one can define VLANID on Subnet and it is possible also to create a virtual nic with (VLAN) tag when creating a new host. It is, however, unclear how this was meant. In some templates, we require tag to be present on NIC:
[lzap@nuc foreman]$ ag "\.tag" app/views/unattended
app/views/unattended/provisioning_templates/snippet/kickstart_kernel_options.erb
93: if iface.virtual? && iface.tag.present? && iface.attached_to.present?
103: options.push("vlanid=#{iface.tag}")
105: options.push("vlan=vlan#{iface.tag}:#{iface.attached_to}")
app/views/unattended/provisioning_templates/provision/kickstart_default.erb
161: if iface.virtual? && iface.tag.present? && iface.attached_to.present?
163: network_options.push("--vlanid=#{iface.tag}")
165: network_options.push("--interfacename=vlan#{iface.tag}")
In others, we actually use NIC tag or fallback to Subnet tag (via method vlanid
[lzap@nuc foreman]$ ag vlanid app/views/unattended
app/views/unattended/provisioning_templates/snippet/kickstart_ifcfg_generic_interface.erb
56:<%- if @interface.virtual? && (!@subnet.nil? && (@subnet.has_vlanid? || @interface.vlanid.present?)) -%>
70:<%- elsif @interface.virtual? && !@subnet.nil? && !@subnet.has_vlanid? && @interface.identifier.include?(':') -%>
app/views/unattended/provisioning_templates/PXELinux/preseed_default_pxelinux.erb
37: if @host.provision_interface.vlanid.present?
38: options << "netcfg/use_vlan=true netcfg/vlan_id=#{@host.provision_interface.vlanid}"
I would like to push forward making this consistent across templates, however, we have
- Use NIC tag and ignore Subnet (preferably when tag was pre-filled from Subnet in the UI): https://github.com/theforeman/foreman/pull/8735
- Inherit tag from Subnet: https://bugzilla.redhat.com/show_bug.cgi?id=2000620
I would like to ask you what you think? Which way we should be going? I lean towards @gvde 's proporal to simply use NIC tag and having Subnet VLANID to be more of “informative” with possibility to pre-fill tag into NIC in the UI.
