The installer didn't install all needed modules on centos, for an example
the httpd-devel for the PassengerAppRoot was not installed, mod_ssl.
At the moment I can start Apache Succesfull but am not able to visit the
forman.
Or is it better to seperate the Ovirt manager and The Foreman ?
Cheers,
Matt
Op dinsdag 18 december 2012 15:58:46 UTC+1 schreef yamaka...@gmail.com het volgende:
> I "had" a decent install of oVirt on my system and wanted to install
> Foreman with it.
> Because my install is running on CentOS, and I wanted to try The Foreman
> and am a Ubuntu user most of the time, I would like to use a script that
> installs all needed packages, like Ubuntu/Debian does but it's own.
> I found the following script that doesn't work that good anymore and
> removes the oVirt installation:
> http://www.uncompiled.com/centos-6-puppet-27-mcollective-foreman-rabbit
> The forman repo was kinda simple to fix, but at the end I get a lot of
> errors.
> It would be nice to have some script that install the right packages on
> CentOS.
> Does someone have something available ?
> Cheers,
> Matt
> I'm still having some issues.
Why do you need httpd-devel? (not required for foreman)
Ohad
forman.
Cheers,
Matt
Op dinsdag 18 december 2012 15:58:46 UTC+1 schreef yamaka…@gmail.comhet volgende:
I “had” a decent install of oVirt on my system and wanted to install
Foreman with it.
installs all needed packages, like Ubuntu/Debian does but it’s own.
I found the following script that doesn’t work that good anymore and
Op woensdag 19 december 2012 10:52:35 UTC+1 schreef ohad het volgende:
> Thanks,
> Ohad
>> forman.
>> Cheers,
>> Matt
>> Op dinsdag 18 december 2012 15:58:46 UTC+1 schreef yamaka...@gmail.comhet volgende:
>>> Foreman with it.
>>> http://www.uncompiled.com/**centos-6-puppet-27-**
>>> errors.
>>> CentOS.
>>> Cheers,
>>> Matt
>> "Foreman users" group.
>> To view this discussion on the web visit
>> https://groups.google.com/d/msg/foreman-users/-/XPj863mq6wEJ.
>> To unsubscribe from this group, send email to
>> foreman-user...@googlegroups.com .
>> For more options, visit this group at
>> http://groups.google.com/group/foreman-users?hl=en.
I didn't see it also on my first install which was on an Ubuntu box.
What is best, to have oVirt and Foreman on the same box ?
Op woensdag 19 december 2012 13:15:17 UTC+1 schreef ohad het volgende:
> On Wed, Dec 19, 2012 at 2:00 PM, <yamaka...@gmail.com >wrote:
>> Because PassengerAppRoot seems to depend on it.
>> thats not true, if you use the installer then it should install passenger
> as a package, which would not require any devel package....
> double check your installation...
> Ohad
