/usr/lib/ruby/gems/1.8/gems/locale-2.0.5/lib/locale/taglist.rb:94:in to_simple': undefined methodto_simple' for nil:NilClass (NoMethodError)
from
/usr/lib/ruby/gems/1.8/gems/hammer_cli-0.1.3/lib/hammer_cli/i18n.rb:115:in locale' from /usr/lib/ruby/gems/1.8/gems/hammer_cli-0.1.3/lib/hammer_cli/i18n.rb:147 from /usr/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:31:ingem_original_require'
from /usr/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:31:in require' from /usr/lib/ruby/gems/1.8/gems/hammer_cli-0.1.3/bin/hammer:9 from /usr/bin/hammer:19:inload'
This appears to be an issue with attempting to determine the language on
the system. Hammer is using the locale library to determine the current
locale of the machine that hammer is being run on. Can you check the values
of:
$LANGUAGE
$LANG
$LC_ALL
$LC_CTYPE
Eric
On Thu, Apr 16, 2015 at 3:06 AM, JC wrote:
Fresh 2.2 install the same. Issue #10154 reported.
On Thursday, 19 March 2015 10:26:58 UTC, JC wrote:
/usr/lib/ruby/gems/1.8/gems/locale-2.0.5/lib/locale/taglist.rb:94:in to_simple': undefined methodto_simple’ for nil:NilClass (NoMethodError)
from /usr/lib/ruby/gems/1.8/gems/hammer_cli-0.1.3/lib/hammer_cli/i18n.rb:115:in locale' from /usr/lib/ruby/gems/1.8/gems/hammer_cli-0.1.3/lib/hammer_ cli/i18n.rb:147 from /usr/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:31:ingem_original_require’
from /usr/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:31:in require' from /usr/lib/ruby/gems/1.8/gems/hammer_cli-0.1.3/bin/hammer:9 from /usr/bin/hammer:19:inload’
> on the system. Hammer is using the locale library to determine the
> current locale of the machine that hammer is being run on. Can you
> check the values of:
> $LANGUAGE
> $LANG
> $LC_ALL
> $LC_CTYPE
> Eric
Where should the > 2.0.5 version (as an rpm) be sourced from? It is not
provided in the CentOS/RHEL/EPEL/Katello/Foreman repos.
> > $LANGUAGE
> > $LANG
> > $LC_ALL
> > $LC_CTYPE
> > Eric
> For a record: rubygem locale < 2.0.6 is not compatible with Hammer. PRs
> to Hammer [1] and packaging [2] were sent.
> [1] https://github.com/theforeman/hammer-cli/pull/168
> [2] https://github.com/theforeman/foreman-packaging/pull/625
$LANGUAGE
$LANG
$LC_ALL
$LC_CTYPE
Eric
$LANGUAGE
$LANG
$LC_ALL
$LC_CTYPE
Eric
