senetm
May 23, 2018, 10:21am
#1
By upgrading katello to 3.6 and foreman to 1.17 i get the following message:
Upgrade Step: import_product_content (this may take a while) ...
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-4.20.0/lib/sequel/database/schema_generator.rb:19: warning: constant ::Fixnum is deprecated
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-4.20.0/lib/sequel/database/schema_generator.rb:19: warning: constant ::Bignum is deprecated
/usr/share/foreman/lib/foreman.rb:8: warning: already initialized constant Foreman::UUID_REGEXP
/usr/share/foreman/lib/foreman.rb:8: warning: previous definition of UUID_REGEXP was here
/usr/share/foreman/lib/core_extensions.rb:183: warning: already initialized constant ActiveSupport::MessageEncryptor::DEFAULT_CIPHER
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/message_encryptor.rb:22: warning: previous definition of DEFAULT_CIPHER was here
/opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/appender.rb:139: warning: constant ::Fixnum is deprecated
/opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/logger.rb:295: warning: constant ::Fixnum is deprecated
The PGconn, PGresult, and PGError constants are deprecated, and will be
removed as of version 1.0.
You should use PG::Connection, PG::Result, and PG::Error instead, respectively.
Called from /opt/theforeman/tfm/root/usr/share/gems/gems/polyglot-0.3.5/lib/polyglot.rb:65:in `require'
rake aborted!
NoMethodError: undefined method `+' for nil:NilClass
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.6.0/app/lib/katello/resources/candlepin.rb:705:in `get'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.6.0/app/models/katello/content.rb:14:in `block (2 levels) in import_all'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.4/lib/active_record/relation/delegation.rb:39:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.6.0/app/models/katello/content.rb:12:in `block in import_all'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.6.0/app/models/katello/content.rb:11:in `import_all'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.6.0/lib/katello/tasks/upgrades/3.6/import_product_content.rake:8:in `block (4 levels) in <top (required)>'
/opt/rh/rh-ruby24/root/usr/share/gems/gems/rake-12.0.0/exe/rake:27:in `<top (required)>'
Tasks: TOP => katello:upgrades:3.6:import_product_content
foreman-rake katello:upgrades:3.6:import_product_content failed! Check the output for error!
Upgrade step import_product_content failed. Check logs for more information.
Dynflow Version 0.1.10
Pulp Version 1.3.0
Pulp server version 2.16.1
SSH Version 0.1.6
TFTP Version 1.17.0
Foreman 1.17
Katello 3.6
Sounds like a bug, anyone from @katello team - sound familiar?
Looks like you have a product with a nil cp_id
. You can find it with Katello::Product.where(cp_id: nil)
in the foreman-rake console
. I don’t think you should ever have products with cp_id = nil
, so you might want to make sure that product looks valid to you. Deleting the products with nil cp_id and re-running the upgrade should fix it for you.
senetm
May 25, 2018, 9:46am
#4
Thanks…that helped…but now i get another error “foreman-rake katello:upgrades:3.6:republish_file_repos failed!”???
Upgrade Step: republish_file_repos (this may take a while) ...
rake aborted!
ArgumentError: wrong number of arguments (given 4, expected 2..3)
/opt/theforeman/tfm/root/usr/share/gems/gems/runcible-2.6.0/lib/runcible/models/iso_distributor.rb:15:in `initialize'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.6.0/app/models/katello/glue/pulp/repo.rb:291:in `new'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.6.0/app/models/katello/glue/pulp/repo.rb:291:in `generate_distributors'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.6.0/app/lib/actions/pulp/repository/refresh.rb:44:in `block in update_or_associate_distributors'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/execution_plan.rb:368:in `switch_flow'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/action.rb:389:in `concurrence'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.6.0/app/lib/actions/pulp/repository/refresh.rb:41:in `update_or_associate_distributors'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.6.0/app/lib/actions/pulp/repository/refresh.rb:13:in `plan'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/action.rb:486:in `block (3 levels) in execute_plan'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/middleware/stack.rb:26:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/middleware.rb:18:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.6.0/app/lib/actions/middleware/backend_services_check.rb:23:in `plan'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/middleware/stack.rb:22:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.6.0/app/lib/actions/middleware/remote_action.rb:9:in `plan'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/middleware.rb:35:in `plan'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/middleware/world.rb:30:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/action.rb:485:in `block (2 levels) in execute_plan'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/action.rb:484:in `block in execute_plan'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/action.rb:444:in `block in with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/action.rb:444:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/action.rb:444:in `with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/action.rb:483:in `execute_plan'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/action.rb:277:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/execution_plan/steps/plan_step.rb:54:in `block in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/execution_plan/steps/abstract.rb:155:in `with_meta_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/execution_plan/steps/plan_step.rb:53:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/execution_plan.rb:270:in `block (2 levels) in plan'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/execution_plan.rb:358:in `with_planning_scope'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/execution_plan.rb:269:in `block in plan'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/middleware.rb:43:in `plan_phase'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/middleware/common/transaction.rb:16:in `block in rollback_on_error'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/database_statements.rb:235:in `block in transaction'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/transaction.rb:194:in `block in within_new_transaction'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/transaction.rb:191:in `within_new_transaction'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/database_statements.rb:235:in `transaction'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.4/lib/active_record/transactions.rb:210:in `transaction'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/transaction_adapters/active_record.rb:5:in `transaction'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/middleware/common/transaction.rb:15:in `rollback_on_error'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/middleware/common/transaction.rb:5:in `plan_phase'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/execution_plan.rb:268:in `plan'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/world.rb:174:in `block in plan'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/world.rb:172:in `tap'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/world.rb:172:in `plan'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.37/lib/dynflow/world.rb:148:in `trigger'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.11.2/lib/foreman_tasks.rb:19:in `trigger'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.11.2/lib/foreman_tasks.rb:25:in `block in trigger_task'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.11.2/lib/foreman_tasks.rb:39:in `block in rails_safe_trigger_task'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/dependencies/interlock.rb:46:in `block in permit_concurrent_loads'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/concurrency/share_lock.rb:185:in `yield_shares'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/dependencies/interlock.rb:45:in `permit_concurrent_loads'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.11.2/lib/foreman_tasks.rb:38:in `rails_safe_trigger_task'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.11.2/lib/foreman_tasks.rb:23:in `trigger_task'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.11.2/lib/foreman_tasks.rb:51:in `sync_task'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.6.0/lib/katello/tasks/upgrades/3.6/republish_file_repos.rake:10:in `block (5 levels) in <top (required)>'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.6.0/lib/katello/tasks/upgrades/3.6/republish_file_repos.rake:8:in `block (4 levels) in <top (required)>'
Tasks: TOP => katello:upgrades:3.6:republish_file_repos
Republishing file repo SLES12_3 (240)...
foreman-rake katello:upgrades:3.6:republish_file_repos failed! Check the output for error!
Upgrade step republish_file_repos failed. Check logs for more information.
senetm
May 25, 2018, 11:42am
#5
