I am starting with projects w/o much translations:
bastion : https://github.com/Katello/bastion/pull/72
katello: https://github.com/Katello/katello/pull/5334
I will start to work on the other projects next. I assume for foreman
core, the PR should go against 1.9. For the plugins and hammer, should
it go against the development branch… or the latest release?
Thanks!
– bk
Note that we can't merge translations into the git repo, they have to be
sent to Transifex.
Now is also the worst time to try and merge in translated strings in
bulk, as translation is underway for 1.9. I'd suggest doing it once
it's quietened down, or after the first or second 1.9 release when we're
heading towards 1.10.
Against the current .pot in their develop or master branches.
On 01/07/15 23:28, Bryan Kearney wrote:
Dominic Cleal
Red Hat Engineering
> sent to Transifex.
I was assuming if I pull the latest down, and then merge in the
donstream changes, then on approval it could be a :
create a edit.po for each .poi file
tx push
would that work?
I will hold off a bit to the core ones, and try out the process on the
plugins which are not really changing. Some of them do not seem to have
changed for a few weeks.
Will do for the plugins. For foreman-core, do you want it against 1.9 or
against develop?
– bk
>> sent to Transifex.
> tx push
> would that work?
If it's just new strings, that's fine. A while ago you had a thread
open about changing existing strings and reviewing that, do you still
plan to propose that?
The POT files may not have, but note that the strings in Transifex may
be changing still.
> against develop?
Currently we're translating 1.9, and usually only translate the latest
stable release, rarely develop.
Dominic Cleal
Red Hat Engineering
>>> sent to Transifex.
>> tx push
>> would that work?
Yes, I will call those out specifically in a seperate pastebin so that
those are easy to find. I will do a test run on a smaller plugin first
so that folks see the process before core.
> be changing still.
Yeah, I was checking the dates on the transifex website.
>> against develop?
kk… will do a pr against 1.9 then once it settles down.
– bk
