Some mistakes with erratas with katello 3.0 (upgraded from 2.4):
I have (at least…) 2 problems. Not sure if it is the same cause or not :
Problem 1 : Some erratas are on pulp but do not appear on Katello. These
erratas were loaded on pulp with « pulp-admin rpm repo uploads erratum … »
Example for CESA-2016:1292. I can list the update with pulp-admin, but I
can’t see the errata on WebUI
[root@lslkatp01:~] # pulp-admin -v -u admin -p mypassword rpm repo content
errata --repo-id VDL-Library-CentOS7_VDL_content_view-CentOS_7-Updates
Description: Not available
Severity: Important
Title: CentOS libxml2 Security Update
Type: security
and query with « hammer erratum list » seems to hang (or I did not find the
correct syntax…):
[root@lslkatp01:~] # hammer erratum list
[Foreman] Password for admin:
(no output after several minutes)
pulp DB and Katello DB seem to be unsynchronized. Is it possible ? How can
I re-sync them ?
*Problem 2 : *OK. The above example is affected by issue 1881 :
https://pulp.plan.io/issues/1881
