I just successfully installed katello 2.2 using katello-installer and was
surprised to find that the underlying Foreman is 1.9.0-develop. Is this
accurate? Is there a way to put it on a released version of Foreman?
Sounds like you installed nightly and not the official 2.2 release. What
does yum repolist show?
Eric
On Tue, May 19, 2015 at 3:19 PM, lawre wrote:I just successfully installed katello 2.2 using katello-installer and was
accurate? Is there a way to put it on a released version of Foreman?–
"Foreman users" group.
I followed the instructions
here: http://www.katello.org/docs/installation/index.html
These are the commands I ran to install the repos (as stated in the above
installation instructions):
yum -y localinstall http://fedorapeople.org/groups/katello/releases/yum/nightly/katello/RHEL/7Server/x86_64/katello-repos-latest.rpm
yum -y localinstall http://yum.theforeman.org/nightly/el7/x86_64/foreman-release.rpm
yum -y localinstall http://yum.puppetlabs.com/puppetlabs-release-el-7.noarch.rpm
yum -y localinstall http://dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm
yum -y install foreman-release-scl
It appears the default installation instructions are for the nightly, not
2.2.
On Tuesday, May 19, 2015 at 2:29:43 PM UTC-5, Eric Helms wrote: > > Sounds like you installed nightly and not the official 2.2 release. What > does yum repolist show? > >> >> >Depends how you got to that installation link whether the default
instructions are for nightly. Under "documentation" there is a drop down
whether the top select is 2.2 which is what you want in this case.
Eric
On Tue, May 19, 2015 at 4:14 PM, lawre wrote:I followed the instructions here:
http://www.katello.org/docs/installation/index.htmlThese are the commands I ran to install the repos (as stated in the above
installation instructions):yum -y localinstall http://fedorapeople.org/groups/katello/releases/yum/nightly/katello/RHEL/7Server/x86_64/katello-repos-latest.rpm
yum -y install foreman-release-sclIt appears the default installation instructions are for the nightly, not
does yum repolist show?–
ok, thanks
