Hello everybody,
recently I've been trying to apply some changes to our Katello 3.0 setup
through foreman-installer and noticed it fails to run. The last time it
used to work was June 27th (according to
/var/log/foreman-installer/foreman.log) when I updated Katello related
packages and run foreman-installer --scenario=katello --upgrade
afterwards to make sure everything was properly updated. This was the yum
update on June 27th:
Packages Altered:
Updated NetworkManager-1:1.0.6-29.el7_2.x86_64 @updates
Update 1:1.0.6-30.el7_2.x86_64 @updates
Updated NetworkManager-libnm-1:1.0.6-29.el7_2.x86_64 @updates
Updated NetworkManager-team-1:1.0.6-29.el7_2.x86_64 @updates
Updated NetworkManager-tui-1:1.0.6-29.el7_2.x86_64 @updates
Updated device-mapper-7:1.02.107-5.el7_2.2.x86_64 @updates
Update 7:1.02.107-5.el7_2.4.x86_64 @updates
Updated device-mapper-event-7:1.02.107-5.el7_2.2.x86_64 @updates
Updated device-mapper-event-libs-7:1.02.107-5.el7_2.2.x86_64 @updates
Updated device-mapper-libs-7:1.02.107-5.el7_2.2.x86_64 @updates
Updated dracut-033-360.el7_2.x86_64 @updates
Update 033-360.el7_2.1.x86_64 @updates
Updated dracut-config-rescue-033-360.el7_2.x86_64 @updates
Updated dracut-network-033-360.el7_2.x86_64 @updates
Updated epel-release-7-6.noarch @
/epel-release-latest-7.noarch
Update 7-7.noarch @epel
Updated foreman-1.11.2-1.el7.noarch @foreman
Update 1.11.3-1.el7.noarch @foreman
Updated foreman-compute-1.11.2-1.el7.noarch @foreman
Updated foreman-debug-1.11.2-1.el7.noarch @foreman
Updated foreman-installer-1:1.11.2-1.el7.noarch @foreman
Update 1:1.11.3-1.el7.noarch @foreman
Updated foreman-installer-katello-3.0.0-10.rc8.el7.noarch @katello
Update 3.0.2-1.el7.noarch @katello
Updated foreman-postgresql-1.11.2-1.el7.noarch @foreman
Updated foreman-proxy-1.11.2-1.el7.noarch @foreman
Updated foreman-release-1.11.2-1.el7.noarch @/foreman-
release
Updated foreman-selinux-1.11.2-1.el7.noarch @foreman
Updated foreman-vmware-1.11.2-1.el7.noarch @foreman
Updated iproute-3.10.0-54.el7.x86_64 @anaconda
Update 3.10.0-54.el7_2.1.x86_64 @updates
Updated katello-3.0.0-8.rc8.el7.noarch @katello
Update 3.0.0-9.el7.noarch @katello
Updated katello-common-3.0.0-8.rc8.el7.noarch @katello
Updated katello-debug-3.0.0-8.rc8.el7.noarch @katello
Updated katello-installer-base-3.0.0-10.rc8.el7.noarch @katello
Updated katello-repos-3.0.0-2.el7.noarch @/katello-
repos-latest
Update 3.0.0-3.el7.noarch @katello
Updated katello-service-3.0.0-8.rc8.el7.noarch @katello
Install kernel-3.10.0-327.22.2.el7.x86_64 @updates
Updated kernel-tools-3.10.0-327.18.2.el7.x86_64 @updates
Update 3.10.0-327.22.2.el7.x86_64 @updates
Updated kernel-tools-libs-3.10.0-327.18.2.el7.x86_64 @updates
Updated kpartx-0.4.9-85.el7_2.4.x86_64 @updates
Update 0.4.9-85.el7_2.5.x86_64 @updates
Updated libgudev1-219-19.el7_2.9.x86_64 @updates
Update 219-19.el7_2.11.x86_64 @updates
Updated libxml2-2.9.1-6.el7_2.2.x86_64 @updates
Update 2.9.1-6.el7_2.3.x86_64 @updates
Updated libxml2-python-2.9.1-6.el7_2.2.x86_64 @updates
Updated lvm2-7:2.02.130-5.el7_2.2.x86_64 @updates
Update 7:2.02.130-5.el7_2.4.x86_64 @updates
Updated lvm2-libs-7:2.02.130-5.el7_2.2.x86_64 @updates
Updated polkit-0.112-6.el7_2.x86_64 @updates
Update 0.112-7.el7_2.x86_64 @updates
Updated python-perf-3.10.0-327.18.2.el7.x86_64 @updates
Updated rubygem-kafo-0.7.2-1.el7.noarch @foreman
Update 0.7.4-1.el7.noarch @foreman
Updated selinux-policy-3.13.1-60.el7_2.3.noarch @updates
Update 3.13.1-60.el7_2.7.noarch @updates
Updated selinux-policy-targeted-3.13.1-60.el7_2.3.noarch @updates
Updated squid-7:3.3.8-26.el7_2.3.x86_64 @updates
Update 7:3.3.8-26.el7_2.4.x86_64 @updates
Updated systemd-219-19.el7_2.9.x86_64 @updates
Updated systemd-libs-219-19.el7_2.9.x86_64 @updates
Updated systemd-sysv-219-19.el7_2.9.x86_64 @updates
Updated tfm-rubygem-dynflow-0.8.10-1.fm1_11.el7.noarch @foreman -
plugins
Update 0.8.11-1.fm1_11.el7.noarch @foreman -
plugins
Updated tfm-rubygem-foreman-tasks-0.7.17-1.fm1_11.el7.noarch @foreman -
plugins
Update 0.7.18-1.fm1_11.el7.noarch @foreman -
plugins
Updated tfm-rubygem-foreman_hooks-0.3.9-2.fm1_11.el7.noarch @foreman -
plugins
Update 0.3.11-1.fm1_11.el7.noarch @foreman -
plugins
Updated tfm-rubygem-katello-3.0.0-11.rc8.el7.noarch @katello
Update 3.0.1-1.el7.noarch @katello
Updated tfm-rubygem-runcible-1.6.0-1.el7.noarch @katello
Update 1.7.2-1.el7.noarch @katello
Updated tzdata-2016d-1.el7.noarch @updates
Update 2016e-1.el7.noarch @updates
Updated tzdata-java-2016d-1.el7.noarch @updates
Now, foreman-installer
doesn't run anymore:
foreman-installer --scenario=katello --help
/usr/share/gems/gems/kafo_parsers-0.0.6/lib/kafo_parsers/
puppet_module_parser.rb:84:in docs': no documentation found for manifest /usr/share/katello-installer-base/modules/capsule/manifests/init.pp, parsing error? (KafoParsers::DocParseError) from /usr/share/gems/gems/kafo_parsers-0.0.6/lib/kafo_parsers/puppet_module_parser.rb:19:in
parse'
from
/usr/share/gems/gems/kafo-0.7.4/lib/kafo/puppet_module.rb:54:in parse' from /usr/share/gems/gems/kafo-0.7.4/lib/kafo/configuration.rb:88:in
block
in modules'
from
/usr/share/gems/gems/kafo-0.7.4/lib/kafo/configuration.rb:88:in map' from /usr/share/gems/gems/kafo-0.7.4/lib/kafo/configuration.rb:88:in
modules'
from /usr/share/gems/gems/kafo-0.7.4/lib/kafo/configuration.rb:184:
in params' from /usr/share/gems/gems/kafo-0.7.4/lib/kafo/configuration.rb:193:in
preset_defaults_from_puppet'
from
/usr/share/gems/gems/kafo-0.7.4/lib/kafo/kafo_configure.rb:253:in
set_parameters' from /usr/share/gems/gems/kafo-0.7.4/lib/kafo/kafo_configure.rb:96: in
initialize'
from /usr/share/gems/gems/clamp-1.0.0/lib/clamp/command.rb:133:in new' from /usr/share/gems/gems/clamp-1.0.0/lib/clamp/command.rb:133:in
run'
from /usr/share/gems/gems/kafo-0.7.4/lib/kafo/kafo_configure.rb:150:
in run' from /usr/sbin/foreman-installer:12:in
<main>'
Is this a bug I should report on the issue tracker or did I screw up my
setup? Any helpful advice is appreciated, thanks for taking the time to
read this!
Marvin
ehelms
July 7, 2016, 6:28pm
#2
Please report as an issue with your traceback so that the right developers
can take a look.
On Wed, Jul 6, 2016 at 2:37 AM, Marvin Beckers wrote:
Hello everybody,
recently I’ve been trying to apply some changes to our Katello 3.0 setup
Packages Altered:
-release
-repos-latest
plugins
plugins
plugins
plugins
plugins
plugins
doesn’t run anymore:
parse’
from
/usr/share/gems/gems/kafo-0.7.4/lib/kafo/puppet_module.rb:54:in parse' from /usr/share/gems/gems/kafo-0.7.4/lib/kafo/configuration.rb:88: in
block in modules’
from
modules’
:in params' from /usr/share/gems/gems/kafo-0.7.4/lib/kafo/configuration.rb:193:in
preset_defaults_from_puppet’
from
set_parameters' from /usr/share/gems/gems/kafo-0.7.4/lib/kafo/kafo_configure.rb:96 :in
initialize’
run’
150:in run' from /usr/sbin/foreman-installer:12:in
read this!
Marvin
"Foreman users" group.
email to foreman-users+unsubscribe@googlegroups.com .
To post to this group, send email to foreman-users@googlegroups.com .
Visit this group at https://groups.google.com/group/foreman-users .
For more options, visit https://groups.google.com/d/optout .
Eric D. Helms
Red Hat Engineering
Ph.D. Student - North Carolina State University
I have created an issue, available at
Bug #15619: "no documentation found for manifest" when using parser=future - Kafo - Foreman - Thank you very much for
looking into this!
Am Donnerstag, 7. Juli 2016 20:28:57 UTC+2 schrieb Eric Helms:
> can take a look.
> On Wed, Jul 6, 2016 at 2:37 AM, Marvin Beckers > wrote:
>> Hello everybody,
>> packages and run `foreman-installer --scenario=katello --upgrade`
>> Packages Altered:
>> foreman-release
>> @anaconda
>> katello-repos-latest
>> -plugins
>> -plugins
>> -plugins
>> -plugins
>> -plugins
>> -plugins
>> Now, `foreman-installer` doesn't run anymore:
>> # foreman-installer --scenario=katello --help
>> puppet_module_parser.rb:84:in `docs': no documentation found for
>> manifest
>> from
>> `parse'
>> from
>> /usr/share/gems/gems/kafo-0.7.4/lib/kafo/puppet_module.rb:54:in `parse'
>> :in `block in modules'
>> from
>> /usr/share/gems/gems/kafo-0.7.4/lib/kafo/configuration.rb:88:in `map'
>> from
>> /usr/share/gems/gems/kafo-0.7.4/lib/kafo/configuration.rb:88:in `modules'
>> 184:in `params'
>> from
>> /usr/share/gems/gems/kafo-0.7.4/lib/kafo/configuration.rb:193:in `
>> from
>> `set_parameters'
>> 96:in `initialize'
>> `new'
>> `run'
>> 150:in `run'
>> from /usr/sbin/foreman-installer:12:in `'
>> read this!
>> Marvin
>> Visit this group at https://groups.google.com/group/foreman-users.
> Eric D. Helms
> Red Hat Engineering
