I´m not able to create a docker container with Katello GUI/CLI, Im getting
the below error by pressing the submit button.
This Problem is only when using a Katello Installation, a Standalone
Foreman Installation is working perfectly with Docker Provisioning…
2015-04-04 12:40:39 [W] Operation FAILED: undefined method `katello?' for
#<Container:0x007f441d4860d0>
2015-04-04 12:40:39 [I] Completed 500 Internal Server Error in 559ms
(Views: 55.4ms | ActiveRecord: 147.3ms
Please be so kind and let me know if this is a known issue, if a workaround
is available or if I should open a ticket for it, below the log details…
2015-04-04 12:39:42 [I] Processing by ContainersController#new as HTML
2015-04-04 12:39:42 [I] Redirected to https:
//sandbox.cesystems.at/wizard_states/1/steps/preliminary
2015-04-04 12:39:42 [I] Completed 302 Found in 163ms (ActiveRecord: 129.8ms)
2015-04-04 12:39:42 [I] Processing by Containers::StepsController#show as
HTML
2015-04-04 12:39:42 [I] Parameters: {"wizard_state_id"=>"1", "id"=>
"preliminary"}
2015-04-04 12:39:43 [I] Rendered taxonomies/_loc_org_tabs.html.erb (20.1ms
2015-04-04 12:39:43 [I] Rendered /opt/rh/ruby193/root/usr/share/gems/gems/
foreman_docker-1.2.4/app/views/containers/steps/_form_buttons.html.erb (
2.4ms)
foreman_docker-1.2.4/app/views/containers/steps/_title.html.erb (41.1ms)
foreman_docker-1.2.4/app/views/containers/steps/preliminary.html.erb within
layouts/application (44.3ms)
2015-04-04 12:39:43 [I] Rendered home/_user_dropdown.html.erb (1.7ms)
2015-04-04 12:39:43 [I] Read fragment views/tabs_and_title_records-3 (0.2ms)
2015-04-04 12:39:43 [I] Rendered home/_topbar.html.erb (3.0ms)
2015-04-04 12:39:43 [I] Rendered layouts/base.html.erb (4.5ms)
2015-04-04 12:39:43 [I] Completed 200 OK in 590ms (Views: 58.9ms |
ActiveRecord: 12.7ms)
2015-04-04 12:39:43 [I] Processing by ContainersController#new as HTML
2015-04-04 12:39:43 [I] Redirected to https:
//sandbox.cesystems.at/wizard_states/2/steps/preliminary
2015-04-04 12:39:43 [I] Completed 302 Found in 20ms (ActiveRecord: 6.2ms)
2015-04-04 12:39:43 [I] Processing by Containers::StepsController#show as
HTML
2015-04-04 12:39:43 [I] Parameters: {"wizard_state_id"=>"2", "id"=>
"preliminary"}
2015-04-04 12:39:43 [I] Rendered taxonomies/_loc_org_tabs.html.erb (14.0ms
1.7ms)
foreman_docker-1.2.4/app/views/containers/steps/_title.html.erb (32.7ms)
layouts/application (34.0ms)
2015-04-04 12:39:43 [I] Rendered home/_user_dropdown.html.erb (2.0ms)
2015-04-04 12:39:43 [I] Rendered home/_topbar.html.erb (3.2ms)
2015-04-04 12:39:43 [I] Rendered layouts/base.html.erb (4.7ms)
2015-04-04 12:39:43 [I] Completed 200 OK in 73ms (Views: 39.9ms |
ActiveRecord: 13.2ms)
2015-04-04 12:39:45 [I] Processing by Containers::StepsController#update as
HTML
2015-04-04 12:39:45 [I] Parameters: {"utf8"=>"?", "authenticity_token"=>
"9QrsKruDtz+/2YVyBquTsWOfYuQKbyV5H3b2Z+5lV5Y=",
"docker_container_wizard_states_preliminary"=>{"compute_resource_id"=>"1",
"location_ids"=>[""], "organization_ids"=>["", "1"]}, "wizard_state_id"=>"2"
, "id"=>"preliminary"}
2015-04-04 12:39:45 [I] Redirected to https:
//sandbox.cesystems.at/wizard_states/2/steps/image
2015-04-04 12:39:45 [I] Completed 302 Found in 74ms (ActiveRecord: 43.2ms)
2015-04-04 12:39:45 [I] Processing by Containers::StepsController#show as
HTML
2015-04-04 12:39:45 [I] Parameters: {"wizard_state_id"=>"2", "id"=>"image"
2015-04-04 12:39:48 [I] Rendered /opt/rh/ruby193/root/usr/share/gems/gems/
katello-2.2.0/app/views/foreman_docker/containers/steps/_katello_container.
html.erb (2578.4ms)
1.9ms)
1.0ms)
foreman_docker-1.2.4/app/views/containers/steps/_image_hub_tab.html.erb (
21.6ms)
0.7ms)
12.2ms)
foreman_docker-1.2.4/app/views/containers/steps/_title.html.erb (2655.5ms)
foreman_docker-1.2.4/app/views/containers/steps/image.html.erb within
layouts/application (2657.8ms)
2015-04-04 12:39:48 [I] Rendered home/_user_dropdown.html.erb (1.8ms)
2015-04-04 12:39:48 [I] Read fragment views/tabs_and_title_records-3 (0.2ms)
2015-04-04 12:39:48 [I] Rendered home/_topbar.html.erb (3.6ms)
2015-04-04 12:39:48 [I] Rendered layouts/base.html.erb (9.4ms)
2015-04-04 12:39:48 [I] Completed 200 OK in 2732ms (Views: 2562.2ms |
ActiveRecord: 145.8ms)
2015-04-04 12:39:48 [I] Served asset /katello/containers/container-
ff7eedb820dc1ab1160933f4ff4f649f.css - 200 OK (0ms)
2015-04-04 12:39:53 [I] Processing by ImageSearchController#auto_complete_repository_name
as /
2015-04-04 12:39:53 [I] Parameters: {"search"=>"cirros", "registry_id"=>""
, "id"=>"1"}
2015-04-04 12:39:53 [I] Successfully decrypted field for ForemanDocker::
Docker Docker
Docker Docker
2015-04-04 12:39:53 [I] Rendered text template (0.0ms)
2015-04-04 12:39:53 [I] Completed 200 OK in 247ms (Views: 211.0ms |
2015-04-04 12:39:53 [I] Processing by ImageSearchController#auto_complete_image_tag
as JSON
, "id"=>"1"}
Docker Docker
Docker Docker
2015-04-04 12:39:53 [I] Completed 200 OK in 44ms (Views: 0.5ms |
ActiveRecord: 3.8ms)
2015-04-04 12:39:56 [I] Processing by Containers::StepsController#update as
HTML
2015-04-04 12:39:56 [I] Parameters: {"utf8"=>"?", "authenticity_token"=>
"docker_container_wizard_states_image"=>{"repository_name"=>"cirros", "tag"
=>"latest"}, "wizard_state_id"=>"2", "id"=>"image"}
2015-04-04 12:39:56 [I] Redirected to https:
//sandbox.cesystems.at/wizard_states/2/steps/configuration
2015-04-04 12:39:56 [I] Completed 302 Found in 47ms (ActiveRecord: 23.9ms)
2015-04-04 12:39:56 [I] Processing by Containers::StepsController#show as
HTML
2015-04-04 12:39:56 [I] Parameters: {"wizard_state_id"=>"2", "id"=>
"configuration"}
2015-04-04 12:39:56 [I] Rendered /opt/rh/ruby193/root/usr/share/gems/gems/
0.7ms)
foreman_docker-1.2.4/app/views/containers/steps/_title.html.erb (10.8ms)
foreman_docker-1.2.4/app/views/containers/steps/configuration.html.erb
within layouts/application (12.1ms)
2015-04-04 12:39:56 [I] Rendered home/_user_dropdown.html.erb (1.5ms)
2015-04-04 12:39:56 [I] Read fragment views/tabs_and_title_records-3 (0.2ms)
2015-04-04 12:39:56 [I] Rendered home/_topbar.html.erb (2.9ms)
2015-04-04 12:39:56 [I] Rendered layouts/base.html.erb (4.2ms)
2015-04-04 12:39:56 [I] Completed 200 OK in 80ms (Views: 49.6ms |
ActiveRecord: 5.7ms)
2015-04-04 12:40:24 [I] Processing by Containers::StepsController#update as
HTML
2015-04-04 12:40:24 [I] Parameters: {"utf8"=>"?", "authenticity_token"=>
"docker_container_wizard_states_configuration"=>{"name"=>"Test", "command"=>"/bin/ping
sandbox", "entrypoint"=>"", "cpu_set"=>"", "cpu_shares"=>"", "memory"=>""},
"wizard_state_id"=>"2", "id"=>"configuration"}
2015-04-04 12:40:24 [I] Redirected to https:
//sandbox.cesystems.at/wizard_states/2/steps/environment
2015-04-04 12:40:24 [I] Completed 302 Found in 50ms (ActiveRecord: 25.7ms)
2015-04-04 12:40:24 [I] Processing by Containers::StepsController#show as
HTML
2015-04-04 12:40:24 [I] Parameters: {"wizard_state_id"=>"2", "id"=>
"environment"}
2015-04-04 12:40:24 [I] Rendered /opt/rh/ruby193/root/usr/share/gems/gems/
foreman_docker-1.2.4/app/views/foreman_docker/common_parameters/
_environment_variable.html.erb (2.4ms)
1.2ms)
foreman_docker-1.2.4/app/views/containers/steps/_title.html.erb (78.5ms)
foreman_docker-1.2.4/app/views/containers/steps/environment.html.erb within
layouts/application (79.8ms)
2015-04-04 12:40:24 [I] Rendered home/_user_dropdown.html.erb (1.6ms)
2015-04-04 12:40:24 [I] Read fragment views/tabs_and_title_records-3 (0.2ms)
2015-04-04 12:40:24 [I] Rendered home/_topbar.html.erb (3.0ms)
2015-04-04 12:40:24 [I] Rendered layouts/base.html.erb (4.6ms)
2015-04-04 12:40:24 [I] Completed 200 OK in 155ms (Views: 95.7ms |
ActiveRecord: 36.6ms)
2015-04-04 12:40:39 [I] Processing by Containers::StepsController#update as
HTML
2015-04-04 12:40:39 [I] Parameters: {"utf8"=>"?", "authenticity_token"=>
"docker_container_wizard_states_environment"=>{"tty"=>"0", "attach_stdin"=>
"1", "attach_stdout"=>"1", "attach_stderr"=>"1"}, "wizard_state_id"=>"2",
"id"=>"environment"}
2015-04-04 12:40:39 [I] Rendered common/500.html.erb within
layouts/application (5.3ms)
2015-04-04 12:40:39 [I] Rendered layouts/base.html.erb (1.4ms)
(Views: 55.4ms | ActiveRecord: 147.3ms)
