Foreman can reboot the servers that are attached to it, but won’t actually start imaging them.
After reboot, server SHOULD see a PXE boot image and start installing the desired OS.
Foreman Version 3.4.1. Proxy version also 3.4.1
Foreman version 3.4.1, the plugin versions I don’t know. It’s whatever Foreman installed upon the first install, so I assume the latest stable builds??
Unknown.
Some of the Log file.
type or paste code here
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/public_keys]/seluser: Found seluser default 'system_u' for /etc/puppetlabs/puppet/ssl/public_keys
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/public_keys]/selrole: Found selrole default 'object_r' for /etc/puppetlabs/puppet/ssl/public_keys
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/public_keys]/seltype: Found seltype default 'puppet_etc_t' for /etc/puppetlabs/puppet/ssl/public_keys
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/public_keys]/selrange: Found selrange default 's0' for /etc/puppetlabs/puppet/ssl/public_keys
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/certificate_requests]/seluser: Found seluser default 'system_u' for /etc/puppetlabs/puppet/ssl/certificate_requests
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/certificate_requests]/selrole: Found selrole default 'object_r' for /etc/puppetlabs/puppet/ssl/certificate_requests
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/certificate_requests]/seltype: Found seltype default 'puppet_etc_t' for /etc/puppetlabs/puppet/ssl/certificate_requests
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/certificate_requests]/selrange: Found selrange default 's0' for /etc/puppetlabs/puppet/ssl/certificate_requests
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/private_keys]/seluser: Found seluser default 'system_u' for /etc/puppetlabs/puppet/ssl/private_keys
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/private_keys]/selrole: Found selrole default 'object_r' for /etc/puppetlabs/puppet/ssl/private_keys
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/private_keys]/seltype: Found seltype default 'puppet_etc_t' for /etc/puppetlabs/puppet/ssl/private_keys
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/private_keys]/selrange: Found selrange default 's0' for /etc/puppetlabs/puppet/ssl/private_keys
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/private]/seluser: Found seluser default 'system_u' for /etc/puppetlabs/puppet/ssl/private
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/private]/selrole: Found selrole default 'object_r' for /etc/puppetlabs/puppet/ssl/private
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/private]/seltype: Found seltype default 'puppet_etc_t' for /etc/puppetlabs/puppet/ssl/private
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/private]/selrange: Found selrange default 's0' for /etc/puppetlabs/puppet/ssl/private
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/certs/foreman.graingerdock4.com.pem]/seluser: Found seluser default 'system_u' for /etc/puppetlabs/puppet/ssl/certs/foreman.graingerdock4.com.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/certs/foreman.graingerdock4.com.pem]/selrole: Found selrole default 'object_r' for /etc/puppetlabs/puppet/ssl/certs/foreman.graingerdock4.com.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/certs/foreman.graingerdock4.com.pem]/seltype: Found seltype default 'puppet_etc_t' for /etc/puppetlabs/puppet/ssl/certs/foreman.graingerdock4.com.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/certs/foreman.graingerdock4.com.pem]/selrange: Found selrange default 's0' for /etc/puppetlabs/puppet/ssl/certs/foreman.graingerdock4.com.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/private_keys/foreman.graingerdock4.com.pem]/seluser: Found seluser default 'system_u' for /etc/puppetlabs/puppet/ssl/private_keys/foreman.graingerdock4.com.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/private_keys/foreman.graingerdock4.com.pem]/selrole: Found selrole default 'object_r' for /etc/puppetlabs/puppet/ssl/private_keys/foreman.graingerdock4.com.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/private_keys/foreman.graingerdock4.com.pem]/seltype: Found seltype default 'puppet_etc_t' for /etc/puppetlabs/puppet/ssl/private_keys/foreman.graingerdock4.com.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/private_keys/foreman.graingerdock4.com.pem]/selrange: Found selrange default 's0' for /etc/puppetlabs/puppet/ssl/private_keys/foreman.graingerdock4.com.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/public_keys/foreman.graingerdock4.com.pem]/seluser: Found seluser default 'system_u' for /etc/puppetlabs/puppet/ssl/public_keys/foreman.graingerdock4.com.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/public_keys/foreman.graingerdock4.com.pem]/selrole: Found selrole default 'object_r' for /etc/puppetlabs/puppet/ssl/public_keys/foreman.graingerdock4.com.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/public_keys/foreman.graingerdock4.com.pem]/seltype: Found seltype default 'puppet_etc_t' for /etc/puppetlabs/puppet/ssl/public_keys/foreman.graingerdock4.com.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/public_keys/foreman.graingerdock4.com.pem]/selrange: Found selrange default 's0' for /etc/puppetlabs/puppet/ssl/public_keys/foreman.graingerdock4.com.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/certs/ca.pem]/seluser: Found seluser default 'system_u' for /etc/puppetlabs/puppet/ssl/certs/ca.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/certs/ca.pem]/selrole: Found selrole default 'object_r' for /etc/puppetlabs/puppet/ssl/certs/ca.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/certs/ca.pem]/seltype: Found seltype default 'puppet_etc_t' for /etc/puppetlabs/puppet/ssl/certs/ca.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/certs/ca.pem]/selrange: Found selrange default 's0' for /etc/puppetlabs/puppet/ssl/certs/ca.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/crl.pem]/seluser: Found seluser default 'system_u' for /etc/puppetlabs/puppet/ssl/crl.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/crl.pem]/selrole: Found selrole default 'object_r' for /etc/puppetlabs/puppet/ssl/crl.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/crl.pem]/seltype: Found seltype default 'puppet_etc_t' for /etc/puppetlabs/puppet/ssl/crl.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/crl.pem]/selrange: Found selrange default 's0' for /etc/puppetlabs/puppet/ssl/crl.pem
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/opt/puppetlabs/puppet/cache/facts.d]/seluser: Found seluser default 'system_u' for /opt/puppetlabs/puppet/cache/facts.d
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/opt/puppetlabs/puppet/cache/facts.d]/selrole: Found selrole default 'object_r' for /opt/puppetlabs/puppet/cache/facts.d
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/opt/puppetlabs/puppet/cache/facts.d]/seltype: Found seltype default 'usr_t' for /opt/puppetlabs/puppet/cache/facts.d
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/opt/puppetlabs/puppet/cache/facts.d]/selrange: Found selrange default 's0' for /opt/puppetlabs/puppet/cache/facts.d
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/opt/puppetlabs/puppet/cache/locales]/seluser: Found seluser default 'system_u' for /opt/puppetlabs/puppet/cache/locales
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/opt/puppetlabs/puppet/cache/locales]/selrole: Found selrole default 'object_r' for /opt/puppetlabs/puppet/cache/locales
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/opt/puppetlabs/puppet/cache/locales]/seltype: Found seltype default 'usr_t' for /opt/puppetlabs/puppet/cache/locales
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/opt/puppetlabs/puppet/cache/locales]/selrange: Found selrange default 's0' for /opt/puppetlabs/puppet/cache/locales
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/opt/puppetlabs/puppet/cache/state]: Adding autorequire relationship with File[/opt/puppetlabs/puppet/cache]
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/opt/puppetlabs/puppet/cache/lib]: Adding autorequire relationship with File[/opt/puppetlabs/puppet/cache]
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/opt/puppetlabs/puppet/cache/preview]: Adding autorequire relationship with File[/opt/puppetlabs/puppet/cache]
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/certs]: Adding autorequire relationship with File[/etc/puppetlabs/puppet/ssl]
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl]: Adding autorequire relationship with File[/etc/puppetlabs/puppet]
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/public_keys]: Adding autorequire relationship with File[/etc/puppetlabs/puppet/ssl]
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/certificate_requests]: Adding autorequire relationship with File[/etc/puppetlabs/puppet/ssl]
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/private_keys]: Adding autorequire relationship with File[/etc/puppetlabs/puppet/ssl]
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/private]: Adding autorequire relationship with File[/etc/puppetlabs/puppet/ssl]
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/certs/foreman.graingerdock4.com.pem]: Adding autorequire relationship with File[/etc/puppetlabs/puppet/ssl/certs]
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/private_keys/foreman.graingerdock4.com.pem]: Adding autorequire relationship with File[/etc/puppetlabs/puppet/ssl/private_keys]
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/public_keys/foreman.graingerdock4.com.pem]: Adding autorequire relationship with File[/etc/puppetlabs/puppet/ssl/public_keys]
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/certs/ca.pem]: Adding autorequire relationship with File[/etc/puppetlabs/puppet/ssl/certs]
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/etc/puppetlabs/puppet/ssl/crl.pem]: Adding autorequire relationship with File[/etc/puppetlabs/puppet/ssl]
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/opt/puppetlabs/puppet/cache/facts.d]: Adding autorequire relationship with File[/opt/puppetlabs/puppet/cache]
2022-12-21 17:14:05 [DEBUG ] [configure] /File[/opt/puppetlabs/puppet/cache/locales]: Adding autorequire relationship with File[/opt/puppetlabs/puppet/cache]
2022-12-21 17:14:05 [DEBUG ] [configure] Finishing transaction 177940
2022-12-21 17:14:05 [DEBUG ] [configure] Received report to process from foreman.graingerdock4.com
2022-12-21 17:14:06 [NOTICE] [configure] System configuration has finished.
2022-12-21 17:14:06 [INFO ] [post] Executing hooks in group post
2022-12-21 17:14:06 [DEBUG ] [root] Executing: foreman-rake upgrade:run
2022-12-21 17:14:11 [DEBUG ] [post] Hook /usr/share/foreman-installer/hooks/post/30-upgrade.rb returned nil
2022-12-21 17:14:11 [DEBUG ] [post] Hook /usr/share/foreman-installer/hooks/post/34-pulpcore_directory_layout.rb returned nil
2022-12-21 17:14:11 [DEBUG ] [post] Hook /usr/share/foreman-installer/hooks/post/99-post_install_message.rb returned nil
2022-12-21 17:14:11 [DEBUG ] [post] Hook /usr/share/foreman-installer/hooks/post/99-version_locking.rb returned nil
2022-12-21 17:14:11 [INFO ] [post] All hooks in group post finished
2022-12-21 17:14:11 [DEBUG ] [pre_exit] Hook /usr/share/foreman-installer/hooks/pre_exit/20-certs_regenerate.rb returned nil
2022-12-21 17:14:11 [DEBUG ] [root] Exit with status code: 2 (signal was 2)
2022-12-21 17:14:11 [DEBUG ] [root] Cleaning /tmp/kafo_installation20221221-108262-2ihu7j
2022-12-21 17:14:11 [DEBUG ] [root] Cleaning /tmp/kafo_installation20221221-108262-18b1xfl
2022-12-21 17:14:11 [DEBUG ] [root] Cleaning /tmp/default_values.yaml
2022-12-21 17:14:11 [DEBUG ] [root] Installer finished in 42.319060388 seconds
