Example: i have a machine with damaged MBO or onboard LAN. I must replace machine asap. So, i do following procedure:
- discover new machine with identical hardware
- while FDI still running on discovered hosts, i swap the disks: take out empty ones, ant put in disks from old machine
- in “provision host” dialog, i select same OS as on old machine
- clear checkbox on “Build Mode”
Machine reboots, but instead of booting form disk, it goes to build, boots installer and overwrite disks with fresh OS.
Machine should be booted from disk immediately after provision if “Build Mode” is set to false.
Am I doing something wrong (again)?
Discovery 15.0.0
