Issue Adding Smart Proxy (foreman-proxy) to Foreman
Hello!
I am experiencing an issue when attempting to add my Puppet master (running
on the same machine as Foreman) to Foreman as a Smart Proxy.
I am entering its details as follows:
Name: Local Puppet Master
URL: https://pup-master-1.localdomain:8443
The screen then appears to refresh without any error output, and nothing is
added to the Smart Proxies list on the display. I have confirmed both that
'foreman-proxy' is running, and that the service is listening on TCP port
8443.
Here is the output from 'production.log':
Started POST "/smart_proxies" for 192.168.0.199 at 2014-09-12 15:43:05 -0400
Processing by SmartProxiesController#create as /
Parameters: {"utf8"=>"✓",
"authenticity_token"=>"hYz0GKFAk4h/tTahbKLK1sVO35AXNHbXBOAY1kF72/0=",
"smart_proxy"=>{"name"=>"Local Puppet Master",
"url"=>"https://pup-master-1.localdomain:8443"}}
Failed to save:
Rendered taxonomies/_loc_org_tabs.html.erb (0.1ms)
Rendered smart_proxies/_form.html.erb (16.5ms)
Rendered smart_proxies/new.html.erb (17.7ms)
Completed 200 OK in 168ms (Views: 20.4ms | ActiveRecord: 8.4ms)
Any assistance would be greatly appreciated.
Thanks!
– Adam
I'd suggest enabling debug logging [1] and seeing what it's complaining about.
Greg
[1] Troubleshooting - Foreman
> Hello!
(running on the same machine as Foreman) to Foreman as a Smart Proxy.
is added to the Smart Proxies list on the display. I have confirmed both
that 'foreman-proxy' is running, and that the service is listening on TCP
port 8443.
-0400
"smart_proxy"=>{"name"=>"Local Puppet Master", "url"=>"
>> Failed to save:
My guess the proxy has only features that foreman does not support, if
that's the case, can you:
  1. Configure at least one more feature on the proxy.
  2. Open a bug :slight_smile:
Thanks
Ohad
> Thanks!
> – Adam
"Foreman users" group.
··· On Sep 12, 2014 10:50 PM, "J. Adam Craig" wrote: > To post to this group, send email to foreman-users@googlegroups.com. > Visit this group at http://groups.google.com/group/foreman-users. > For more options, visit https://groups.google.com/d/optout.
Folks –
I have enabled DEBUG logging for Foreman, and received the following output
when attempting to add the local Puppet master as a Smart Proxy via the
Foreman web console.
Started POST "/smart_proxies" for ::1 at 2014-09-15 13:24:09 -0400
"authenticity_token"=>"S/2HUyYTcRHgtmiaZpTJY9rD5LYU6QznYaYSJ0X61lk=",
User Load (1.2ms) SELECT users.* FROM users WHERE users.id = 3
LIMIT 1
Setting current user thread-local variable to admin
AuthSource Load (0.5ms) SELECT auth_sources.* FROM auth_sources
WHERE auth_sources.id = 1 LIMIT 1
(0.2ms) BEGIN
SmartProxy Exists (0.4ms) SELECT 1 AS one FROM smart_proxies WHERE
smart_proxies.name = BINARY 'Local Puppet Master' LIMIT 1
SmartProxy Exists (0.3ms) SELECT 1 AS one FROM smart_proxies WHERE
smart_proxies.url = BINARY 'https://pup-master-1.localdomain:8443'
LIMIT 1
Setting Load (0.4ms) SELECT settings.* FROM settings WHERE
settings.name = 'ssl_certificate' ORDER BY name LIMIT 1
Setting Load (0.9ms) SELECT settings.* FROM settings WHERE
settings.name = 'ssl_ca_file' ORDER BY name LIMIT 1
Setting Load (0.5ms) SELECT settings.* FROM settings WHERE
settings.name = 'ssl_priv_key' ORDER BY name LIMIT 1
Feature Load (1.2ms) SELECT features.* FROM features
Feature Load (0.8ms) SELECT features.* FROM features WHERE
features.name IS NULL
(9.3ms) ROLLBACK
Failed to save:
Rendered smart_proxies/_form.html.erb (10.0ms)
Rendered smart_proxies/new.html.erb (11.0ms)
Completed 200 OK in 732ms (Views: 14.2ms | ActiveRecord: 17.6ms)
Does this necessitate a bug report, or is this operator error on my part?
I didn't have an "ah-ha!" moment while looking over the output.
Thanks!
– Adam
··· ______________________ *J. Adam Craig* UNIX & Windows Operating Systems Engineer VCU Computer Center 804.828.4886
“Don’t be a phishing victim – VCU and other reputable organizations will
never use email to request that you reply with your password, social
security number or confidential personal information. For more details,
visit http://infosecurity.vcu.edu/phishing.html
On Sat, Sep 13, 2014 at 12:53 AM, Ohad Levy ohadlevy@gmail.com wrote:
On Sep 12, 2014 10:50 PM, “J. Adam Craig” jacraig@vcu.edu wrote:
Hello!
that ‘foreman-proxy’ is running, and that the service is listening on TCP
port 8443.
Here is the output from ‘production.log’:
Started POST “/smart_proxies” for 192.168.0.199 at 2014-09-12 15:43:05
-0400
Parameters: {“utf8”=>“✓”,
“authenticity_token”=>“hYz0GKFAk4h/tTahbKLK1sVO35AXNHbXBOAY1kF72/0=”,
“smart_proxy”=>{“name”=>“Local Puppet Master”, “url”=>“
https://pup-master-1.localdomain:8443”}}
Failed to save:
that’s the case, can you:
Thanks
Ohad
Thanks!
– Adam
Groups “Foreman users” group.
an email to foreman-users+unsubscribe@googlegroups.com.
https://groups.google.com/d/topic/foreman-users/BcP3XdN-Nbo/unsubscribe.
Folks –
I see now that I have to enable the features for 'foreman-proxy' when
installing to EL from RPM packages (as opposed to using the
'foreman-installer', as I've done previously) within the
'/etc/foreman-proxy/settings.d' directory. I am enabling a few features
now, and will post back with my result.
– Adam
On Mon, Sep 15, 2014 at 1:30 PM, J. Adam Craig jacraig@vcu.edu wrote:
Folks –
output when attempting to add the local Puppet master as a Smart Proxy via
the Foreman web console.
Started POST “/smart_proxies” for ::1 at 2014-09-15 13:24:09 -0400
“authenticity_token”=>“S/2HUyYTcRHgtmiaZpTJY9rD5LYU6QznYaYSJ0X61lk=”,
LIMIT 1
(0.2ms) BEGIN
smart_proxies.name = BINARY ‘Local Puppet Master’ LIMIT 1
LIMIT 1
settings.name = ‘ssl_certificate’ ORDER BY name LIMIT 1
settings.name = ‘ssl_ca_file’ ORDER BY name LIMIT 1
settings.name = ‘ssl_priv_key’ ORDER BY name LIMIT 1
(9.3ms) ROLLBACK
Failed to save:
I didn’t have an “ah-ha!” moment while looking over the output.
Thanks!
– Adam
J. Adam Craig
VCU Computer Center
804.828.4886
Hello!
nothing is added to the Smart Proxies list on the display. I have
confirmed both that ‘foreman-proxy’ is running, and that the service is
listening on TCP port 8443.
-0400
Failed to save:
Thanks
Ohad
Thanks!
– Adam
I have succeeded in adding the Smart Proxy after enabling the Puppet,
Puppet CA, and TFTP features by editing their respective .yml files within
'/etc/foreman-proxy/settings.d', restarting the 'foreman-proxy' service,
and attempting again to add the Smart Proxy.
Thanks for your patience. Learn something (or several things) new every
day.
– Adam
On Mon, Sep 15, 2014 at 1:34 PM, J. Adam Craig jacraig@vcu.edu wrote:
Folks –
I see now that I have to enable the features for ‘foreman-proxy’ when
’foreman-installer’, as I’ve done previously) within the
’/etc/foreman-proxy/settings.d’ directory. I am enabling a few features
– Adam
J. Adam Craig
VCU Computer Center
804.828.4886
Folks –
LIMIT 1
(0.2ms) BEGIN
LIMIT 1
(9.3ms) ROLLBACK
Failed to save:
Thanks!
– Adam
J. Adam Craig
VCU Computer Center
804.828.4886
Hello!
15:43:05 -0400
Failed to save:
Thanks
Ohad
Thanks!
– Adam
