--> Processing Dependency: tfm-rubygem(hammer_cli_foreman) >= 0.14.0 for package: tfm-rubygem-hammer_cli_katello-0.14.1-1.el7.noarch
--> Finished Dependency Resolution
Error: Package: tfm-rubygem-hammer_cli_katello-0.14.1-1.el7.noarch (katello-3_8)
Requires: tfm-rubygem(hammer_cli_foreman) >= 0.14.0
Installed: tfm-rubygem-hammer_cli_foreman-0.13.1-1.el7.noarch (foreman-1_18)
tfm-rubygem(hammer_cli_foreman) = 0.13.1
Available: tfm-rubygem-hammer_cli_foreman-0.13.0-1.el7.noarch (foreman-1_18)
tfm-rubygem(hammer_cli_foreman) = 0.13.0
This is especially interesting because I’m pretty sure hammer_cli has been deprecated?
I tried using --skip-broken, but the result is unkind - too much left out, not worth upgrading atm.
Packages skipped because of dependency problems:
foreman-1.18.2-1.el7.noarch from Foreman_foreman-1_18
foreman-compute-1.18.2-1.el7.noarch from Foreman_foreman-1_18
1:foreman-installer-1.18.2-1.el7.noarch from Foreman_foreman-1_18
foreman-installer-katello-3.8.0-1.el7.noarch from Katello_katello-3_8
foreman-postgresql-1.18.2-1.el7.noarch from Foreman_foreman-1_18
foreman-proxy-1.18.2-1.el7.noarch from Foreman_foreman-1_18
foreman-selinux-1.18.2-1.el7.noarch from Foreman_foreman-1_18
katello-3.8.0-5.el7.noarch from Katello_katello-3_8
katello-common-3.8.0-5.el7.noarch from Katello_katello-3_8
katello-debug-3.8.0-5.el7.noarch from Katello_katello-3_8
katello-installer-base-3.8.0-1.el7.noarch from Katello_katello-3_8
tfm-rubygem-hammer_cli_katello-0.14.1-1.el7.noarch from Katello_katello-3_8
tfm-rubygem-katello-3.8.0-1.el7.noarch from Katello_katello-3_8
