How do i remove default location in Foreman as i'm using multiple location
how do i remove default location in Foreman as i’m using multiple location
I’m using couple of smart proxy servers and not able to register the server with the specific location as the default location takes up since it’s set as default
It is possible to assign a location when you register a host even when default location is set so maybe you are using the wrong method?
i’m using subscription-manager to register the server.
If you instead use the “curl url” generated by the “Register Host” wizard, it should solve your problem.
yes for the manual registration, but i’m doing with Ansible so looking for an option to get rid of default_location from settings.
