Ah ok. Thanks a lot.
I never checked this as I installed with the default organization and
location I needed.
Now I can assign things far more easy then editing every single item!
But …
I got an error message:
*Oops, we're sorry but something went wrong*
Warning!
Validation failed: Taxonomy has already been taken
Trace:
/ActiveRecord::RecordInvalid/
*Validation failed: Taxonomy has already been taken*
app/controllers/concerns/foreman/controller/taxonomies_controller.rb:79:in
`block in update'
app/models/taxonomy.rb:52:in `block in no_taxonomy_scope'
app/models/taxonomy.rb:59:in `block (2 levels) in as_taxonomy'
app/models/concerns/foreman/thread_session.rb:148:in `as_location'
app/models/taxonomy.rb:58:in `block in as_taxonomy'
app/models/concerns/foreman/thread_session.rb:113:in `as_org'
app/models/taxonomy.rb:57:in `as_taxonomy'
app/models/taxonomy.rb:51:in `no_taxonomy_scope'
app/controllers/concerns/foreman/controller/taxonomies_controller.rb:78:in
`update'
app/models/concerns/foreman/thread_session.rb:33:in `clear_thread'
lib/middleware/catch_json_parse_errors.rb:9:in `call'
From the log:
Processing by OrganizationsController#update as HTML
Parameters: {"utf8"=>"✓",
"authenticity_token"=>"*****************",
"organization"=>{"name"=>"TESTORG", "description"=>"",
"service_level"=>"", "ignore_types"=>["0", "0", "0", "0", "0", "0",
"0", "0", "0", "0"], "user_ids"=>[""], "smart_proxy_ids"=>["1", ""],
"subnet_ids"=>["1", ""], "compute_resource_ids"=>[""],
"medium_ids"=>["1", "7", "", "2", "3", "4", "5", "6"],
"config_template_ids"=>["44", "54", "", "46", "45", "53", "54", "1",
"37", "39", "47"], "domain_ids"=>["1", ""], "realm_ids"=>["1", ""],
"environment_ids"=>["1", ""], "hostgroup_ids"=>["13", "11", "14",
"", "7", "12", "8", "9", "10", "3"], "location_ids"=>["2", ""]},
"commit"=>"Submit", "id"=>"1-testorg"}
Operation FAILED: Validation failed: Taxonomy has already been taken
Rendered common/500.html.erb within layouts/application (6.4ms)
Rendered layouts/base.html.erb (1.4ms)
Completed 500 Internal Server Error in 180ms (Views: 12.0ms |
ActiveRecord: 7.9ms)
Met vriendelijke groet, With kind regards,
Jorick Astrego
Netbulae Virtualization Experts
On 10/28/2014 04:34 PM, Greg Sutcliffe wrote:
> It's a bit one sided - you can;t do it from the ConfigTemplate edit
> page, but you can do it from the Loc/Org edit page. Have a look there
> and there should be a tab for templates.
> HTH,
> Greg
> You received this message because you are subscribed to the Google
> Groups "Foreman users" group.
> To unsubscribe from this group and stop receiving emails from it, send
> an email to foreman-users+unsubscribe@googlegroups.com
> To post to this group, send email to foreman-users@googlegroups.com
> Visit this group at http://groups.google.com/group/foreman-users.
Tel: 053 20 30 270 info@netbulae.eu Staalsteden 4-3A KvK 08198180
Fax: 053 20 30 271 www.netbulae.eu 7547 TA Enschede BTW NL821234584B01
