State University > > -- > You received this message because you are subscribed to the Google Groups > "foreman-dev" group. > To unsubscribe from this group and stop receiving emails from it, send an > email to foreman-dev+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout. >
Off the top of my head not sure, try using Puppet 3?
I have updated my PR to make use of Stephen’s new foreman_installer role
options:
  1. Use the foreman_installer_options under ‘variables’ section in the
    box definition similar to what oyu have below (that ought to work with my
    refactor)
4, then next run I get “bin/sh: /opt/puppetlabs/puppet/bin/gem: No such
file or directory”.
the boxes.yaml
registry:
box: centos7
ansible:
group: 'devel’
variables:
playbook:
- ‘playbooks/devel.yml’
changed the playbook to simply ‘devel’
’/home/thomasmckay/code/forklift/playbooks/roles/katello_devel/tasks/main.yml’:
syntax problem.\n\nThe offending line appears to be:\n\n\n- name: ‘Run
devel installer’\n ^ here\n”}
registry:
box: centos7
ansible:
group: 'devel’
variables:
playbook:
On Sat, Oct 22, 2016 at 8:58 AM, Eric D Helms ericdhelms@gmail.com >>> wrote:
On Sat, Oct 22, 2016 at 8:32 AM, Tom McKay thomasmckay@redhat.com >>>> wrote:
registry:
box: centos7
ansible:
group: 'server’
variables:
playbook:
On Sat, Oct 22, 2016 at 8:11 AM, Eric D Helms ericdhelms@gmail.com >>>>> wrote:
On Sat, Oct 22, 2016 at 8:08 AM, Tom McKay thomasmckay@redhat.com >>>>>> wrote:
like to know how to convert this old format to new.
On Sat, Oct 22, 2016 at 8:03 AM, Eric D Helms < >>>>>>> eric.d.helms@gmail.com> wrote:
it to the latest forklift format? I’m blocked on testing because I can’t
katello:
box: centos7
installer: >-
options: >-
–disable-selinux
–koji-repos
memory: 8192
cpus: 4
networks:
options:
ip: 192.168.100.219
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
w/ @ewoud help all good! I'll comment on PR and go from there.
++ for the help
On Oct 22, 2016 12:03 PM, “Tom McKay” thomasmckay@redhat.com wrote:
On Sat, Oct 22, 2016 at 10:28 AM, Eric D Helms ericdhelms@gmail.com >> wrote:
options:
    refactor)
file or directory”.
the boxes.yaml
registry:
box: centos7
ansible:
group: 'devel’
variables:
playbook:
registry:
box: centos7
ansible:
group: 'devel’
variables:
playbook:
On Sat, Oct 22, 2016 at 8:58 AM, Eric D Helms ericdhelms@gmail.com >>>> wrote:
On Sat, Oct 22, 2016 at 8:32 AM, Tom McKay thomasmckay@redhat.com >>>>> wrote:
registry:
box: centos7
ansible:
group: 'server’
variables:
t=5001"
playbook:
On Sat, Oct 22, 2016 at 8:11 AM, Eric D Helms ericdhelms@gmail.com >>>>>> wrote:
On Sat, Oct 22, 2016 at 8:08 AM, Tom McKay thomasmckay@redhat.com >>>>>>> wrote:
On Sat, Oct 22, 2016 at 8:03 AM, Eric D Helms < >>>>>>>> eric.d.helms@gmail.com> wrote:
katello:
box: centos7
installer: >-
options: >-
–disable-selinux
–koji-repos
memory: 8192
cpus: 4
networks:
options:
ip: 192.168.100.219
Google Groups “foreman-dev” group.
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
