I'm trying to use hook scripts do do some extra stuff when a host gets
added in forman.
I created a script to react to create events (in
config/hooks/host/managed/create ) that sucessfully pre provisions my hosts
in ipa, and puts the one time password generated during the ipa add host
operation in a variable in foreman for use during bootstrapping.
However, I also want to re prevision the host when it gets rebuild. This is
a frequent occurence, as we are doing very active devolopment here at the
moment (every host gets rebuild on average about once a week…)
I though I could do this by dropping a script in
config/hooks/host/managed/update. This hook gets triggered when I do a
rebuild. However, this script gets also triggered when I change something
in the host config, and also when the host signals itself to Foreman after
the first build…
So I can't use this. Is there another hook I can use, one that only gets
triggered by a rebuild?
Krist
host/managed/after_build will get called when a host is put into build mode.
On 09/12/13 15:18, Krist van Besien wrote:
> Hi,
> added in forman.
> hosts in ipa, and puts the one time password generated during the ipa
> add host operation in a variable in foreman for use during bootstrapping.
> is a frequent occurence, as we are doing very active devolopment here at
> the moment (every host gets rebuild on average about once a week...)
> something in the host config, and also when the host signals itself to
> Foreman after the first build...
Dominic Cleal
Red Hat Engineering
Thanks. That did it. I also noticed that the JSON passed to the script
contains a "build" parameter I can use as an extra check,. to avoid that a
host gets removed from IPA when it isn't being rebuild…
Krist
> mode.
