My Fault, the doc is not very clear. I would change it to
/path/downloaded-installer-from-git-folder (or something like it)
Thanks so far!
Op dinsdag 18 december 2012 15:58:46 UTC+1 schreef yamaka...@gmail.com het volgende:
> I "had" a decent install of oVirt on my system and wanted to install
> Foreman with it.
> Because my install is running on CentOS, and I wanted to try The Foreman
> and am a Ubuntu user most of the time, I would like to use a script that
> installs all needed packages, like Ubuntu/Debian does but it's own.
> I found the following script that doesn't work that good anymore and
> removes the oVirt installation:
> http://www.uncompiled.com/centos-6-puppet-27-mcollective-foreman-rabbit
> The forman repo was kinda simple to fix, but at the end I get a lot of
> errors.
> It would be nice to have some script that install the right packages on
> CentOS.
> Does someone have something available ?
> Cheers,
> Matt
