/usr/share/foreman/lib/foreman.rb:8: warning: already initialized constant Foreman::UUID_REGEXP /usr/share/foreman/lib/foreman.rb:8: warning: previous definition of UUID_REGEXP was here /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_docker-4.1.0/app/controllers/api/v2/containers_controller.rb:107: warning: constant ::Fixnum is deprecated
Application root
/usr/share/foreman
Environment (value of RAILS_ENV, RACK_ENV, WSGI_ENV and PASSENGER_ENV)
Hey @Shri, sorry you are having issues starting katello!
Can you run foreman-maintain service restart
and then run foreman-maintain service status -b and post the output here?
Also, the output from grep ERROR /var/log/foreman-installer/katello.log would be helpful too (some of it is already in the pastebin, but I want to make sure we are seeing all the errors)
even though all services are up and running , unable to open web-console.
Web application could not be started
Application root
/usr/share/foreman
@Shri What installer arguments did you use when you installed? Also, can you look for errors in /var/log/foreman-proxy/proxy.log? There may be backdated files in /var/log/foreman-proxy so check those too
