SSH connection is correctly working :
root@srv-msc-foreman:/usr/lib/ruby/vendor_ruby# ssh -i /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy -vvvv root@10.254.251.120
OpenSSH_7.2p2 Ubuntu-4ubuntu2.4, OpenSSL 1.0.2g 1 Mar 2016
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug3: kex names ok: [diffie-hellman-group1-sha1]
debug2: resolving "10.254.251.120" port 22
debug2: ssh_connect_direct: needpriv 0
debug1: Connecting to 10.254.251.120 [10.254.251.120] port 22.
debug1: Connection established.
debug1: permanently_set_uid: 0/0
debug1: identity file /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy type 1
debug1: key_load_public: No such file or directory
debug1: identity file /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_7.2p2 Ubuntu-4ubuntu2.4
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.4
debug1: match: OpenSSH_7.4 pat OpenSSH* compat 0x04000000
debug2: fd 3 setting O_NONBLOCK
debug1: Authenticating to 10.254.251.120:22 as 'root'
debug3: hostkeys_foreach: reading file "/root/.ssh/known_hosts"
debug3: record_hostkey: found key type ECDSA in file /root/.ssh/known_hosts:2
debug3: load_hostkeys: loaded 1 keys from 10.254.251.120
debug3: order_hostkeyalgs: prefer hostkeyalgs: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521
debug3: send packet: type 20
debug1: SSH2_MSG_KEXINIT sent
debug3: receive packet: type 20
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1,ext-info-c
debug2: host key algorithms: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519-cert-v01@openssh.com,ssh-rsa-cert-v01@openssh.com,ssh-ed25519,rsa-sha2-512,rsa-sha2-256,ssh-rsa
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,aes192-cbc,aes256-cbc,3des-cbc
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,aes192-cbc,aes256-cbc,3des-cbc
debug2: MACs ctos: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: MACs stoc: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: compression ctos: none,zlib@openssh.com,zlib
debug2: compression stoc: none,zlib@openssh.com,zlib
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: host key algorithms: ssh-rsa,rsa-sha2-512,rsa-sha2-256,ecdsa-sha2-nistp256,ssh-ed25519
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,aes192-cbc,aes256-cbc,blowfish-cbc,cast128-cbc,3des-cbc
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,aes192-cbc,aes256-cbc,blowfish-cbc,cast128-cbc,3des-cbc
debug2: reserved 0
debug1: kex: algorithm: curve25519-sha256@libssh.org
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug3: send packet: type 30
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug3: receive packet: type 31
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:ZJ+QGGjzIRVolpakYRjDT7/fUYvjEy+LUaGVixJI4Oc
debug1: Host '10.254.251.120' is known and matches the ECDSA host key.
debug1: Found key in /root/.ssh/known_hosts:2
debug3: send packet: type 21
debug2: set_newkeys: mode 1
debug1: rekey after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug3: receive packet: type 21
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug2: key: /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy (0x561980447b80), explicit
debug3: send packet: type 5
debug3: receive packet: type 7
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<rsa-sha2-256,rsa-sha2-512>
debug3: receive packet: type 6
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug3: send packet: type 50
debug3: receive packet: type 51
debug1: Authentications that can continue: publickey,gssapi-keyex,gssapi-with-mic,password
debug3: start over, passed a different list publickey,gssapi-keyex,gssapi-with-mic,password
debug3: preferred gssapi-keyex,gssapi-with-mic,publickey,keyboard-interactive,password
debug3: authmethod_lookup gssapi-keyex
debug3: remaining preferred: gssapi-with-mic,publickey,keyboard-interactive,password
debug3: authmethod_is_enabled gssapi-keyex
debug1: Next authentication method: gssapi-keyex
debug1: No valid Key exchange context
debug2: we did not send a packet, disable method
debug3: authmethod_lookup gssapi-with-mic
debug3: remaining preferred: publickey,keyboard-interactive,password
debug3: authmethod_is_enabled gssapi-with-mic
debug1: Next authentication method: gssapi-with-mic
debug1: Unspecified GSS failure. Minor code may provide more information
Server not found in Kerberos database
debug2: we sent a gssapi-with-mic packet, wait for reply
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Offering RSA public key: /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy
debug3: send_pubkey_test
debug2: we sent a publickey packet, wait for reply
debug3: receive packet: type 60
debug1: Server accepts key: pkalg rsa-sha2-512 blen 279
debug2: input_userauth_pk_ok: fp SHA256:A9RDqpjHsGPyg0RIsjGJ8HbrTk3uFOJciCYNM1LtmxU
debug3: sign_and_send_pubkey: RSA SHA256:A9RDqpjHsGPyg0RIsjGJ8HbrTk3uFOJciCYNM1LtmxU
debug3: receive packet: type 52
debug1: Authentication succeeded (publickey).
Authenticated to 10.254.251.120 ([10.254.251.120]:22).
debug1: channel 0: new [client-session]
debug3: ssh_session2_open: channel_new: 0
debug2: channel 0: send open
debug3: send packet: type 90
debug1: Requesting no-more-sessions@openssh.com
debug3: send packet: type 80
debug1: Entering interactive session.
debug1: pledge: network
debug3: receive packet: type 80
debug1: client_input_global_request: rtype hostkeys-00@openssh.com want_reply 0
debug3: receive packet: type 91
debug2: callback start
debug2: fd 3 setting TCP_NODELAY
debug3: ssh_packet_set_tos: set IP_TOS 0x10
debug2: client_session2_setup: id 0
debug2: channel 0: request pty-req confirm 1
debug3: send packet: type 98
debug1: Sending environment.
debug3: Ignored env SHELL
debug3: Ignored env TERM
debug3: Ignored env USER
debug3: Ignored env LS_COLORS
debug3: Ignored env SUDO_USER
debug3: Ignored env SUDO_UID
debug3: Ignored env USERNAME
debug3: Ignored env MAIL
debug3: Ignored env PATH
debug3: Ignored env PWD
debug1: Sending env LANG = en_US.UTF-8
debug2: channel 0: request env confirm 0
debug3: Ignored env KRB5CCNAME
debug3: Ignored env SHLVL
debug3: Ignored env SUDO_COMMAND
debug3: Ignored env HOME
debug3: Ignored env LOGNAME
debug3: Ignored env LESSOPEN
debug3: Ignored env SUDO_GID
debug3: Ignored env LESSCLOSE
debug3: Ignored env OLDPWD
debug3: Ignored env _
debug2: channel 0: request shell confirm 1
debug2: callback done
debug2: channel 0: open confirm rwindow 0 rmax 32768
debug3: receive packet: type 99
debug2: channel_input_status_confirm: type 99 id 0
debug2: PTY allocation request accepted on channel 0
debug2: channel 0: rcvd adjust 2097152
debug2: shell request accepted on channel 0
Last login: Tue Sep 4 11:20:04 2018 from srv-msc-foreman.msc.so
When I try to execute the command « uname –a » on this Centos7 server through the standard « Run Command – SSH Default » Job, it results in an indefinite pending state.
On the Centos7 server, I can see that those process are running :
root 23816 20546 0 10:55 ? 00:00:00 sshd: root@notty
root 23826 23816 0 10:55 ? 00:00:00 bash -c tee '/var/tmp/foreman-ssh-cmd-86fcb648-01a4-418d-bee6-dcc04c40624a/script' && chmod '555' '/var/tmp/foreman-ssh-cmd-86fcb648-01a4-418d-bee6-dcc04c40624a/script'
root 23833 23826 0 10:55 ? 00:00:00 tee /var/tmp/foreman-ssh-cmd-86fcb648-01a4-418d-bee6-dcc04c40624a/script
the proxy log in debug mode shows this :
D, [2018-09-04T16:33:42.880661 ] DEBUG -- : accept: 10.254.251.8:43026
D, [2018-09-04T16:33:42.885550 ] DEBUG -- : Rack::Handler::WEBrick is invoked.
W, [2018-09-04T16:33:42.901499 #16447] WARN -- : Could not open DB for dynflow at '', will keep data in memory. Restart will drop all dynflow data.
[2018-09-04 16:33:42.998 #16447] INFO -- Execution plan cleaner removing 0 execution plans.
[2018-09-04 16:33:43.015 #16447] INFO -- 10.254.251.8 - - [04/Sep/2018:16:33:43 +0200] "GET /dynflow/tasks/count?state=running HTTP/1.1" 200 29 0.0063
[2018-09-04 16:33:43.058 #16447] DEBUG -- close: 10.254.251.8:43026
[2018-09-04 16:33:43.472 #16447] DEBUG -- accept: 10.254.251.8:43028
[2018-09-04 16:33:43.488 #16447] DEBUG -- Rack::Handler::WEBrick is invoked.
[2018-09-04 16:33:43.492 #16447] DEBUG -- ExecutionPlan 00122fb3-2d19-4d4b-ba51-2f9ad36476f7 pending >> planning
[2018-09-04 16:33:43.495 #16447] DEBUG -- Step 00122fb3-2d19-4d4b-ba51-2f9ad36476f7: 1 pending >> running in phase Plan ForemanRemoteExecutionCore::Actions::RunScript
[2018-09-04 16:33:43.497 #16447] DEBUG -- Step 00122fb3-2d19-4d4b-ba51-2f9ad36476f7: 4 pending >> running in phase Plan SmartProxyDynflowCore::Callback::Action
[2018-09-04 16:33:43.498 #16447] DEBUG -- Step 00122fb3-2d19-4d4b-ba51-2f9ad36476f7: 4 running >> success in phase Plan SmartProxyDynflowCore::Callback::Action
[2018-09-04 16:33:43.500 #16447] DEBUG -- Step 00122fb3-2d19-4d4b-ba51-2f9ad36476f7: 1 running >> success in phase Plan ForemanRemoteExecutionCore::Actions::RunScript
[2018-09-04 16:33:43.506 #16447] DEBUG -- ExecutionPlan 00122fb3-2d19-4d4b-ba51-2f9ad36476f7 planning >> planned
[2018-09-04 16:33:43.517 #16447] INFO -- 10.254.251.8 - - [04/Sep/2018:16:33:43 +0200] "POST /dynflow/tasks/ HTTP/1.1" 200 50 0.0274
[2018-09-04 16:33:43.526 #16447] DEBUG -- ExecutionPlan 00122fb3-2d19-4d4b-ba51-2f9ad36476f7 planned >> running
[2018-09-04 16:33:43.530 #16447] DEBUG -- Step 00122fb3-2d19-4d4b-ba51-2f9ad36476f7: 2 pending >> running in phase Run ForemanRemoteExecutionCore::Actions::RunScript
[2018-09-04 16:33:43.533 #16447] DEBUG -- Step 00122fb3-2d19-4d4b-ba51-2f9ad36476f7: 2 running >> suspended in phase Run ForemanRemoteExecutionCore::Actions::RunScript
[2018-09-04 16:33:43.534 #16447] DEBUG -- start runner 60429fd9-fbb8-4ae6-b6e0-1cc3490fed22
[2018-09-04 16:33:43.535 #16447] DEBUG -- opening session to root@10.254.251.120
[2018-09-04 16:33:43.557 #16447] DEBUG -- close: 10.254.251.8:43028
[2018-09-04 16:33:44.560 #16447] DEBUG -- Sending data to /var/tmp/foreman-ssh-cmd-60429fd9-fbb8-4ae6-b6e0-1cc3490fed22/script on remote host:
uname -a
[2018-09-04 16:33:57.980 #16447] DEBUG -- Executor heartbeat
… and so on.
As I told you, the « bash –c tee » process executed on the Centos is correctly receiving the date sent by the « ch.send_data(stdin) » command, but it waits forever for some more data, and so the « exit-status » signal is never sent back.
By adding the « ch.eof! unless stdin.nil? » just after, I can inform the process that the stdin is finished, and then everything works fine.
Regards,
Thomas Castelle
Responsable de la Direction Technique des Services Opérés
Direction des Opérations
T : +33 4 26 20 76 23 ― M : +33 6 27 27 28 57
Standard : +33 8 20 56 39 27 ― Fax : +33 4 72 43 00 67
Exaprobe
Agence de Lyon : 13 B avenue Albert Einstein - CS90217 - 69623 Villeurbanne Cedex
email : tcastelle@exaprobe.commailto:tcastelle@exaprobe.com
web : www.exaprobe.comhttp://www.exaprobe.com/ / www.econocom.comhttp://www.econocom.com/
[LOGO_EXAPROBE_BLUE_RVB_BD]
[cid:image003.gif@01CB0719.BB08BD00] Avant d’imprimer cet email, pensez à l’environnement
