Issues booting from OS Mirrors
I am using Foreman 1.8 and trying to provision a bare metal server with
Ubuntu 14.04. My Foreman server is running on CentOS 7 host.
I tried associating Ubuntu Mirror to the Operating System but when the
system boots it gives an error as below. I tied Open Suse as well and that
was giving installation media error
trying to load : pxelinux.cfg/00-80-c1-6e-23-8d-10 --> (MAC address of
the host)
could not find the kernel image: boot/ubuntu=14=x86_64-linux
Do i have to make changes in the pxelinux.cfg/00-80-c1-6e-23-8d-10 file
after it got buid ?
Now i have couple of questions
  1. Are these mirrors which was pre created with installation of foreman are
    the right one or do we have to change them.
  2. Is there a way i can create repo on my CentOS foreman server for some of
    the common OS i need for provisioning ?
  3. Is there a way to use iso for provisioning
  4. Ubuntu use amd64 but i don't see that architecture in the list when i
    create a OS
Thanks
Gagan
When I try using Open suse mirror
(http://download.opensuse.org/distribution/13.2/repo/oss/ ). The kernel
image loads and proceeds but then get stuck at "please make sure your
installation media is available" prompt as attached.
I am using AutoYAST Default and AutoYASt default PXELinux as the template.
Thanks
Gagan
I was able to install centOs without issue.
Looks like the problem is with the mirror for Ubuntu. However, in case of
OpenSuse Not sure is Template support OpenSuse 13.2.
Thanks
Gagan
Is Open Suse 13.2 is support by AutoYAst SLES default template ? The oses
list just SLES 11 and SLES 12 ?
Is there any place from where I can download latest Oses's template ? I am
not sure how much effort it takes to write my own template
Thanks
Gagan
ยทยทยท > > >
