I am not sure if anyone is still facing this problem with Foreman or not,
but when I try to execute puppetrun from Foreman for a specific host, its
throwing Internal Server Error.
I went through some threads and some say this issue is with puppet when
running with Webrick, but not when used with passenger. So, any help will
be useful.
OS - Centos 6.6
Foreman Version -
Puppet version - 3.8.3
Using default Foreman with Passenger, getting below error when I am
executing puppetrun -
failed to execute puppetrun: ERF12-4252 [ProxyAPI::ProxyException]: Unable
to execute Puppet run ([RestClient::InternalServerError]: 500 Internal
Server Error) for proxy
On the agent node, in puppet logs, I see this -
Could not retrieve catalog from remote server: Could not intern from
text/pson: no ‘environments’ in
{:root_environment=>#<Puppet::Node::Environment:0x7f40253539c0
@name=:“root”
Note that when I run puppet agent from commandline, it works fine.
Also, puppet kick agent-hostname from master returns the following.
puppet kick --ping --host puppet-agent-1
Warning: Puppet kick is deprecated. See http://links.puppetlabs.com/puppet-kick-deprecation
Warning: Failed to load ruby LDAP library. LDAP functionality will not be
available
Triggering puppet-agent-1
Error: Host puppet-agent-1 failed: Error 400 on SERVER: no 'environments’
in {:root_environment=>#<Puppet::Node::Environment:0x7f40253539c0
@name=:“root”, @modulepath=[], @watching=true, @config_version=nil,
@manifest=:no_manifest>,
:current_environment=>#<Puppet::Node::Environment:0x7f40253539c0
@manifest=:no_manifest>} at top of [[0, nil, nil]]
There are 3 main mechanisms for performing puppet runs via foreman's gui.
Out of the 3, puppet kick is deprecated and I never got puppet-kick to work
anyway. I did get it to work using puppetssh. Here's thread that really
help me for setting this up:
The final mechanism is using mcollective. That's a bit more involved, but
if you need something quick then go for puppetssh approach.
Kind regards,
Sher
On Thursday, November 5, 2015 at 11:02:27 AM UTC, Sayan Das wrote:
> Hi,
> be useful.
> OS - Centos 6.6
> Foreman Version -
> text/pson: no 'environments' in
> {:root_environment=># @name=:"*root*"
> I have already followed these steps to setup puppetrun -
> http://projects.theforeman.org/projects/foreman/wiki/Puppetrun
> # puppet kick --ping --host puppet-agent-1
> available
> Error: Host puppet-agent-1 failed: Error 400 on SERVER: no 'environments'
> in {:root_environment=># @name=:"*root*", @modulepath=[], @watching=true, @config_version=nil,
> :current_environment=># @name=:"*root*", @modulepath=[], @watching=true, @config_version=nil,
> puppet-agent-1 finished with exit code 2
