I am a new user to Foreman and Puppet and currently I am configuring it. I
want to do KVM based VM installation via Foreman using Libvirt. I wanted to
know whether it's possible to Run the foreman server in a VM and do these
things. If yes, how?
I have already refered the link
http://theforeman.org/projects/foreman/wiki/Virtual_Machine_Provisioning
Thanks in advance.
-Chandan
Moreover, whenever I am trying to add a new hypervisor manually using the
link /hypervisors/
Its showing following error
Oops, we're sorry but something went wrong
x <http://foreman:3000/hypervisors/#> undefined local variable or
method `hash_for_new_hypervisor_path' for
#<ActionView::Base:0x2b2dca38c7f0>
If you feel this is an error with Foreman itself, please open a new issue
with Foreman ticketing system<Issues - Foreman>,
You would probably need to attach the Full
trace<http://foreman:3000/hypervisors/#>and relevant log entries.
ActionView::TemplateError
undefined local variable or method `hash_for_new_hypervisor_path' for #
app/views/hypervisors/index.html.erb:3
I am sure there is something missing in my setting may be someone can help
in in that. I words with Bengaden on IRC but I was not able to resolve the
problem.
My configuration:
Fedora 16 host machine.
Centos Guest machine KVM libvirt.
The foreman is running on a Centos 5.7 VM and I am trying to install a new
VM on the host machine (F16) using the foreman. Not sure whether such
configuration works. If does not let me know in case I need to run both
hypervisor and foreman both on Real hard ware machine.
Moreover, I am able to connect to the remote hypervisor using
qemu+tcp://foreman/.
Thanks
Chandan
know whether it’s possible to Run the foreman server in a VM and do these
Virtual Machine Provisioning - Foreman
Thanks in advance.
-Chandan
"Foreman users" group.
To view this discussion on the web visit
https://groups.google.com/d/msg/foreman-users/-/pf35lL8SzHgJ.
> link /hypervisors/
> method hash_for_new_hypervisor_path' for > #<ActionView::Base:0x2b2dca38c7f0> > > If you feel this is an error with Foreman itself, please open a new issue > with Foreman ticketing system<http://theforeman.org/projects/foreman/issues>, > You would probably need to attach the Full trace<http://foreman:3000/hypervisors/#>and relevant log entries. > *ActionView::TemplateError* > *undefined local variable or method
hash_for_new_hypervisor_path' for #*
> problem.
> My configuration:
> Do you have libvirt installed on the foreman host? how did you install
foreman?
kvm provisioning using libvirt works quite well, since version 0.3 or so,
in the recent development version we also support provisioning using ovirt
(see ovirt.org) if that fits your usage case betters.
Ohad
Thanks
Chandan
I want to do KVM based VM installation via Foreman using Libvirt. I wanted
to know whether it’s possible to Run the foreman server in a VM and do
these things. If yes, how?
Thanks in advance.
-Chandan
Hi Ohad,
Yes libvirt is installed in the VM where I am running foreman. I installed
foreman using YUM. I guess its your article only at how2centos. I followed
those steps to install and do initial configuration for foreman such as
importing the DB and puppet manifest files.
As of now I am able to see puppet host informations on foreman. And now to
see whether things work I wanted to install/build on VM using foreman's
webgui. So I followed the provisioning VM on the foreman wiki page.
Later I learned that I am not able to even open/create/ a new hypervisor in
my foreman installation.
Do I need to install foreman on a physical machine rather than on a VM? Let
me know if am doing anything wrong.
Thanks
Chandan
On Tue, May 1, 2012 at 1:05 AM, Ohad Levy wrote:
link /hypervisors/
Oops, we’re sorry but something went wrong
x http://foreman:3000/hypervisors/# undefined local variable or
method `hash_for_new_hypervisor_path’ for
#ActionView::Base:0x2b2dca38c7f0
with Foreman ticketing systemhttp://theforeman.org/projects/foreman/issues,
You would probably need to attach the Full tracehttp://foreman:3000/hypervisors/#and relevant log entries.
undefined local variable or method `hash_for_new_hypervisor_path’ for #
help in in that. I words with Bengaden on IRC but I was not able to resolve
the problem.
My configuration:
new VM on the host machine (F16) using the foreman. Not sure whether such
foreman?
Ohad
Thanks
Chandan
Thanks in advance.
-Chandan
Groups “Foreman users” group.
Hi Ohad,
Thanks for the help, now I am able to see the hypervisor and control
(poweroff, destroy, poweron) the guest VMs on that hypervisor. However, I
am still not able to get a fresh new host build(installed) using foreman.
Using the web inteface I did created a host and it tells the host has been
created, but I dont see any files created at my /tfttpboot directory or
anywhere that could signify and something is working.
Moreover, I have installed foreman-proxy using yum. and did the
configuration as per how2s already available on wiki and other links.
Thanks
Chandan
On Tue, May 1, 2012 at 9:23 AM, Chandan Kumar wrote:
Hi Ohad,
see whether things work I wanted to install/build on VM using foreman’s
in my foreman installation.
Let me know if am doing anything wrong.
Thanks
Chandan
the link /hypervisors/
issue with Foreman ticketing systemhttp://theforeman.org/projects/foreman/issues,
*undefined local variable or method `hash_for_new_hypervisor_path’ for #
the problem.
My configuration:
foreman?
Ohad
Thanks
Chandan
it. I want to do KVM based VM installation via Foreman using Libvirt. I
wanted to know whether it’s possible to Run the foreman server in a VM and
do these things. If yes, how?
Thanks in advance.
-Chandan
