Maybe I'm missing something really obvious here but how do you get Foreman
to join a FreeIPA client to a domain when it is provisioned?
I followed all the steps in the Foreman manual and successfully installed a
foreman-proxy agent on a FreeIPA server and then configured the realm and
proxy in foreman.
Then I created a new server and set it to join the realm and provisioned it
with foreman. When the installation finished I logged onto the server and
there were no ipa-client packages installed.
I also looked at all the facts for the machine when it showed up in
foreman's hosts list and although it is listed as a member of the correct
realm and domain, I could not find the ipa one time password anywhere?
So…
1)Am I supposed to do something to manually join the machine and am I
supposed to know where to look for the onetime password to do this?
or
2)Is Foreman supposed to run the 'ipa-client-install' step but I have to
manually configure foreman to do this?
I couldn't find any examples of what the actual steps are to make this work.
On Wed, Apr 8, 2015 at 2:17 PM, Nathan Peters wrote:
Maybe I’m missing something really obvious here but how do you get Foreman
a foreman-proxy agent on a FreeIPA server and then configured the realm and
proxy in foreman.
it with foreman. When the installation finished I logged onto the server
and there were no ipa-client packages installed.
foreman’s hosts list and although it is listed as a member of the correct
So…
or
2)Is Foreman supposed to run the ‘ipa-client-install’ step but I have to
I couldn’t find any examples of what the actual steps are to make this
work.
Is there somewhere in the official foreman docs you can point me to that
lists downloading or installing that snippet?
Is that snippet already on my server and I just need to activate it?
Did I miss some step in the docs or is this something you actually have to
google to find out?
On Wednesday, April 8, 2015 at 11:19:21 AM UTC-7, Josh wrote:
> Are you including the freeipa_register snippet [1] in your provisioning
> template?
> [1]
> https://github.com/theforeman/community-templates/blob/master/snippets/freeipa_register.erb
> Thanks,
> Josh
>> Foreman to join a FreeIPA client to a domain when it is provisioned?
>> proxy in foreman.
>> So...
>> or
>> work.
>> "Foreman users" group.
>> Visit this group at http://groups.google.com/group/foreman-users.
There may be a version included with your Foreman distribution, but I'm
not certain. I would recommend using the version that I linked you to.
You will need to reference this in your main provisioning template:
installed a foreman-proxy agent on a FreeIPA server and then configured the
realm and proxy in foreman.
So…
or
work.
Foreman 1.7 does indeed include that snippet and it is correctly included
in the default kickstart templates.
I had the newly provisioned client pointed to the wrong dns server so
registration failed when it couldn't lookup the host.
On Wednesday, April 8, 2015 at 11:31:59 AM UTC-7, Josh wrote:
> There *may* be a version included with your Foreman distribution, but I'm
> <% if @host.info["parameters"]["realm"] && @host.otp && @host.realm &&
> @host.realm.realm_type == "FreeIPA" -%>
> # IdM Registration
> <%= snippet "freeipa_register" %>
> <% end -%>
> The documentation around this probably needs some updating.
> Thanks,
> Josh
> On Wed, Apr 8, 2015 at 2:27 PM, Nathan Peters > wrote:
>> I hadn't heard of this before.
>> to google to find out?
>>> template?
>>> [1] https://github.com/theforeman/community-templates/blob/master/
>>> Thanks,
>>> Josh
>>>> provisioned it with foreman. When the installation finished I logged onto
>>>> the server and there were no ipa-client packages installed.
>>>> So...
>>>> or
>>>> to manually configure foreman to do this?
>>>> work.
>>>> Groups "Foreman users" group.
>>>> an email to foreman-user...@googlegroups.com.
>>>> To post to this group, send email to forema...@googlegroups.com.
