Hello –
Following an upgrade to Foreman 1.7, I am now no longer able to retrieve
values from the ENC via the node.rb file. Please see below:
sudo -u puppet /etc/puppet/node.rb <fqdn>
Error retrieving node <fqdn>: Net::HTTPInternalServerError
Check Foreman's /var/log/foreman/production.log for more information.
From '/var/log/foreman/production.log':
Started GET "/node/<fqdn>?format=yml" for <ip> at 2014-12-03 15:19:47 -0500
Processing by HostsController#externalNodes as YML
Parameters: {"name"=>"<fqdn>"}
Operation FAILED: undefined method `find_by_lower_login' for
#<Class:0x000000060705e8>
Rendered common/500.html.erb within layouts/application (6.0ms)
Rendered layouts/base.html.erb (2.2ms)
Completed 500 Internal Server Error in 17ms (Views: 10.5ms | ActiveRecord:
0.1ms)
I have updated '/etc/puppet/node.rb' as per these instructions
<Foreman :: Manual>, and
created the '/etc/puppet/foreman.yaml' file, which did not previously
exist, replacing variables with their correct values as appropriate.
Please advise. What am I missing? This is a RHEL 6.x system.
– Adam
______________________
*J. Adam Craig*
Linux & Windows Operating Systems Engineer
VCU Computer Center
804.828.4886
“Don’t be a phishing victim – VCU and other reputable organizations will
never use email to request that you reply with your password, social
security number or confidential personal information. For more details,
visit http://infosecurity.vcu.edu/phishing.html”
Please disregard. The issue was that I neglected to run the following, as
<Foreman :: Manual>:
Step 3 - Post-upgrade steps
Step 3 (A) - Database migration and cleanup
The database should be migrated already, but you can make sure by executing
the migration script again, it should produce no errors or output:
foreman-rake db:migrate
foreman-rake db:seed
You should clear the cache and the existing sessions:
foreman-rake tmp:cache:clear
foreman-rake tmp:sessions:clear
– Adam
*J. Adam Craig*
VCU Computer Center
804.828.4886
On Wed, Dec 3, 2014 at 3:25 PM, J. Adam Craig jacraig@vcu.edu wrote:
Hello –
Error retrieving node : Net::HTTPInternalServerError
Check Foreman’s /var/log/foreman/production.log for more information.
From ‘/var/log/foreman/production.log’:
Started GET “/node/?format=yml” for at 2014-12-03 15:19:47 -0500
Parameters: {“name”=>""}
Operation FAILED: undefined method `find_by_lower_login’ for
#Class:0x000000060705e8
0.1ms)
I have updated ‘/etc/puppet/node.rb’ as per these instructions
http://theforeman.org/manuals/1.7/index.html#3.5.5FactsandtheENC, and
created the ‘/etc/puppet/foreman.yaml’ file, which did not previously
– Adam
J. Adam Craig
VCU Computer Center
804.828.4886
I have a same problem while migrating off 1.5.3 to 1.7.1.
If I try to run db:migrate I get the following error (foreman-installer
gives me the same):
foreman-rake --trace db:migrate
rake aborted!
cannot load such file – apipie/middleware/checksum_in_headers
/opt/rh/ruby193/root/usr/share/rubygems/rubygems/custom_require.rb:36:in
require' /opt/rh/ruby193/root/usr/share/rubygems/rubygems/custom_require.rb:36:in
require'
/usr/share/foreman/config/application.rb:2:in <top (required)>' /opt/rh/ruby193/root/usr/share/rubygems/rubygems/custom_require.rb:36:in
require'
require' /usr/share/foreman/Rakefile:1:in
<top (required)>'
/opt/rh/ruby193/root/usr/share/ruby/rake/rake_module.rb:25:in load' /opt/rh/ruby193/root/usr/share/ruby/rake/rake_module.rb:25:in
load_rakefile'
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:501:in
raw_load_rakefile' /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:82:in
block in
load_rakefile'
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:133:in
standard_exception_handling' /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:81:in
load_rakefile'
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:65:in block in run' /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:133:in
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:63:in run' /opt/rh/ruby193/root/usr/bin/rake:32:in
<main>'
rake aborted!
rake aborted!
I must be missing some package that installer does not bring in either.
Maybe some GEM?
Anyone had and solved this problem?
Thanks!
