[katello 2.4] Problem promoting a composite content view
I built a composite view some times ago. It's composed by 5 other CVs,
totaling 9 repositories. When i create a new version or promote do a
lifecycle environment i keep getting errors when promoting.
For example, in the last job i run i get this:
404 Resource Not Found
Runtime Error null at org.candlepin.model.AbstractHibernateCurator.delete:326
I know that if i click resume, the task continues and the promotion finishes. I'm not sure about the consistency of the published CV.
Can someone explain me better what are these errors and check if the CV is correctly generated? Additionally, does these errors can be reduced or removed making some cleanup activities?
The task on Error tab reports the following:
Action:
Actions::Pulp::Repository::CopyYumMetadataFile
Input:
{"source_pulp_id"=>
"org-Server_RH5_64bit-20_0-VMWare_Tools-vmtools_rhel5_64bit",
"target_pulp_id"=>
"org-Sviluppo-Server_RH5_64bit-VMWare_Tools-vmtools_rhel5_64bit",
"clauses"=>nil,
"remote_user"=>"admin",
"remote_cp_user"=>"admin",
"locale"=>"en-GB"}
Output:
Exception:
RestClient::ResourceNotFound: 404 Resource Not Found
Backtrace:
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/abstract_response.rb:48:in return!' /opt/theforeman/tfm/root/usr/share/gems/gems/runcible-1.3.5/lib/runcible/base.rb:92:inblock in get_response'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:228:in call' /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:228:inprocess_result'
/opt/theforeman/tfm/root/usr/share/gems/gems/rbovirt-0.0.35/lib/restclient_ext/request.rb:50:in block in transmit' /opt/rh/ruby193/root/usr/share/ruby/net/http.rb:746:instart'
/opt/theforeman/tfm/root/usr/share/gems/gems/rbovirt-0.0.35/lib/restclient_ext/request.rb:44:in transmit' /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:64:inexecute'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:33:in execute' /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/resource.rb:51:inget'
/opt/theforeman/tfm/root/usr/share/gems/gems/runcible-1.3.5/lib/runcible/base.rb:91:in get_response' /opt/theforeman/tfm/root/usr/share/gems/gems/runcible-1.3.5/lib/runcible/base.rb:79:incall'
/opt/theforeman/tfm/root/usr/share/gems/gems/runcible-1.3.5/lib/runcible/resources/task.rb:41:in poll' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/pulp/abstract_async_task.rb:119:inblock in get_new_tasks'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/pulp/abstract_async_task.rb:118:in map' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/pulp/abstract_async_task.rb:118:inget_new_tasks'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/pulp/abstract_async_task.rb:109:in block in external_task=' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/pulp/abstract_async_task.rb:106:ineach'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/pulp/abstract_async_task.rb:106:in external_task=' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/pulp/repository/abstract_copy_content.rb:40:inexternal_task='
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/action/polling.rb:83:in initiate_external_action' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/action/polling.rb:18:inrun'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/action/cancellable.rb:9:in run' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/pulp/abstract_async_task.rb:45:inrun'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/action.rb:506:in block (3 levels) in execute_run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/middleware/stack.rb:26:incall'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/middleware/stack.rb:26:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/middleware.rb:17:inpass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/middleware.rb:30:in run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/middleware/stack.rb:22:incall'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/middleware/remote_action.rb:16:in block in run' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/middleware/remote_action.rb:46:inblock (2 levels) in as_remote_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/katello/util/thread_session.rb:72:in pulp_config' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/middleware/remote_action.rb:32:inas_pulp_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/middleware/remote_action.rb:45:in block in as_remote_user' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/katello/util/thread_session.rb:79:incp_config'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/middleware/remote_action.rb:27:in as_cp_user' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/middleware/remote_action.rb:44:inas_remote_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/middleware/remote_action.rb:16:in run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/middleware/stack.rb:22:incall'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/action/progress.rb:30:in with_progress_calculation' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/action/progress.rb:16:inrun'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/middleware/stack.rb:22:in call' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/middleware/stack.rb:26:inpass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/middleware.rb:17:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/middleware/keep_locale.rb:11:inblock in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/middleware/keep_locale.rb:22:in with_locale' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/middleware/keep_locale.rb:11:inrun'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/middleware.rb:17:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/middleware.rb:30:inrun'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/middleware/stack.rb:22:in call' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/middleware/world.rb:30:inexecute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/action.rb:505:in block (2 levels) in execute_run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/action.rb:504:incatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/action.rb:504:in block in execute_run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/action.rb:419:incall'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/action.rb:419:in block in with_error_handling' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/action.rb:419:incatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/action.rb:419:in with_error_handling' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/action.rb:499:inexecute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/action.rb:260:in execute' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:9:inblock (2 levels) in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/execution_plan/steps/abstract.rb:155:in call' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/execution_plan/steps/abstract.rb:155:inwith_meta_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:8:in block in execute' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:22:inopen_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:7:in execute' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/executors/parallel/worker.rb:15:inblock in on_message'
/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matchers/abstract.rb:74:in block in assigns' /opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matchers/abstract.rb:73:intap'
/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matchers/abstract.rb:73:in assigns' /opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matching.rb:56:inmatch_value'
/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matching.rb:36:in block in match?' /opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matching.rb:35:ineach'
/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matching.rb:35:in match?' /opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matching.rb:23:inmatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/executors/parallel/worker.rb:12:in on_message' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/context.rb:46:inon_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/executes_context.rb:7:in on_envelope' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/abstract.rb:25:inpass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.10/lib/dynflow/actor.rb:26:in on_envelope' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/abstract.rb:25:inpass'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/awaits.rb:15:in on_envelope' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/abstract.rb:25:inpass'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/sets_results.rb:14:in on_envelope' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/abstract.rb:25:inpass'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/buffer.rb:38:in process_envelope' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/buffer.rb:31:inprocess_envelopes?'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/buffer.rb:20:in on_envelope' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/abstract.rb:25:inpass'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/termination.rb:55:in on_envelope' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/abstract.rb:25:inpass'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/removes_child.rb:10:in on_envelope' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/abstract.rb:25:inpass'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/sets_results.rb:14:in on_envelope' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/core.rb:161:inprocess_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/core.rb:95:in block in on_envelope' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/core.rb:118:inblock (2 levels) in schedule_execution'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/synchronization/mri_lockable_object.rb:62:in block in synchronize' /opt/rh/ruby193/root/usr/share/ruby/monitor.rb:211:inmon_synchronize'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/synchronization/mri_lockable_object.rb:62:in synchronize' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/core.rb:115:inblock in schedule_execution'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/serialized_execution.rb:18:in call' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/serialized_execution.rb:18:incall'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/serialized_execution.rb:96:in work' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/serialized_execution.rb:77:inblock in call_job'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/ruby_thread_pool_executor.rb:333:in call' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/ruby_thread_pool_executor.rb:333:inrun_task'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/ruby_thread_pool_executor.rb:322:in block (3 levels) in create_worker' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/ruby_thread_pool_executor.rb:305:inloop'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/ruby_thread_pool_executor.rb:305:in block (2 levels) in create_worker' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/ruby_thread_pool_executor.rb:304:incatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/ruby_thread_pool_executor.rb:304:in block in create_worker' /opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/diagnostic_context.rb:323:incall'
/opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/diagnostic_context.rb:323:in `block in create_with_logging_context'
Action:
Actions::Pulp::Repository::RemoveRpm
Input:
{"pulp_id"=>"org-Sviluppo-Server_RH5_64bit-OracleASM-OracleASM_x86_64",
"locale"=>"en-GB"}
Output:
Exception:
Backtrace:
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/pulp/abstract_async_task.rb:106:in external_task=' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/actions/pulp/repository/abstract_remove_content.rb:27:inexternal_task='
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.1/app/lib/katello/util/thread_session.rb:72:in `pulp_config'
/opt/theforeman/tf
