Hey Greg,
> > A) Unattended installations. Anaconda, the Red Hat and Fedora installer,
> > does support http proxy setting in kickstart and I assume the same for
> > other Linux distributions.
> I think assuming that could cause us problems. Relying on it could
> shut us out of some OSes if they don't support it (or there are bugs
> in their implementation of it).
I understand, proxy would be totally optional.
> > User would need to specify additional smart proxy on a host with "http
> > proxy" feature turned on. This would be used in the provision template.
> > Therefore minimum Foreman UI impact.
> Bear in mind we already have pull requests open for handling templates
> on the smart-proxy, which correctly handles re-writing the URLs in the
> template, so the client is talking direct to the smart-proxy, and the
> smart-proxy separately talks to Foreman. In that scenario, we no
> longer need an HTTP proxy (and thus don't need to assume the OS
> installer supports it). There is still the open question of how to
> have the smart-proxy listen on http and https, but I'm sure we can
> solve that.
I know, but the concept of our smart proxy is a simple process in one
thread. Once we start putting things like proxying stuff there, we would
need to change from Webrick to something else (which is not a bad thing
generally).
I like the idea of rendering templates on the proxy side, on the other
hand if the user forbids internet access (or access to foreman) there
must be some reason and proxy is needed anyway. At least for rhsm. Then
this could be win-win.
> > B) Discovery. This one is slightly more difficult. Since we are booting
> > new bare metal, the server has no context. But since we are usually
> > booting from a TFTP server (from a smart proxy) and the configuration
> > is deployed by foreman, we should be able to give the context by
> > providing a kernel command line option specifying the proxy to use. And
> > we can do this in the template - we just need to create a
> > variable/function that returns proxy hostname which the template is
> > being rendered on.
> > Additional change needs to be done in the discover_host.rb script - to
> > make use of the kernel option setting proxy for HTTP ruby client.
> Something like this was implemented in the PR for (A) (see [1]). It
> already handles PXE templates (necessary for (A) to work), so that's a
> zero-effort win if we solve (A) first.
> I'm also thinking we can do this entirely in the smart-proxy, if we
> wish, since all the code (foreman, smart-proxy, and discovery image)
> is under our control. Foreman is already contacting the smart-proxy in
> order to issue the reboot command (i.e it's not a direct foreman->host
> connection) so we could extend this. It's not really any different to
> how we handle BMC communication today.
Yeah, this is definitely an option and I do not lean towards any
solution yet. Collecting some input. I'd also like to hear opinion from
Katello guys because they have experiences with Candlepin proxying.
Any bugs on that page?
> I think an HTTP proxy might be useful for the Discovered Host ->
> Foreman communication (e.g when registering itself), but again, that
> could easily be a RESTful route on the smart-proxy - even easier
> if/when we finally add plugin support to the smart-proxy.
Yeah, again if our smart-proxy scales well, then this is definitely a
way. Keep in mind proxy currently does run on all ruby platforms and
versions, including Windows. We want to keep that, so this might tighten
our hands a bit when speaking about scalability, threading, moving away
from webrick etc.
> > C) Subscription-manager. Assuming that rhsm does support HTTP CONNECT
> > method for TCP tunneling of HTTPS protocol (Squid does support that), we
> > can configure rhsm using Foreman templates similar way. The only thing
> > that needs to be done is a variable/method returning the http proxy that
> > has been set for a host in the rhsm template snippet.
> > I assume that the proxy should be only used for subscription actions,
> > the content is synced on the smart proxy anyway so there is no added
> > value of proxying the content. On the other hand, content proxying is
> > possible and might be useful for large setups (one proxy with pulp,
> > other proxies - sublans - only proxy). But since the content is
> > available mainly under https, it cannot be cached anyway (there are some
> > nasty tricks but let's skip that for now).
> This is only case I can see where using an HTTP proxy could save us a
> lot of work (because handling https is a pain). For A) we have a
> solution 95% coded, and for B) we'd have to do the same amount of work
> (roughly) for using an HTTP proxy or extending the smart-proxy.
On the other hand, the code is already in Katello, we might move it from
there to smart proxy. Why would we proxy via two endpoints when we can
send directly to Candlepin? Then no Squid would be required at all.
> Overall I'm not against using Squid (or another HTTP proxy) but my concerns are:
> * Is there really only one (or maybe 1.5) use case for it?
That's why I ask here. Please community users, chip in. Would you like
this feature? What are your current pain points?
> * Keeping the smart-proxy lightweight (mine runs on a Rapsberry Pi,
> and I know it can be run on an OpenWRT router with some effort) - this
> would need to be optional. If it's a lot of work to correctly make it
> optional, perhaps we should just handle it in the smart-proxy?
This would be optional, turned off by default I guess.
> Personally I'd like to see us finish plugin support for the
> smart-proxy (Sam? :P). That would make it a lot easier to play with
> this stuff and see what works.
I am fine with any way, but what I like about the squid approach is we
just need to deploy it (new puppet module in the installer) and then to
make several tiny changes here and there in Foreman. No changes on the
smart proxy side. That looks attractive too.
Thanks for your valid points.
Later,
Lukas “lzap” Zapletal
irc: lzap #theforeman
