Installation from RPM
 I'm trying to the latest version of Foreman via RPM, and I'm
getting the following error message:
sudo rpm -Uvh /home/hmedina/foreman-0.1.6-2.noarch.rpm
error: Failed dependencies:
rubygem(rake) >= 0.8.3 is needed by foreman-0.1.6-2.noarch
rubygem(sqlite3-ruby) is needed by foreman-0.1.6-2.noarch
But I have these GEMs installed:
*** LOCAL GEMS ***
actionmailer (2.3.5)
actionpack (2.3.5)
activerecord (2.3.5)
activeresource (2.3.5)
activesupport (2.3.5)
fastthread (1.0.7)
mysql (2.7)
net-sftp (2.0.4)
net-ssh (2.0.23)
net-ssh-gateway (1.0.1)
net-ssh-multi (1.0.1)
passenger (2.2.11)
rack (1.0.1)
rails (2.3.5)
rake (0.8.7)
rubygems-update (1.3.7)
sqlite3-ruby (1.2.5)
Are there any switches to the command that I'm missing? I'm running
CentOS 5.5, ruby 1.8.6 and gem 1.3.7.
Thanks in advance,
Henry
> Hello,
> *** LOCAL GEMS ***
> actionpack (2.3.5)
> fastthread (1.0.7)
> mysql (2.7)
> net-sftp (2.0.4)
> net-ssh (2.0.23)
> passenger (2.2.11)
> rack (1.0.1)
> rails (2.3.5)
> rake (0.8.7)
> Thanks in advance,
> Henry
Hey Henry,
It's complaining about RPM dependencies, so installing via 'gem' won't
resolve them. You probably want to configure your system to use EPEL:
http://fedoraproject.org/wiki/EPEL to install the correct rpms.
Both of those gems are packaged as rpms for EL5 in EPEL (rubygem-rake
& rubygem-sqlite3-ruby)
-Justin
··· On Wed, Dec 8, 2010 at 7:33 PM, CraftyTech wrote:
To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com.
For more options, visit this group at http://groups.google.com/group/foreman-users?hl=en.
It works !! Thanks…
··· On Dec 8, 7:38 pm, Justin Sherrill wrote: > On Wed, Dec 8, 2010 at 7:33 PM, CraftyTech wrote: > > Hello, > > > I'm trying to the latest version of Foreman via RPM, and I'm > > getting the following error message: > > > sudo rpm -Uvh /home/hmedina/foreman-0.1.6-2.noarch.rpm > > error: Failed dependencies: > > rubygem(rake) >= 0.8.3 is needed by foreman-0.1.6-2.noarch > > rubygem(sqlite3-ruby) is needed by foreman-0.1.6-2.noarch > > > But I have these GEMs installed: > > > *** LOCAL GEMS *** > > > actionmailer (2.3.5) > > actionpack (2.3.5) > > activerecord (2.3.5) > > activeresource (2.3.5) > > activesupport (2.3.5) > > fastthread (1.0.7) > > mysql (2.7) > > net-sftp (2.0.4) > > net-ssh (2.0.23) > > net-ssh-gateway (1.0.1) > > net-ssh-multi (1.0.1) > > passenger (2.2.11) > > rack (1.0.1) > > rails (2.3.5) > > rake (0.8.7) > > rubygems-update (1.3.7) > > sqlite3-ruby (1.2.5) > > > Are there any switches to the command that I'm missing? I'm running > > CentOS 5.5, ruby 1.8.6 and gem 1.3.7. > > > Thanks in advance, > > > Henry > > Hey Henry, > > It's complaining about RPM dependencies, so installing via 'gem' won't > resolve them. You probably want to configure your system to use EPEL:http://fedoraproject.org/wiki/EPELto install the correct rpms. > > Both of those gems are packaged as rpms for EL5 in EPEL (rubygem-rake > & rubygem-sqlite3-ruby) > > -Justin > > > > > > > > > > > -- > > You received this message because you are subscribed to the Google Groups "Foreman users" group. > > To post to this group, send email to foreman-users@googlegroups.com. > > To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com. > > For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en.
