(Foreman 1.10RC2, foreman-xen 0.2.2 compute ressource)
I try to create a vm with hammer :
[root@devops-build-03 ~]# hammer --debug host create --build=1 --name="
nico-test-06.devops.neura-local.com" --hostgroup-id 2
–compute-resource-id=1 --interface primary=true,provision=true,managed=true
But I got this error:
Could not create the host:
resource have no errors
I able to create the vm using the CLI with the same compute resource and
hostgroup. Someone encounters this problem ?
Log on foreman side:
- 2015-11-17 10:59:38 [app] [I] Processing by
Api::V2::HostsController#create as JSON - 2015-11-17 10:59:38 [app] [I] Parameters: {"host"=>{"name"=>"
nico-test-06.devops.neura-local.com", "compute_resource_id"=>1,
"hostgroup_id"=>2, "build"=>true, "enabled"=>true, "managed"=>true,
"compute_attributes"=>{"volumes_attri - butes"=>{}}, "host_parameters_attributes"=>{},
"interfaces_attributes"=>{"0"=>{"primary"=>"true", "provision"=>"true",
"managed"=>"true"}}}, "apiv"=>"v2"} - 2015-11-17 10:59:38 [app] [D] Setting current user thread-local
variable to foreman_admin - 2015-11-17 10:59:38 [app] [D] Setting current user thread-local
variable to nil - 2015-11-17 10:59:38 [app] [D] Setting current user thread-local
variable to admin - 2015-11-17 10:59:38 [app] [I] Authorized user admin(Admin User)
variable to admin - 2015-11-17 10:59:40 [app] [W] Action failed
- | RuntimeError: resource have no errors
- | /usr/share/foreman/app/controllers/api/base_controller.rb:90:in
`process_resource_error' - | /usr/share/foreman/app/controllers/api/base_controller.rb:110:in
`process_response' - |
/usr/share/foreman/app/controllers/api/v2/hosts_controller.rb:90:in `create' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/implicit_render.rb:4:in
`send_action' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/base.rb:167:in
`process_action' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rendering.rb:10:in
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/callbacks.rb:18:in
`block in process_action' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:573:in
`block (5 levels) in
_run__2597261230471645431__process_action__1529846330735909560__callbacks' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:215:in
`block in _conditional_callback_around_8658' - |
/usr/share/foreman/app/controllers/api/v2/base_controller.rb:151:in
`disable_json_root' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:214:in
`_conditional_callback_around_8658' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:550:in
`block (4 levels) in
`block in _conditional_callback_around_8657' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:326:in
`around' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:310:in
`_callback_around_2879' - |
`_conditional_callback_around_8657' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:527:in
`block (3 levels) in
`block in _conditional_callback_around_8656' - |
/usr/share/foreman/app/controllers/concerns/application_shared.rb:13:in
`set_timezone' - |
`_conditional_callback_around_8656' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:526:in
`block (2 levels) in
`block in _conditional_callback_around_8655' - |
/usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in
`clear_thread' - |
`_conditional_callback_around_8655' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:448:in
`block in
`block in _conditional_callback_around_8654' - |
`around' - |
`_callback_around_13' - |
`_conditional_callback_around_8654' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:414:in
`_run__2597261230471645431__process_action__1529846330735909560__callbacks' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:405:in
`__run_callback' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:385:in
`_run_process_action_callbacks' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:81:in
`run_callbacks' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/callbacks.rb:17:in
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rescue.rb:29:in
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:30:in
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications.rb:123:in
`block in instrument' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications/instrumenter.rb:20:in
`instrument' - |
`instrument' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:29:in
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/params_wrapper.rb:207:in
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/railties/controller_runtime.rb:18:in
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/base.rb:121:in
`process' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/rendering.rb:45:in
`process' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal.rb:203:in
`dispatch' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rack_delegation.rb:14:in
`dispatch' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal.rb:246:in
`block in action' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:73:in
`call' - |
`dispatch' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:36:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/mapper.rb:42:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/journey-1.0.4/lib/journey/router.rb:68:in
`block in call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/journey-1.0.4/lib/journey/router.rb:56:in
`each' - |
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:600:in
`call' - |
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.2.6/lib/apipie/static_dispatcher.rb:65:in
`call' - |
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.2.6/lib/apipie/extractor/recorder.rb:97:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/static.rb:62:in
`call' - |
`call' - |
`call' - |
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.2.6/lib/apipie/middleware/checksum_in_headers.rb:27:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/best_standards_support.rb:17:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/etag.rb:23:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/conditionalget.rb:35:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/head.rb:14:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/params_parser.rb:21:in
`call' - | /usr/share/foreman/lib/middleware/catch_json_parse_errors.rb:9:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/flash.rb:242:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/session/abstract/id.rb:205:in
`context' - |
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/session/abstract/id.rb:200:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/cookies.rb:339:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/query_cache.rb:64:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/abstract/connection_pool.rb:473:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/callbacks.rb:28:in
`block in call' - |
`_run__667215844898893561__call__3694175364566407301__callbacks' - |
`_run_call_callbacks' - |
`run_callbacks' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/callbacks.rb:27:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/remote_ip.rb:32:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/debug_exceptions.rb:16:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/show_exceptions.rb:56:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/rack/logger.rb:26:in
`call_app' - |
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/rack/logger.rb:16:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/request_id.rb:22:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/methodoverride.rb:21:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/runtime.rb:17:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/cache/strategy/local_cache.rb:72:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/lock.rb:15:in
`call' - |
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/rack-cache-1.2/lib/rack/cache/context.rb:136:in
`forward' - |
/opt/rh/ruby193/root/usr/share/gems/gems/rack-cache-1.2/lib/rack/cache/context.rb:143:in
`pass' - |
/opt/rh/ruby193/root/usr/share/gems/gems/rack-cache-1.2/lib/rack/cache/context.rb:155:in
`invalidate' - |
/opt/rh/ruby193/root/usr/share/gems/gems/rack-cache-1.2/lib/rack/cache/context.rb:71:in
`call!' - |
/opt/rh/ruby193/root/usr/share/gems/gems/rack-cache-1.2/lib/rack/cache/context.rb:51:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:479:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/application.rb:223:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/railtie/configurable.rb:30:in
`method_missing' - |
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/builder.rb:134:in
`call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/urlmap.rb:64:in
`block in call' - |
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/urlmap.rb:49:in
`each' - |
`call' - |
/usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/lib/phusion_passenger/rack/thread_handler_extension.rb:77:in
`process_request' - |
/usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/lib/phusion_passenger/request_handler/thread_handler.rb:140:in
`accept_and_process_next_request' - |
/usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/lib/phusion_passenger/request_handler/thread_handler.rb:108:in
`main_loop' - |
/usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/lib/phusion_passenger/request_handler.rb:441:in
`block (3 levels) in start_threads' - |
/opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/diagnostic_context.rb:323:in
`call' - |
`block in create_with_logging_context' - 2015-11-17 10:59:40 [app] [I] Rendered
api/v2/errors/standard_error.json.rabl within api/v2/layouts/error_layout
(0.7ms) - 2015-11-17 10:59:40 [app] [I] Completed 500 Internal Server Error
in 2483ms (Views: 1.9ms | ActiveRecord: 13.8ms)
Debug activate on hammer cli:
- root@devops-build-03 ~]# hammer --debug host create --build=1 --name="
–compute-resource-id=1 --interface primary=true,provision=true,managed=true - [ INFO 2015-11-17 10:59:37 Init] Initialization of Hammer CLI (0.4.0)
has started… - [DEBUG 2015-11-17 10:59:37 Init] Running at ruby 1.9.3-p484
- [ INFO 2015-11-17 10:59:37 Init] Configuration from the file
/etc/hammer/cli_config.yml has been loaded - [ INFO 2015-11-17 10:59:37 Init] Configuration from the file
/etc/hammer/cli.modules.d/foreman.yml has been loaded - [ INFO 2015-11-17 10:59:37 Init] Configuration from the file
/root/.hammer/cli.modules.d/foreman.yml has been loaded - [DEBUG 2015-11-17 10:59:37 Connection] Registered: foreman
- [DEBUG 2015-11-17 10:59:37 API] Global headers: {
:content_type => "application/json",
:accept => "application/json;version=2",
"Accept-Language" => "en"
- [ INFO 2015-11-17 10:59:37 Modules] Extension module
hammer_cli_foreman (0.4.0) loaded - [DEBUG 2015-11-17 10:59:37 Init] Using locale 'en'
- [DEBUG 2015-11-17 10:59:37 Init] 'mo' files for locale domain
'hammer-cli' loaded from
'/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-0.4.0/locale' - [DEBUG 2015-11-17 10:59:37 Init] 'mo' files for locale domain
'hammer-cli-foreman' loaded from
'/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman-0.4.0/locale' - [ INFO 2015-11-17 10:59:37 HammerCLI::MainCommand] Called with
options: {"option_debug"=>true} - [ INFO 2015-11-17 10:59:38 HammerCLIForeman::Host] Called with
options: {} - [ INFO 2015-11-17 10:59:38 HammerCLIForeman::Host::CreateCommand]
Called with options: {"option_managed"=>true, "option_build"=>true,
"option_enabled"=>true, "option_volume_list"=>[],
"option_interface_list"=>[{"primary"=>"true", "provision"=>"true",
"managed"=>"true"}], "option_compute_resource_id"=>1,
"option_hostgroup_id"=>2, "option_name"=>"
nico-test-06.devops.neura-local.com"} - [ INFO 2015-11-17 10:59:38 API] POST /api/hosts
- [DEBUG 2015-11-17 10:59:38 API] Params: {
"host" => {
"name" => "
24. "compute_resource_id" => 1,
25. "hostgroup_id" => 2,
26. "build" => true,
27. "enabled" => true,
28. "managed" => true,
29. "compute_attributes" => {
30. "volumes_attributes" => {}
31. },
32. "host_parameters_attributes" => {},
33. "interfaces_attributes" => {
34. "0" => {
35. "primary" => "true",
36. "provision" => "true",
37. "managed" => "true"
38. }
39. }
40. }
41. }
42. [DEBUG 2015-11-17 10:59:38 API] Hea
