I recently got back into foreman and puppet. I upgraded my foreman instance to 1.1 stable and the puppet infra is 2.7. I don't seem to be able to import classes and environments properly in foreman. I just get the changes not detected pop up.
puppet.conf looks like this:-
cat /etc/puppet/puppet.conf
[main]
logdir = /var/log/puppet
rundir = /var/run/puppet
ssldir = $vardir/ssl
confdir = /etc/puppet
[agent]
classfile = $vardir/classes.txt
localconfig = $vardir/localconfig
report = true
listen = true
environment = production
[master]
modulepath = $confdir/environments/$environment/modules:$confdir/modules
external_nodes = /etc/puppet/node.rb
node_terminus = exec
autosign = $confdir/autosign.conf { mode = 664 }
storeconfigs = true
dbadapter = mysql
dbuser = puppetier
dbpassword = piero
dbserver = localhost
rrddir=/var/lib/puppet/rrd
rrdinterval=$runinterval
rrdgraph=true
reports=log, foreman
[production]
manifest = /etc/puppet/environments/production/manifests/site.pp
modulepath = /etc/puppet/environments/production/modules
[dev]
manifest = /etc/puppet/dev/manifests/site.pp
modulepath = /etc/puppet/dev/modules
[root@shiba modules]#
which sort of works out ok when I query the API via curl I get the right answers
[root@shiba modules]# curl http://puppet.hq.meibin.net:8443/puppet/environments
["dev","dev","production","production"][root@shiba modules]#
though I am not sure why I get two of each. But these don't appear in the GUI. I tested this by adding a test environment and it won't appear in the GUI but in curl
["dev","production","test","production","dev"][root@shiba modules]#
Is the GUI sensitive to something or am I doing something wrong here and others have this sorted already. The puppet master is on the same host as foreman and the foreman-proxy has a proper puppet_conf directive.
Thanks
