After install I got the error how do i fix this??
Ruby (Rack) application could not be started
These are the possible causes:
- There may be a syntax error in the application's code. Please check
for such errors and fix them.
- A required library may not installed. Please install all libraries
that this application requires.
- The application may not be properly configured. Please check whether
all configuration files are written correctly, fix any incorrect
configurations, and restart this application.
- A service that the application relies on (such as the database
server or the Ferret search engine server) may not have been started.
Please start that service.
Further information about the error may have been written to the
application's log file. Please check it in order to analyse the problem. Error
message:could not connect to server: No such file or directory Is the
server running locally and accepting connections on Unix domain socket
"/var/run/postgresql/.s.PGSQL.5432"? (PG::ConnectionBad)Exception class:
PhusionPassenger::UnknownErrorApplication root: /usr/share/foreman
Backtrace: # File Line Location 0
/usr/share/foreman/vendor/ruby/1.8/gems/activerecord-3.2.13/lib/active_record/connection_adapters/postgresql_adapter.rb
1216 in initialize' 1 /usr/share/foreman/vendor/ruby/1.8/gems/activerecord-3.2.13/lib/active_record/connection_adapters/postgresql_adapter.rb 1216 in
connect' 2
1216 in connect' 3 /usr/share/foreman/vendor/ruby/1.8/gems/activerecord-3.2.13/lib/active_record/connection_adapters/postgresql_adapter.rb 324 in
initialize' 4
28 in new' 5 /usr/share/foreman/vendor/ruby/1.8/gems/activerecord-3.2.13/lib/active_record/connection_adapters/postgresql_adapter.rb 28 in
postgresql_connection' 6
/usr/share/foreman/vendor/ruby/1.8/gems/activerecord-3.2.13/lib/active_record/connection_adapters/abstract/connection_pool.rb
315 in send' 7 /usr/share/foreman/vendor/ruby/1.8/gems/activerecord-3.2.13/lib/active_record/connection_adapters/abstract/connection_pool.rb 315 in
new_connection' 8
325 in checkout_new_connection' 9 /usr/share/foreman/vendor/ruby/1.8/gems/activerecord-3.2.13/lib/active_record/connection_adapters/abstract/connection_pool.rb 247 in
checkout' 10
242 in loop' 11 /usr/share/foreman/vendor/ruby/1.8/gems/activerecord-3.2.13/lib/active_record/connection_adapters/abstract/connection_pool.rb 242 in
checkout' 12 /usr/lib/ruby/1.8/monitor.rb 242 in synchronize' 13 /usr/share/foreman/vendor/ruby/1.8/gems/activerecord-3.2.13/lib/active_record/connection_adapters/abstract/connection_pool.rb 239 in
checkout' 14
102 in connection' 15 /usr/lib/ruby/1.8/monitor.rb 242 in
synchronize'
16
101 in connection' 17 /usr/share/foreman/vendor/ruby/1.8/gems/activerecord-3.2.13/lib/active_record/connection_adapters/abstract/connection_pool.rb 410 in
retrieve_connection' 18
/usr/share/foreman/vendor/ruby/1.8/gems/activerecord-3.2.13/lib/active_record/connection_adapters/abstract/connection_specification.rb
171 in retrieve_connection' 19 /usr/share/foreman/vendor/ruby/1.8/gems/activerecord-3.2.13/lib/active_record/connection_adapters/abstract/connection_specification.rb 145 in
connection' 20
/usr/share/foreman/vendor/ruby/1.8/gems/activerecord-3.2.13/lib/active_record/model_schema.rb
308 in clear_cache!' 21 /usr/share/foreman/vendor/ruby/1.8/gems/activerecord-3.2.13/lib/active_record/railtie.rb 104 in
_callback_before_17' 22
/usr/share/foreman/vendor/ruby/1.8/gems/activesupport-3.2.13/lib/active_support/callbacks.rb
418 in _run__792819900__prepare__4__callbacks' 23 /usr/share/foreman/vendor/ruby/1.8/gems/activesupport-3.2.13/lib/active_support/callbacks.rb 405 in
send' 24
405 in __run_callback' 25 /usr/share/foreman/vendor/ruby/1.8/gems/activesupport-3.2.13/lib/active_support/callbacks.rb 385 in
_run_prepare_callbacks' 26
81 in send' 27 /usr/share/foreman/vendor/ruby/1.8/gems/activesupport-3.2.13/lib/active_support/callbacks.rb 81 in
run_callbacks' 28
/usr/share/foreman/vendor/ruby/1.8/gems/actionpack-3.2.13/lib/action_dispatch/middleware/reloader.rb
74 in prepare!' 29 /usr/share/foreman/vendor/ruby/1.8/gems/actionpack-3.2.13/lib/action_dispatch/middleware/reloader.rb 48 in
prepare!' 30
/usr/share/foreman/vendor/ruby/1.8/gems/railties-3.2.13/lib/rails/application/finisher.rb
47
31
/usr/share/foreman/vendor/ruby/1.8/gems/railties-3.2.13/lib/rails/initializable.rb
30 in instance_exec' 32 /usr/share/foreman/vendor/ruby/1.8/gems/railties-3.2.13/lib/rails/initializable.rb 30 in
run' 33
55 in run_initializers' 34 /usr/share/foreman/vendor/ruby/1.8/gems/railties-3.2.13/lib/rails/initializable.rb 54 in
each' 35
54 in run_initializers' 36 /usr/share/foreman/vendor/ruby/1.8/gems/railties-3.2.13/lib/rails/application.rb 136 in
initialize!' 37
/usr/share/foreman/vendor/ruby/1.8/gems/railties-3.2.13/lib/rails/railtie/configurable.rb
30 in send' 38 /usr/share/foreman/vendor/ruby/1.8/gems/railties-3.2.13/lib/rails/railtie/configurable.rb 30 in
method_missing' 39 /usr/share/foreman/config/environment.rb 5
40 /usr/lib/ruby/vendor_ruby/1.8/rubygems/custom_require.rb 36 in
gem_original_require' 41 /usr/lib/ruby/vendor_ruby/1.8/rubygems/custom_require.rb 36 in
require' 42
config.ru 3
43 /usr/lib/ruby/vendor_ruby/rack/builder.rb 51 in instance_eval' 44 /usr/lib/ruby/vendor_ruby/rack/builder.rb 51 in
initialize' 45 config.ru 1 in
`new' 46 config.ru 1
Powered by Phusion Passenger <http://www.modrails.com/>, mod_rails /
mod_rack for Apache.
What OS, OS version, etc… are you installing on and how did you install?
- There may be a syntax error in the application’s code. Please check
whether all configuration files are written correctly, fix any incorrect
application’s log file. Please check it in order to analyse the problem. Error
connect’ 2
initialize’ 4
postgresql_connection’ 6
new_connection’ 8
checkout’ 10
checkout’ 12 /usr/lib/ruby/1.8/monitor.rb 242 in synchronize' 13 /usr/share/foreman/vendor/ruby/1.8/gems/activerecord-3.2.13/lib/active_record/connection_adapters/abstract/connection_pool.rb 239 in
checkout’ 14
synchronize’
16
retrieve_connection’ 18
connection’ 20
_callback_before_17’ 22
send’ 24
_run_prepare_callbacks’ 26
run_callbacks’ 28
prepare!’ 30
47
31
run’ 33
each’ 35
initialize!’ 37
method_missing’ 39 /usr/share/foreman/config/environment.rb 5
require’
42 config.ru 3
initialize’ 45 config.ru
1 in `new’ 46 config.ru 1
Powered by Phusion Passenger http://www.modrails.com/, mod_rails /
"Foreman users" group.
Romeo
Check PostgreSQL is running?
Maybe there were errors during the installer run?
On 21/08/13 19:03, limbooface wrote:
> Error message:
> could not connect to server: No such file or directory Is the server
Dominic Cleal
Red Hat Engineering
