I've just opened the DO NOT MERGE PR to Katello (https://github.com/Katello/katello/pull/3550)
brings the recent work on Dynflow for handling orchestration and task management.
Most of the code there is the javascript, as the backend piece is part of https://github.com/iNecas/foreman-tasks
so that both Katello and Foreman can base the tasks management on the same code base,
avoiding having multiple sets of models/apis for dealing with the same thing.
Please give it a try, see the code and write comments. It's my first official angular work
(not the smallest piece to start with), so please lower your expectations
As the work blocks other tasks we have on the Katello, I would like to
find the smallest set of issues that need to get addressed before it
gets into master and address the rest there.
– Ivan
