I'm setting up my first smart proxy to begin provisioning systems, and
am having trouble adding the smart proxy to Foreman. When I attempt
to add the smart proxy with URL (hostname changed),
http://foremanproxy.domain.com:8443/features I get the following in
Foreman
2 errors prohibited this smart proxy from being saved
There were problems with the following fields:
Url did not respond to a request for its feature list.The reason given
was: 404 Resource Not Found.
Please check the proxy is configured and running on the host before
saving.
And this is in the production.log
Processing SmartProxiesController#create (for … at 2011-10-17
14:42:31) [POST]
Parameters: {“commit”=>“Save changes”,
“smart_proxy”=>{“name”=>“foremanproxy”, “url”=>“http://
foremanproxy.domain.com:8443/features”},
“authenticity_token”=>"oeCemVNXEr}
Failed to save: Url did not respond to a request for its feature
list.The reason given was: 404 Resource Not Found., Please check the
proxy is configured and runnin.
Rendering template within layouts/application
Rendering smart_proxies/new
Completed in 41ms (View: 15, DB: 110) | 200 OK [https://
foremanserver.domain.com/smart_proxies]
If I go to the URL in a browser I see the feature page.
Rails: /usr/share/foreman: symbol lookup error: /usr/lib/ruby/gems/1.8/
gems/json-1.5.3/ext/json/ext/json/ext/parser.so: undefined symbol:
RSTRING_PTR
[Mon Oct 17 14:52:57 2011] [error] [client 165.91.97.106] Premature
end of script headers: smart_proxies, referer: https://itscforeman.tamu.edu/smart_proxies
[ pid=10744 thr=47825194648384 file=ext/apache2/Hooks.cpp:822
time=2011-10-17 14:52:57.475 ]: The backend application (process
32088) did not send a valid HTTP resp.
The proxy has the foreman-proxy service started, latest stable RPM.
iptables is off and the proxy server is listening on port 8443. This
is the uncommented lines of settings.yml
:daemon: true
:daemon_pid: /var/run/foreman-proxy/foreman-proxy.pid
:port: 8443
:tftp: true
:tftproot: /var/lib/tftpboot
:dns: false
:dhcp: false
:dhcp_vendor: isc
:puppetca: true
:puppet: true
:log_file: /tmp/proxy.log
Let me know what other info may be useful.
Thanks
> Foreman
> saving.
> 14:42:31) [POST]
> Parameters: {"commit"=>"Save changes",
> "smart_proxy"=>{"name"=>"foremanproxy", "url"=>"http://
> foremanproxy.domain.com:8443/features"},
> "authenticity_token"=>"oeCemVNXEr}
> If I try using either of these URLs, http://foremanproxy.domain.com:8443/,
> or http://foremanproxy.domain.com:8443, I get a 500 error and this in
> my apache error_log
> RSTRING_PTR
I think you have two versions of the json gem installed, double check,
as one of them seems to be installed incorrectly (e.g. 32bit version
on a 64bit ruby or the other way around).
Ohad
> :daemon: true
> :port: 8443
> :tftp: true
> :dns: false
> :dhcp: false
> :dhcp_vendor: isc
> :puppetca: true
> :puppet: true
> Thanks
> - Trey
> To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com.
> For more options, visit this group at http://groups.google.com/group/foreman-users?hl=en.
That was it! I had installed json via the gem command and also had
rubygem-json installed via yum. I removed the gem of json and kept
the rpm version and now it works!
Thanks
> >http://foremanproxy.domain.com:8443/featuresI get the following in
> > Foreman
> > saving.
> > Processing SmartProxiesController#create (for .......... at 2011-10-17
> > 14:42:31) [POST]
> > If I try using either of these URLs,http://foremanproxy.domain.com:8443/,
> > orhttp://foremanproxy.domain.com:8443, I get a 500 error and this in
> > my apache error_log
> > RSTRING_PTR
> > end of script headers: smart_proxies, referer:https://itscforeman.tamu.edu/smart_proxies
> Ohad
> > :daemon: true
> > :port: 8443
> > :tftp: true
> > :dns: false
> > :dhcp: false
> > :dhcp_vendor: isc
> > :puppetca: true
> > :puppet: true
> > Thanks
> > - Trey
> > For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en.
