@host variable does not work in if-statement
On a provisioning template the following does not work:
<% if @host.architecture == 'x86_64' -%>
foo
<% end -%>
Where the following prints: x86_64
<%= @host.architecture %>
What am I doing wrong here ?
Use: if @host.architecture.to_s == 'x86_64'
··· On 25/04/17 22:05, Matt . wrote: > On a provisioning template the following does not work: > > <% if @host.architecture == 'x86_64' -%> > foo > <% end -%>
Dominic Cleal
dominic@cleal.org
Yes I found that finally and also .name is possible instead of .to_s.
Why is this ?
··· Op woensdag 26 april 2017 09:08:17 UTC+2 schreef Dominic Cleal: > > On 25/04/17 22:05, Matt . wrote: > > On a provisioning template the following does not work: > > > > <% if @host.architecture == 'x86_64' -%> > > foo > > <% end -%> > > Use: if @host.architecture.to_s == 'x86_64' > > -- > Dominic Cleal > dom...@cleal.org >
@host.architecture is an object (a model) which is not directly equal to
a string ("x86_64"). .name or .to_s return the string containing the
name of the architecture.
··· On 26/04/17 11:00, Matt wrote: > Yes I found that finally and also .name is possible instead of .to_s. > > Why is this ?
Dominic Cleal
dominic@cleal.org
