Hi
For some reason I can no longer use foreman-rake for anything nor does the
foreman-installer work. Please see below:
[root@localhost pxelinux.cfg]# foreman-rake db::dump
rake aborted!
Don't know how to build task 'db::dump'
[root@localhost pxelinux.cfg]# foreman-rake db::dump --trace
rake aborted!
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/task_manager.rb:62:in
[]' /opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:149:in
invoke_task'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:106:in
block (2 levels) in top_level' /opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:106:in
each'
block in top_level' /opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:115:in
run_with_threads'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:100:in
top_level' /opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:78:in
block in run'
/opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:176:in
standard_exception_handling' /opt/rh/rh-ruby22/root/usr/share/gems/gems/rake-10.4.2/lib/rake/application.rb:75:in
run'
/opt/rh/rh-ruby22/root/usr/bin/rake:33:in `<main>'
[root@localhostpxelinux.cfg]# bundle exec rake -T
Could not locate Gemfile
This is the same message when i try to do anything with foreman-rake. Can
someone please let me know how to fix?
Thanks!
