Is there a guide to change the web UI certificate for Katello 3.13 with Foreman 1.23? I tried installing Katello with foreman-installer --scenario katello
then following this guide to switch out the certificates/key. However, Apache refuses to use anything other than the self-signed cert.
We need to move these docs into a more prominent location, for now you can find information about setting custom certificates here:
Thank you.
The documentation indicates a value for the certificate request file, is this a required parameter?
Seems like it didn’t need it, however, the installer errored out for some reason.
[root@katello ~]# katello-certs-check -c /etc/pki/tls/example/_example_io.crt -k /etc/pki/tls/example/_example_io.key -b /etc/pki/tls/example/chain.crt
Checking server certificate encoding:
[OK]
Checking expiration of certificate:
[OK]
Checking expiration of CA bundle:
[OK]
Checking if server certificate has CA:TRUE flag
[OK]
Checking to see if the private key matches the certificate:
[OK]
Checking CA bundle against the certificate file:
[OK]
Checking Subject Alt Name on certificate
[OK]
Checking Key Usage extension on certificate for Key Encipherment
[OK]
Validation succeeded
To install the Katello main server with the custom certificates, run:
foreman-installer --scenario katello \
--certs-server-cert "/etc/pki/tls/example/_example_io.crt" \
--certs-server-key "/etc/pki/tls/example/_example_io.key" \
--certs-server-ca-cert "/etc/pki/tls/example/chain.crt"
To update the certificates on a currently running Katello installation, run:
--certs-server-ca-cert "/etc/pki/tls/example/chain.crt" \
--certs-update-server --certs-update-server-ca
To use them inside a NEW $FOREMAN_PROXY, rerun this command with -t foreman-proxy
[root@katello ~]# foreman-installer --scenario katello --certs-server-cert /etc/pki/tls/example/_example_io.crt --certs-server-key /etc/pki/tls/example/_example_io.key --certs-server-ca-cert /etc/pki/tls/example/chain.crt
can't find a file that should have been created during an earlier step:
./ssl-build/KATELLO-TRUSTED-SSL-CERT
katello-ssl-tool --help
Generating web server's SSL key pair/set RPM:
./ssl-build/katello.dotslash.io/katello.dotslash.io-apache-1.0-1.src.rpm
./ssl-build/katello.dotslash.io/katello.dotslash.io-apache-1.0-1.noarch.rpm
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/execution.rb:297:in `execute'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/provider/command.rb:23:in `execute'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/provider.rb:222:in `block in has_command'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/provider.rb:444:in `block in create_class_and_instance_method'
/usr/share/foreman-installer/modules/certs/lib/puppet/provider/katello_ssl_tool.rb:40:in `block in katello_ssl_tool'
/usr/share/foreman-installer/modules/certs/lib/puppet/provider/katello_ssl_tool.rb:39:in `chdir'
/usr/share/foreman-installer/modules/certs/lib/puppet/provider/katello_ssl_tool.rb:39:in `katello_ssl_tool'
/usr/share/foreman-installer/modules/certs/lib/puppet/provider/cert/katello_ssl_tool.rb:42:in `generate!'
/usr/share/foreman-installer/modules/certs/lib/puppet/provider/katello_ssl_tool.rb:17:in `create'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property/ensure.rb:16:in `block in defaultvalues'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property.rb:490:in `set'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property.rb:570:in `sync'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:241:in `sync'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:136:in `sync_if_needed'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:82:in `perform_changes'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:21:in `evaluate'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:263:in `apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:283:in `eval_resource'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:187:in `call'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:187:in `block (2 levels) in evaluate'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:521:in `block in thinmark'
/opt/puppetlabs/puppet/lib/ruby/2.5.0/benchmark.rb:308:in `realtime'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:520:in `thinmark'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:187:in `block in evaluate'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/graph/relationship_graph.rb:122:in `traverse'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:174:in `evaluate'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/cataexample.rb:240:in `block (2 levels) in apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/cataexample.rb:239:in `block in apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/example.rb:161:in `with_destination'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/report.rb:146:in `as_exampleging_destination'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/cataexample.rb:238:in `apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:194:in `block (2 levels) in apply_cataexample'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:193:in `block in apply_cataexample'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:233:in `block in benchmark'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:232:in `benchmark'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:192:in `apply_cataexample'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:381:in `run_internal'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:242:in `block in run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/context.rb:62:in `override'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet.rb:274:in `override'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:219:in `run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:343:in `apply_cataexample'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:260:in `block (2 levels) in main'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:243:in `block in main'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:207:in `main'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:177:in `run_command'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:382:in `block in run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:687:in `exit_on_fail'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:382:in `run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:143:in `run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:77:in `execute'
/opt/puppetlabs/puppet/bin/puppet:5:in `<main>'
Preparing installation Done
Something went wrong! Check the example for ERROR-level output
The full example is at /var/example/foreman-installer/katello.example
You seem to have a hit bug that was fixed in katello-certs-tools but not released with Foreman 1.23. For now, try installing http://yum.theforeman.org/releases/nightly/el7/x86_64/katello-certs-tools-2.6.0-1.el7.noarch.rpm
More errors after installing the katello-certs-tools package you suggested.
[root@katello ~]# foreman-installer --scenario katello --certs-server-cert /etc/pki/tls/example/_example_io.crt --certs-server-key /etc/pki/tls/example/_example_io.key --certs-server-ca-cert /etc/pki/tls/example/chain.crt --foreman-initial-organization "example" --foreman-initial-location "datacenter"
Could not set 'present' on ensure: No such file or directory @ rb_sysopen - /etc/pki/katello/private/katello-apache.key (file: /usr/share/foreman-installer/modules/certs/manifests/keypair.pp, line: 18)
/usr/share/foreman-installer/modules/certs/lib/puppet/provider/katello_ssl_tool.rb:180:in `initialize'
/usr/share/foreman-installer/modules/certs/lib/puppet/provider/katello_ssl_tool.rb:180:in `open'
/usr/share/foreman-installer/modules/certs/lib/puppet/provider/katello_ssl_tool.rb:180:in `create'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:240:in `block (2 levels) in apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:239:in `block in apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/log.rb:161:in `with_destination'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/report.rb:146:in `as_logging_destination'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:238:in `apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:194:in `block (2 levels) in apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:193:in `block in apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:192:in `apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:343:in `apply_catalog'
Wrapped exception:
I tested this out myself and it seems you have hit a bug with custom certificates that is fixed in nightly but didn’t make it into 1.23/3.13. We’ll work to get this into a release of 1.23. In the meantime, try re-running the installer a second time and see if that causes it to correct itself (seems to have locally for me).
Good to know it’s not just me. With the new certs-tool package, re-running the installer still yielded errors. However, with the original package that came with the non-nightly repo worked from what I can tell.
