Hello Team,
Im trying to setup katello 3.3 on CentOS 7, While running the final setup.
foreman-installer --scenario katello --foreman-admin-username admin --foreman-admin-password admin
Im getting the errror like below.
/Stage[main]/Qpid::Service/Service[qpidd]/ensure: change from stopped to running failed: Systemd start for qpidd failed!
journalctl log for qpidd:
– Logs begin at Thu 2017-04-20 02:49:55 UTC, end at Thu 2017-04-20 03:14:40 UTC. –
Apr 20 03:14:40 instance-5 systemd[1]: Started An AMQP message broker daemon…
Apr 20 03:14:40 instance-5 systemd[1]: Starting An AMQP message broker daemon…
Apr 20 03:14:40 instance-5 systemd[1]: qpidd.service: main process exited, code=killed, status=11/SEGV
Apr 20 03:14:40 instance-5 systemd[1]: Unit qpidd.service entered failed state.
Apr 20 03:14:40 instance-5 systemd[1]: qpidd.service failed.
Installing Done [100%] […]
Attaching the whole message.
Qpidd error.txt (5.63 KB)
