My hosts have recently stopped exiting from build mode after being provisioned. I see the following in my provisioning template:
<% if @provisioning_type == nil || @provisioning_type == 'host' -%>
# Inform the build system that we are done.
echo "Informing Foreman that we are built"
wget -q -O /dev/null --no-check-certificate <%= foreman_url %>
<% end -%>
) 2>&1 | tee /root/install.post.log
exit 0
And on a newly provisioned host the last line of /root/install.post.log is:
But the host's build status is still "Pending installation".
In production.log I see:
2017-01-10 14:03:05 174444cd [app] [I] Started GET "/unattended/built?token=4eb1bd5b-b6d1-4d1b-ba97-fc970546fe23" for 172.16.246.110 at 2017-01-10 14:03:05 -0600
2017-01-10 14:03:05 174444cd [app] [I] Processing by UnattendedController#built as TEXT
2017-01-10 14:03:05 174444cd [app] [I] Parameters: {"token"=>"4eb1bd5b-b6d1-4d1b-ba97-fc970546fe23"}
2017-01-10 14:03:05 174444cd [app] [D] Found sl2aosplpxy0001.ipa.centric.lab
2017-01-10 14:03:05 174444cd [app] [D] Setting current user thread-local variable to foreman_api_admin
2017-01-10 14:03:05 174444cd [app] [I] unattended: sl2aosplpxy0001.ipa.centric.lab is Built!
2017-01-10 14:03:05 174444cd [templates] [I] Rendering template 'PXEGrub2 default local boot'
2017-01-10 14:03:05 174444cd [templates] [I] Rendering template 'pxegrub2_chainload'
2017-01-10 14:03:05 174444cd [app] [W] Deploy TFTP PXEGrub2 config for sl2aosplpxy0001.ipa.centric.lab task failed with the following error: ERF12-5472 [ProxyAPI::ProxyException]: Unable to set TFTP boot entry for 00:50:56:91:71:66 ([RestClient::BadRequest]: 400 Bad Request) for proxy https://katello.ipa.centric.lab:9090/tftp
> ProxyAPI::ProxyException: ERF12-5472 [ProxyAPI::ProxyException]: Unable to set TFTP boot entry for 00:50:56:91:71:66 ([RestClient::BadRequest]: 400 Bad Request) for proxy https://katello.ipa.centric.lab:9090/tftp
> /usr/share/foreman/lib/proxy_api/tftp.rb:17:in `rescue in set'
> /usr/share/foreman/lib/proxy_api/tftp.rb:15:in `set'
> /usr/share/foreman/app/models/concerns/orchestration/tftp.rb:102:in `block in setTFTP'
> /usr/share/foreman/app/models/concerns/orchestration/tftp.rb:204:in `block in each_unique_feasible_tftp_proxy'
> /usr/share/foreman/app/models/concerns/orchestration/tftp.rb:203:in `map'
> /usr/share/foreman/app/models/concerns/orchestration/tftp.rb:203:in `each_unique_feasible_tftp_proxy'
> /usr/share/foreman/app/models/concerns/orchestration/tftp.rb:101:in `setTFTP'
> /usr/share/foreman/app/models/concerns/orchestration.rb:194:in `execute'
> /usr/share/foreman/app/models/concerns/orchestration.rb:135:in `block in process'
> /usr/share/foreman/app/models/concerns/orchestration.rb:127:in `each'
> /usr/share/foreman/app/models/concerns/orchestration.rb:127:in `process'
> /usr/share/foreman/app/models/concerns/orchestration.rb:35:in `around_save_orchestration'
<snip big log trace>
Any ideas?
j
Ehh, disregard this. I upgraded to 3.2.2/1.13.3 and it went away. Likely related:
http://projects.theforeman.org/issues/16475
----- Original Message -----
To: "Foreman Users"
Sent: Tuesday, January 10, 2017 3:47:46 PM
Subject: [foreman-users] Host Not Leaving "Build" Mode
<% end -%>
exit 0
But the host’s build status is still “Pending installation”.
Any ideas?
j
