Hello
I want use the parameter @host.operatingsystem.major in puppet module.
But I did find document to use this functions.
Is there any body help me how to use it?
Thanks very much!
Xiaofei
Hello
Thanks very much!
Xiaofei
If you have a smart class parameter on your Puppet class and you're
using Foreman 1.3, ensure the interpolate_erb_in_parameters setting is
enabled and then change the value of your parameter to:
<%= @host.operatingsystem.major %>
Foreman will run ERB inside your parameters so you can put these normal
template values in.
Dominic Cleal
Red Hat Engineering
锟斤拷 2013-12-5 16:46, Dominic Cleal wrote:
>> Hello
>> Thanks very much!
Is this should be used in erb files
I want use case function in puppet manifest file. I look at the node
yaml and found the parameters "operatingsystemmajrelease"
I'll use this parameters to configure different yum repos.
Thanks very much
Xiaofei
template values in.
