I’m trying to add smart_proxy_ipam as smart proxy plugin
Being able to add smart_proxy_ipam as a start proxy as a feature
- foreman-3.0.0-1.el8.noarch
- foreman-proxy-3.0.0-1.el8.noarch
- candlepin-4.1.7-1.el8.noarch
- candlepin-selinux-4.1.7-1.el8.noarch
- foreman-cli-3.0.0-1.el8.noarch
- foreman-debug-3.0.0-1.el8.noarch
- foreman-dynflow-sidekiq-3.0.0-1.el8.noarch
- foreman-installer-3.0.0-1.el8.noarch
- foreman-installer-katello-3.0.0-1.el8.noarch
- foreman-postgresql-3.0.0-1.el8.noarch
- foreman-release-3.0.0-1.el8.noarch
- foreman-service-3.0.0-1.el8.noarch
- katello-4.2.0.1-1.el8.noarch
- katello-certs-tools-2.8.0-1.el8.noarch
- katello-client-bootstrap-1.7.7-1.el8.noarch
- katello-common-4.2.0.1-1.el8.noarch
- katello-debug-4.2.0.1-1.el8.noarch
- katello-default-ca-1.0-1.noarch
- katello-repos-4.2.0.1-1.el8.noarch
- katello-server-ca-1.0-1.noarch
- katello.comtec.lan-apache-1.0-1.noarch
- katello.comtec.lan-foreman-client-1.0-1.noarch
- katello.comtec.lan-foreman-proxy-1.0-1.noarch
- katello.comtec.lan-foreman-proxy-client-1.0-1.noarch
- katello.comtec.lan-puppet-client-1.0-1.noarch
- pulp-client-1.0-1.noarch
- python3-pulp-ansible-0.9.0-2.el8.noarch
- python3-pulp-certguard-1.4.0-3.el8.noarch
- python3-pulp-container-2.8.1-0.2.el8.noarch
- python3-pulp-deb-2.14.1-2.el8.noarch
- python3-pulp-file-1.8.2-2.el8.noarch
- python3-pulp-rpm-3.14.6-2.el8.noarch
- python3-pulpcore-3.14.8-2.el8.noarch
- qpid-proton-c-0.32.0-3.el8.x86_64
- rubygem-foreman-tasks-5.1.1-1.fm3_0.el8.noarch
- rubygem-foreman-tasks-core-0.3.6-1.fm2_5.el8.noarch
- rubygem-foreman_bootdisk-18.0.0-1.fm3_0.el8.noarch
- rubygem-foreman_bootdisk-doc-18.0.0-1.fm3_0.el8.noarch
- rubygem-foreman_discovery-18.0.0-1.fm3_0.el8.noarch
- rubygem-foreman_maintain-0.8.10-1.el8.noarch
- rubygem-foreman_puppet-1.0.3-1.fm3_0.el8.noarch
- rubygem-foreman_remote_execution-4.7.0-1.fm3_0.el8.noarch
- rubygem-foreman_remote_execution_core-1.4.8-1.el8.noarch
- rubygem-foreman_setup-7.0.0-3.fm2_5.el8.noarch
- rubygem-foreman_setup-doc-7.0.0-3.fm2_5.el8.noarch
- rubygem-foreman_statistics-1.2.0-1.fm3_0.el8.noarch
- rubygem-foreman_statistics-doc-1.2.0-1.fm3_0.el8.noarch
- rubygem-foreman_xen-1.0.1-2.fm2_5.el8.noarch
- rubygem-foreman_xen-doc-1.0.1-2.fm2_5.el8.noarch
- rubygem-hammer_cli-3.0.0-1.el8.noarch
- rubygem-hammer_cli_foreman-3.0.0-1.el8.noarch
- rubygem-hammer_cli_foreman_bootdisk-0.3.0-2.el8.noarch
- rubygem-hammer_cli_foreman_bootdisk-doc-0.3.0-2.el8.noarch
- rubygem-hammer_cli_foreman_discovery-1.0.2-2.fm2_5.el8.noarch
- rubygem-hammer_cli_foreman_puppet-0.0.3-1.fm3_0.el8.noarch
- rubygem-hammer_cli_foreman_remote_execution-0.2.2-1.fm3_0.el8.noarch
- rubygem-hammer_cli_foreman_tasks-0.0.16-1.fm3_0.el8.noarch
- rubygem-hammer_cli_katello-1.1.1-0.1.pre.master.20210804141838gitece0b63.el8.noarch
- rubygem-katello-4.2.0.1-1.el8.noarch
- rubygem-pulp_ansible_client-0.8.0-1.el8.noarch
- rubygem-pulp_certguard_client-1.4.0-1.el8.noarch
- rubygem-pulp_container_client-2.7.0-1.el8.noarch
- rubygem-pulp_deb_client-2.13.0-1.el8.noarch
- rubygem-pulp_file_client-1.8.1-1.el8.noarch
- rubygem-pulp_python_client-3.4.0-1.el8.noarch
- rubygem-pulp_rpm_client-3.13.3-1.el8.noarch
- rubygem-pulpcore_client-3.14.1-1.el8.noarch
- rubygem-qpid_proton-0.32.0-3.el8.x86_64
- rubygem-smart_proxy_pulp-3.1.0-1.fm2_6.el8.noarch
AlmaLinux 8.4
Usually I’m trying to install plugins using enable feature from foreman (if the plugin exists in the list) or using rpm from OS
Unfortunately not of the option is available in this case so I want to install using a gem.
Is not very clear how I should manage this, at least to me.
I successfully run the following command:
gem install smart_proxy_ipam
Successfully installed smart_proxy_ipam-0.1.4
Parsing documentation for smart_proxy_ipam-0.1.4
Done installing documentation for smart_proxy_ipam after 0 seconds
1 gem installed
I also copied the externalipam.yml and externalipam_netbox.yml files to /etc/foreman/plugins/
cat externalipam.yml
:enabled: true
:use_provider: externalipam_phpipam
What should I do next ?
The feature is not enabled in proxy features even with refresh features of proxy.
Thanks.
