There are a few things with puppet-katello that I think we can fix and
make it more modular and closer to foreman / a basic foreman plugin.
Odd permissions on katello bundler file
All other bundler files are owned by root:root and since packaging is
used I think this can be changed to root:root.
Odd config file
Again this file is owned by foreman while all other configs are owned by
root:root. Here I see no reason either.
Another thing is that this has a before foreman::database and the
migrate but puppet-foreman executes the database class before placing
the config. What's the reasoning behind this?
Katello apache fragment is mostly pulp and candlepin
This sets up pulp and candlepin for which I'd propose to introduce two
separate fragments.
It also manages keepalive which IMHO belongs in puppet-foreman.
Katello config dir
Can we get rid of this?
Future
Ideally puppet-katello would be more like a profile module. We'd have a
foreman::plugin::katello that installs just the katello plugin to
Foreman. Then it also combines other modules to have a katello profile.
That means we have to move some things to other modules
(pulp::config::foreman instead of sneaking it into puppet-katello?).
> Hello all,
> # Odd permissions on katello bundler file
> https://github.com/Katello/puppet-katello/blob/
> 8b4bb6924c5911fb572bb8c19667186e56c8f71b/manifests/config.pp#L8-L13\
+1
> # Odd config file
> 8b4bb6924c5911fb572bb8c19667186e56c8f71b/manifests/config.pp#L15-L23
This is likely due to some migrations requiring some of the settings in the
config file to work properly. On the Foreman side, this would potentially
affect taxonomies? On the Katello side, this would affect some of our
migrations that unfortunately reach out to backend services. I think its a
change that if we wanted to make would need to be thoroughly tested to see
what if any impact.
> # Katello apache fragment is mostly pulp and candlepin
> 8b4bb6924c5911fb572bb8c19667186e56c8f71b/manifests/config.pp#L25-L28
> separate fragments.
We could look into splitting the fragments up. I want to say the keepalive
was due to needing it and not having a way (that would get into the code
base in time) for us to set it. This could likely be updated.
> # Future
This sounds like baking into puppet-pulp and puppet-candlepin, as examples,
knowledge of Katello and Foremanisms. We've largely tried to keep those
modules as independent modules that the community can widely use and in
which we tell them what we need altered and changed. There is currently a
decent chunk of orchestration between katello-pulp-candlepin that makes
ripping them apart harder. Thats the part that would need some thought and
re-work: what we configure and how we orchestrate. Loosening that boundary
as much as possible would help here I think.
Eric
On Tue, Aug 23, 2016 at 11:02 AM, Ewoud Kohl van Wijngaarden < ewoud@kohlvanwijngaarden.nl> wrote:
> > Hello all,
> +1
> > # Odd config file
> what if any impact.
We should dive into this. Other plugins that make database changes might
have similar problems.
> > separate fragments.
It looks like puppetlabs-apache now has proper options for this. We even
have options for this in puppet-foreman[1] but they use a custom
fragment for this. That should get updated.
This means we can at least drop KeepAlive On from the template. Then we
need to decide what to do with $katello::max_keep_alive which attempts
to configure the same value as $foreman::max_keepalive_requests but have
wildly differing defaults (10000 vs 100).
> > # Future
You may be right about this. Having it in foreman::plugin::katello::pulp
and foreman::plugin::katello::candlepin might be better. A start could
be to separate them inside puppet-katello first to get a logical
separation.
On Tue, Aug 23, 2016 at 01:40:44PM -0400, Eric D Helms wrote:
> On Tue, Aug 23, 2016 at 11:02 AM, Ewoud Kohl van Wijngaarden < > ewoud@kohlvanwijngaarden.nl> wrote:
> > > separate fragments.
> > On Tue, Aug 23, 2016 at 11:02 AM, Ewoud Kohl van Wijngaarden < > > ewoud@kohlvanwijngaarden.nl> wrote:
