Hi Guys,
I started to use the foreman with ENC in my servers with puppet.
But I need to create a node default and I don't know, how to do this.
Anyone, could help me ?
Hi Guys,
Generally speaking, you don't want to. "node default" is a concept
that exists solely within site.pp, and while you can mix site.pp with
an ENC, it has caveats you should be aware of[1]. In particular,
defining classes in a "node default" block would be something I'd
avoid, since that's the ENC's job. Defining resource defaults is
probably fine though.
The better approach for classes is to define a "Base" (or similar
name) hostgroup or configgroup, and ensure it's assigned to all your
nodes. This keeps visibility where it should be, and doesn't introduce
strange behaviour when trying to debug where a node inherited a class
from (since you would naturally start with the classes coming from the
ENC).
HTH,
Greg
[1]https://docs.puppetlabs.com/guides/external_nodes.html#how-merging-works
Tks for your answer Greg.
Do you have a link ou a video to send me how to create or define a "Base"
on hostgroup or configgroup ?
Generally speaking, you don’t want to. “node default” is a concept
defining classes in a “node default” block would be something I’d
avoid, since that’s the ENC’s job. Defining resource defaults is
probably fine though.The better approach for classes is to define a “Base” (or similar
name) hostgroup or configgroup, and ensure it’s assigned to all your
nodes. This keeps visibility where it should be, and doesn’t introduce
ENC).HTH,
Greg[1]
https://docs.puppetlabs.com/guides/external_nodes.html#how-merging-works–
"Foreman users" group.
