When trying to delete CV, getting error:
Katello::Errors::CandlepinError: Environment with id b4e36045f55913702b188a911d63aed8 could not be found.
and task fails.
CV to be deleted
|foreman-tasks|The goal of this plugin is to unify the way of showing task statuses across the Foreman instance. It defines Task model for keeping the information about the tasks and Lock for assigning the tasks to resources. The locking allows dealing with preventing multiple colliding tasks to be run on the same resource. It also optionally provides Dynflow infrastructure for using it for managing the tasks.|Ivan Nečas|2.0.2|
|foreman_ansible|Ansible integration with Foreman|Daniel Lobato Garcia|5.1.3|
|foreman_bootdisk|Plugin for Foreman that creates iPXE-based boot disks to provision hosts without the need for PXE infrastructure.|Dominic Cleal|17.0.2|
|foreman_discovery|MaaS Discovery Plugin engine for Foreman|Aditi Puntambekar, alongoldboim, Alon Goldboim, amirfefer, Amit Karsale, Amit Upadhye, Amos Benari, Avi Sharvit, Bryan Kearney, bshuster, Daniel Lobato, Daniel Lobato Garcia, Daniel Lobato García, Danny Smit, David Davis, Djebran Lezzoum, Dominic Cleal, Eric D. Helms, Ewoud Kohl van Wijngaarden, Frank Wall, Greg Sutcliffe, ChairmanTubeAmp, Ido Kanner, imriz, Imri Zvik, Ivan Nečas, Joseph Mitchell Magen, June Zhang, kgaikwad, Lars Berntzon, ldjebran, Leos Stejskal, Lukas Zapletal, Lukáš Zapletal, Marek Hulan, Marek Hulán, Martin Bačovský, Matt Jarvis, Michael Moll, Nick, odovzhenko, Ohad Levy, Ondrej Prazak, Ondřej Ezr, Ori Rabin, orrabin, Partha Aji, Petr Chalupa, Phirince Philip, Rahul Bajaj, Robert Antoni Buj Gelonch, Scubafloyd, Sean O\'Keeffe, Sebastian Gräßl, Shimon Shtein, Shlomi Zadok, Stephen Benjamin, Swapnil Abnave, Thomas Gelf, Timo Goebel, Tomas Strych, Tom Caspy, Tomer Brisker, and Yann Cézard|16.1.2|
|foreman_openscap|Foreman plug-in for managing security compliance reports|slukasik@redhat.com|4.0.2|
|foreman_remote_execution|A plugin bringing remote execution to the Foreman, completing the config management functionality with remote management functionality.|Foreman Remote Execution team|3.3.7|
|foreman_setup|Plugin for Foreman that helps set up provisioning.|Dominic Cleal|7.0.0|
|katello|Katello adds Content and Subscription Management to Foreman. For this it relies on Candlepin and Pulp.|N/A|3.16.1.2|
|puppetdb_foreman|Disable hosts on PuppetDB after they are deleted or built in Foreman. Follow https://github.com/theforeman/puppetdb_foreman and raise an issue/submit a pull request if you need extra functionality. You can also find some help in #theforeman IRC channel on Freenode.|Daniel Lobato Garcia|5.0.0|
CentOS Linux release 7.8.2003 (Core)
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.16.1.2/app/lib/actions/middleware/propagate_candlepin_errors.rb:21:in rescue in propagate_candlepin_errors' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.16.1.2/app/lib/actions/middleware/propagate_candlepin_errors.rb:18:in
propagate_candlepin_errors’
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.16.1.2/app/lib/actions/middleware/propagate_candlepin_errors.rb:9:in run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware/stack.rb:23:in
call’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware/stack.rb:27:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware.rb:19:in
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.16.1.2/app/lib/actions/middleware/remote_action.rb:16:in block in run' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.16.1.2/app/lib/actions/middleware/remote_action.rb:40:in
block in as_remote_user’
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.16.1.2/app/models/katello/concerns/user_extensions.rb:21:in cp_config' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.16.1.2/app/lib/actions/middleware/remote_action.rb:27:in
as_cp_user’
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.16.1.2/app/lib/actions/middleware/remote_action.rb:39:in as_remote_user' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.16.1.2/app/lib/actions/middleware/remote_action.rb:16:in
run’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware/stack.rb:23:in call' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware/stack.rb:27:in
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware.rb:19:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-2.0.2/app/lib/actions/middleware/rails_executor_wrap.rb:14:in
block in run’
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.1/lib/active_support/execution_wrapper.rb:88:in wrap' /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-2.0.2/app/lib/actions/middleware/rails_executor_wrap.rb:13:in
run’
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware.rb:19:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action/progress.rb:31:in
with_progress_calculation’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action/progress.rb:17:in run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware/stack.rb:23:in
call’
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-2.0.2/app/lib/actions/middleware/keep_current_request_id.rb:15:in block in run' /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-2.0.2/app/lib/actions/middleware/keep_current_request_id.rb:49:in
restore_current_request_id’
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-2.0.2/app/lib/actions/middleware/keep_current_request_id.rb:15:in run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware/stack.rb:23:in
call’
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-2.0.2/app/lib/actions/middleware/keep_current_timezone.rb:15:in block in run' /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-2.0.2/app/lib/actions/middleware/keep_current_timezone.rb:44:in
restore_curent_timezone’
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-2.0.2/app/lib/actions/middleware/keep_current_timezone.rb:15:in run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware/stack.rb:23:in
call’
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-2.0.2/app/lib/actions/middleware/keep_current_user.rb:15:in block in run' /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-2.0.2/app/lib/actions/middleware/keep_current_user.rb:44:in
restore_curent_user’
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-2.0.2/app/lib/actions/middleware/keep_current_user.rb:15:in run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware/stack.rb:23:in
call’
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-2.0.2/app/lib/actions/middleware/keep_current_taxonomies.rb:15:in block in run' /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-2.0.2/app/lib/actions/middleware/keep_current_taxonomies.rb:45:in
restore_current_taxonomies’
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-2.0.2/app/lib/actions/middleware/keep_current_taxonomies.rb:15:in run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware/stack.rb:23:in
call’
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware.rb:32:in run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware/stack.rb:23:in
call’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware/world.rb:31:in execute' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:570:in
block (2 levels) in execute_run’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:569:in catch' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:569:in
block in execute_run’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:472:in block in with_error_handling' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:472:in
catch’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:472:in with_error_handling' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:564:in
execute_run’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:285:in execute' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:18:in
block (2 levels) in execute’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/execution_plan/steps/abstract.rb:167:in with_meta_calculation' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:17:in
block in execute’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:32:in open_action' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:16:in
execute’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/director.rb:68:in execute' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/executors/sidekiq/worker_jobs.rb:11:in
block (2 levels) in perform’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/executors.rb:18:in run_user_code' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/executors/sidekiq/worker_jobs.rb:9:in
block in perform’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/executors/sidekiq/worker_jobs.rb:25:in with_telemetry' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/executors/sidekiq/worker_jobs.rb:8:in
perform’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/executors/sidekiq/serialization.rb:27:in perform' /opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:192:in
execute_job’
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:165:in block (2 levels) in process' /opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/middleware/chain.rb:128:in
block in invoke’
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/middleware/chain.rb:133:in invoke' /opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:164:in
block in process’
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:137:in block (6 levels) in dispatch' /opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/job_retry.rb:109:in
local’
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:136:in block (5 levels) in dispatch' /opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq.rb:37:in
block in module:Sidekiq’
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:132:in block (4 levels) in dispatch' /opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:250:in
stats’
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:127:in block (3 levels) in dispatch' /opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/job_logger.rb:8:in
call’
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:126:in block (2 levels) in dispatch' /opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/job_retry.rb:74:in
global’
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:125:in block in dispatch' /opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/logging.rb:48:in
with_context’
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/logging.rb:42:in with_job_hash_context' /opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:124:in
dispatch’
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:163:in process' /opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:83:in
process_one’
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:71:in run' /opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/util.rb:16:in
watchdog’
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/util.rb:25:in block in safe_thread' /opt/theforeman/tfm/root/usr/share/gems/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in
block in create_with_logging_context’
