When I click the import environments in classes from Foreman it shows no changes the folders definitely have classes. When I add the folder specifically it shows up but
/etc/puppetlabs/code/environments doesn’t work for some reason.
Able to import environments from /etc/puppetlabs/code/environments
3.0.1
It used to work prior but when I checked the postgres db for the puppet classes theres no records that match the KT_environment ID.
