I been running into problem for the last week.
I have install the new Katello 2.1.
And in two or my katello installation both install have the same problem.
I have create a new Product Centos Server Linux
I create the Product after that have url to do repo discovery.
It never complete the pulp_task,
It just said state => waiting.
below that task is Listen on candlepin events {"locale"=>"en"}
The process never completes.
Below is the set that has been waiting.
4cup
12 GB ram
500GB storage.
I have create a foreman-debug for you to see.
foreman-debug-HAq0L.tar.xz
I am having the same problem in my new AWS installation Katello 2.1 doing
the same thing.
Thanks Al
Any errors in "/var/log/candlepin/error.log" or "/var/log/messages"?
Met vriendelijke groet, With kind regards,
Jorick Astrego
Netbulae Virtualization Experts
> 4cup
> 12 GB ram
> 500GB storage.
> doing the same thing.
> Thanks Al
Tel: 053 20 30 270 info@netbulae.eu Staalsteden 4-3A KvK 08198180
Fax: 053 20 30 271 www.netbulae.eu 7547 TA Enschede BTW NL821234584B01
No error in Messages but here the out from candleping/error.log
2015-02-17 19:23:21,773 [=, org=] ERROR
org.apache.qpid.client.AMQConnectionDelegate_0_10 - connection exception:
conn:62e561a7
org.apache.qpid.transport.ConnectionException: connection aborted
at org.apache.qpid.transport.Connection.closed(Connection.java:563)
~[qpid-common-0.22.jar:na]
at
org.apache.qpid.transport.network.Assembler.closed(Assembler.java:112)
at
org.apache.qpid.transport.network.InputHandler.closed(InputHandler.java:204)
at
org.apache.qpid.transport.network.security.ssl.SSLReceiver.closed(SSLReceiver.java:66)
at
org.apache.qpid.transport.network.io.IoReceiver.run(IoReceiver.java:222)
> 4cup
> 12 GB ram
> 500GB storage.
> the same thing.
> Thanks Al
Jorick,
Still not fixed at all here is the latest output.
Started at: 2015-02-23 21:39:55 UTC
Ended at: 2015-02-23 21:59:05 UTC
Real time: 1150.02s
Execution time (excluding suspended state): 8.83s
Input:
pulp_id: AIRCELL_PROD-Puppet_Labs_Rpms-pupept6_dependencies_x86_64
distributor_type_id: yum_distributor
source_pulp_id:
dependency:
remote_user: ajohnson2-58a818a8
remote_cp_user: ajohnson2
locale: en
Output:
pulp_tasks:- exception:
task_type: pulp.server.managers.repo.publish.publish
_href: /pulp/api/v2/tasks/00a33deb-6b63-4fd7-b013-ddf39aebdacb/
task_id: 00a33deb-6b63-4fd7-b013-ddf39aebdacb
tags:
- pulp:repository:AIRCELL_PROD-Puppet_Labs_Rpms-pupept6_dependencies_x86_64
- pulp:action:publish
finish_time:
start_time:
traceback:
spawned_tasks: []
progress_report: {}
queue: reserved_resource_worker-1@til-vm-swk6-11.aircell.prod.dq
state: waiting
result:
error:
_id:
$oid: 54eb9e2c9431b63575bec426
poll_attempts:
total: 91
failed: 0
below that task is Listen on candlepin events {“locale”=>“en”}
4cup
12 GB ram
500GB storage.
the same thing.
Thanks Al
I've been experiencing these too. Doing a "service tomcat6 restart"
fixes it for a while.
Caused by: org.apache.qpid.transport.TransportException: Error
connecting to broker
at
org.apache.qpid.transport.network.io.IoNetworkTransport.connect(IoNetworkTransport.java:86)
at
org.apache.qpid.transport.Connection.connect(Connection.java:232)
at
org.apache.qpid.client.AMQConnectionDelegate_0_10.makeBrokerConnection(AMQConnectionDelegate_0_10.java:221)
~[qpid-client-0.22.jar:na]
at
org.apache.qpid.client.AMQConnection.makeBrokerConnection(AMQConnection.java:619)
at
org.apache.qpid.client.AMQConnection.<init>(AMQConnection.java:398)
... 47 common frames omitted
Caused by: java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
~[na:1.7.0_75]
at
java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:339)
~[na:1.7.0_75]
at
java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
~[na:1.7.0_75]
at
java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
~[na:1.7.0_75]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
~[na:1.7.0_75]
at java.net.Socket.connect(Socket.java:579) ~[na:1.7.0_75]
at
org.apache.qpid.transport.network.io.IoNetworkTransport.connect(IoNetworkTransport.java:82)
... 51 common frames omitted
2015-02-19 12:54:26,477 [=, org=] ERROR
exception: conn:63d8fdbe
at
at
at
at
at
at java.lang.Thread.run(Thread.java:745) [na:1.7.0_75]
> exception: conn:62e561a7
> at
> at
> at
> at
> at
> problem.
> 4cup
> 12 GB ram
> 500GB storage.
> 2.1 doing the same thing.
> Thanks Al
> You received this message because you are subscribed to the Google
> Groups "Foreman users" group.
> To unsubscribe from this group and stop receiving emails from it, send
> an email to foreman-users+unsubscribe@googlegroups.com
> To post to this group, send email to foreman-users@googlegroups.com
> Visit this group at http://groups.google.com/group/foreman-users.
Jorick Astrego
> Jorick,
Alvin,
If you do a katello-service restart and then go into the dynflow console
and resume the task does it go any further?
It looks like the pulp tasks are getting stuck for some reason.
-Justin
On 02/23/2015 04:59 PM, Alvin Johnson wrote:
> *Started at:* 2015-02-23 21:39:55 UTC
> *Ended at:* 2015-02-23 21:59:05 UTC
> *Real time:* 1150.02s
> *Execution time (excluding suspended state):* 8.83s
> *Input:*
> source_pulp_id:
> dependency:
> locale: en
> *Output:*
> pulp_tasks:
> - exception:
> tags:
> finish_time:
> start_time:
> traceback:
> spawned_tasks: []
> progress_report: {}
> state: waiting
> result:
> error:
> _id:
> poll_attempts:
> total: 91
> failed: 0
> problem.
> 4cup
> 12 GB ram
> 500GB storage.
> Thanks Al
Mmm, I don't know.
I had some problems before because of heavy diskIO lots of tasks got hung.
Had to skip them using https://<hostname>/foreman_tasks/dynflow/ to get
things going again.
But it became pretty unusable. We upgraded to SSD storage because of
this and now all tasks finish fine.
Could you check iowait while running the task?
Regards,
Jorick
On 02/23/2015 10:59 PM, Alvin Johnson wrote:
> Jorick,
> *Input:*
> source_pulp_id:
> dependency:
> locale: en
> *Output:*
> pulp_tasks:
> - exception:
> tags:
> finish_time:
> start_time:
> traceback:
> spawned_tasks: []
> progress_report: {}
> state: waiting
> result:
> error:
> _id:
> poll_attempts:
> total: 91
> failed: 0
> problem.
> 4cup
> 12 GB ram
> 500GB storage.
> Thanks Al
Jorick Astrego
Spoke to soon, there are some NodeMetadataGenerate tasks stuck and a lot
of ListenOnCandlepinEvents.
Id Action State
<https://deployen.netbulae.mgmt/foreman_tasks/dynflow/?order_by=state&desc>
Result
<https://deployen.netbulae.mgmt/foreman_tasks/dynflow/?order_by=result&desc>
▼ Started at
<https://deployen.netbulae.mgmt/foreman_tasks/dynflow/?order_by=started_at&desc>
fb585fd1-6c7a-41b1-a2ea-37dbaa87354b
Actions::Candlepin::ListenOnCandlepinEvents paused error
2015-02-24 11:28:32 UTC Show
<https://deployen.netbulae.mgmt/foreman_tasks/dynflow/fb585fd1-6c7a-41b1-a2ea-37dbaa87354b>
60cbdd6a-85b1-45fe-922a-517a17a3749d
Actions::Katello::ContentView::NodeMetadataGenerate paused error
2015-02-23 14:45:12 UTC Show
<https://deployen.netbulae.mgmt/foreman_tasks/dynflow/60cbdd6a-85b1-45fe-922a-517a17a3749d>
9b07b149-65fb-4b10-9cea-34e4db47aa4e
2015-02-23 12:48:47 UTC Show
<https://deployen.netbulae.mgmt/foreman_tasks/dynflow/9b07b149-65fb-4b10-9cea-34e4db47aa4e>
90cda926-1709-4cec-be4f-de295cc4ecd5
2015-02-23 12:41:30 UTC Show
<https://deployen.netbulae.mgmt/foreman_tasks/dynflow/90cda926-1709-4cec-be4f-de295cc4ecd5>
286c4448-a6a8-4f3d-b7ec-a6e7907541e6
2015-02-23 12:09:16 UTC Show
<https://deployen.netbulae.mgmt/foreman_tasks/dynflow/286c4448-a6a8-4f3d-b7ec-a6e7907541e6>
7e7910a5-73be-4af2-9917-3dc86e0f6e04
2015-02-23 10:57:04 UTC Show
<https://deployen.netbulae.mgmt/foreman_tasks/dynflow/7e7910a5-73be-4af2-9917-3dc86e0f6e04>
e5bc368b-54bd-4967-b492-14c0c520fbc7
2015-02-23 09:12:36 UTC Show
<https://deployen.netbulae.mgmt/foreman_tasks/dynflow/e5bc368b-54bd-4967-b492-14c0c520fbc7>
fae1e798-092e-413b-9b60-5235b58c0dbb
2015-02-20 12:20:47 UTC Show
<https://deployen.netbulae.mgmt/foreman_tasks/dynflow/fae1e798-092e-413b-9b60-5235b58c0dbb>
56eb3a58-1618-4662-986a-b3feccd081c5
2015-02-18 14:55:59 UTC Show
<https://deployen.netbulae.mgmt/foreman_tasks/dynflow/56eb3a58-1618-4662-986a-b3feccd081c5>
edb30ad5-bb10-427d-8aad-a9b87d346726
2015-02-18 12:50:04 UTC Show
<https://deployen.netbulae.mgmt/foreman_tasks/dynflow/edb30ad5-bb10-427d-8aad-a9b87d346726>
I'm thinking of dowgrading to Katello 2.0 and foreman 1.6, the latest
versions are giving me a headache
On 02/24/2015 02:15 PM, Jorick Astrego wrote:
> Mmm, I don't know.
> Had to skip them using https:///foreman_tasks/dynflow/ to
> get things going again.
> Regards,
> Jorick
>> Jorick,
>> *Input:*
>> source_pulp_id:
>> dependency:
>> locale: en
>> *Output:*
>> pulp_tasks:
>> - exception:
>> tags:
>> finish_time:
>> start_time:
>> traceback:
>> spawned_tasks: []
>> progress_report: {}
>> state: waiting
>> result:
>> error:
>> _id:
>> poll_attempts:
>> total: 91
>> failed: 0
>> On Thursday, February 19, 2015 at 12:18:27 PM UTC-6, Alvin Johnson >> wrote:
>> problem.
>> 4cup
>> 12 GB ram
>> 500GB storage.
>> Thanks Al
>> send an email to foreman-users+unsubscribe@googlegroups.com
> Jorick Astrego*
> Netbulae Virtualization Experts *
Jorick Astrego
> lot of ListenOnCandlepinEvents.
> Id Action State
> Result
> ▼ Started at
> error 2015-02-23 14:45:12 UTC Show
> error 2015-02-23 10:57:04 UTC Show
Hey Jorick
Are there any errors under the Node metadata generate tasks?
We're tracking an issue related with the ListenOnCandlepin
http://projects.theforeman.org/issues/9068
-Justin
Mmm, I don’t know.
hung.
Regards,
Jorick
Jorick,
Real time: 1150.02s
Input:
source_pulp_id:
dependency:
locale: en
Output:
pulp_tasks:
- exception:
tags:
finish_time:
start_time:
traceback:
spawned_tasks: []
progress_report: {}
state: waiting
result:
error:
_id:
poll_attempts:
total: 91
failed: 0
On Thursday, February 19, 2015 at 12:18:27 PM UTC-6, Alvin Johnson >>> wrote:
problem.
4cup
12 GB ram
500GB storage.
Thanks Al
Groups “Foreman users” group.
Jorick Astrego*
NL821234584B01
Jorick Astrego*
