dil
April 5, 2020, 2:37pm
1
**Problem:*When trying to connect to the hosted foreman http://foreman.domain.com web interface I get the error Web application could not be started attached/uploaded is the compressed html error message from trying to connect via the web browser. *
**Expected outcome:I should get a web login screen
Foreman and Proxy versions: 1.24.2
Foreman and Proxy plugin versions: 1.24.2 Katello: 3.14.1
**Distribution and version:*CentOS 7.7.1908 *
**Other relevant data:*
[web_app_could_not_be_started.tgz|attachment](upload://vjP7bjSpfzFaBJc5OYeGxAgjFt4.tgz) (41.5 KB)[
Looks like the file attachment didn’t work, can you paste the text of the error? also, where exactly does it fail? from the screenshot of the plugin list looks like the ui is working?
dil
April 5, 2020, 2:54pm
3
The screenshot is from a previous case as nothing has changed.
stack level too deep (SystemStackError)
/opt/rh/rh-ruby25/root/usr/local/share/gems/gems/fast_gettext-2.0.2/lib/fast_gettext/translation.rb:112:in `each_key'
/opt/rh/rh-ruby25/root/usr/local/share/gems/gems/fast_gettext-2.0.2/lib/fast_gettext/translation.rb:112:in `each_with_index'
/opt/rh/rh-ruby25/root/usr/local/share/gems/gems/fast_gettext-2.0.2/lib/fast_gettext/translation.rb:112:in `D_'
/usr/share/foreman/lib/foreman/gettext/all_domains.rb:6:in `_'
/opt/rh/rh-ruby25/root/usr/local/share/gems/gems/fast_gettext-2.0.2/lib/fast_gettext/translation.rb:105:in `block in d_'
/opt/rh/rh-ruby25/root/usr/local/share/gems/gems/fast_gettext-2.0.2/lib/fast_gettext.rb:22:in `with_domain'
/opt/rh/rh-ruby25/root/usr/local/share/gems/gems/fast_gettext-2.0.2/lib/fast_gettext/translation.rb:105:in `d_'
/opt/rh/rh-ruby25/root/usr/local/share/gems/gems/fast_gettext-2.0.2/lib/fast_gettext/translation.rb:114:in `block in D_'
/usr/share/foreman/app/models/nic/interface.rb:14:in `<class:Interface>'
/usr/share/foreman/app/models/nic/interface.rb:2:in `<module:Nic>'
/usr/share/foreman/app/models/nic/interface.rb:1:in `<top (required)>'
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:122:in `require'
/opt/theforeman/tfm/root/usr/share/gems/gems/polyglot-0.3.5/lib/polyglot.rb:65:in `require'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:287:in `block in require'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:253:in `load_dependency'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:287:in `require'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:374:in `block in require_or_load'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:37:in `block in load_interlock'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies/interlock.rb:14:in `block in loading'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/concurrency/share_lock.rb:151:in `exclusive'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies/interlock.rb:13:in `loading'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:37:in `load_interlock'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:352:in `require_or_load'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:506:in `load_missing_constant'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_hooks-0.3.16/lib/foreman_hooks/as_dependencies_hook.rb:4:in `load_missing_constant'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:193:in `const_missing'
/usr/share/foreman/app/models/nic/managed.rb:2:in `<module:Nic>'
/usr/share/foreman/app/models/nic/managed.rb:1:in `<top (required)>'
/usr/share/foreman/app/services/interface_type_mapper.rb:4:in `<class:InterfaceTypeMapper>'
/usr/share/foreman/app/services/interface_type_mapper.rb:1:in `<top (required)>'
/usr/share/foreman/config/initializers/apipie.rb:22:in `block in <top (required)>'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.14/lib/apipie/apipie_module.rb:38:in `configure'
/usr/share/foreman/config/initializers/apipie.rb:3:in `<top (required)>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:281:in `load'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:281:in `block in load'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/engine.rb:657:in `block in load_config_initializer'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/notifications.rb:170:in `instrument'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/engine.rb:656:in `load_config_initializer'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/engine.rb:614:in `block (2 levels) in <class:Engine>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/engine.rb:613:in `each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/engine.rb:613:in `block in <class:Engine>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:32:in `instance_exec'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:32:in `run'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:61:in `block in run_initializers'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:228:in `block in tsort_each'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:422:in `block (2 levels) in each_strongly_connected_component_from'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:431:in `each_strongly_connected_component_from'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:421:in `block in each_strongly_connected_component_from'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:50:in `each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:50:in `tsort_each_child'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:415:in `call'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:415:in `each_strongly_connected_component_from'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:349:in `block in each_strongly_connected_component'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:347:in `each'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:347:in `call'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:347:in `each_strongly_connected_component'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:226:in `tsort_each'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:205:in `tsort_each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:60:in `run_initializers'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/application.rb:361:in `initialize!'
/usr/share/foreman/config/environment.rb:5:in `<top (required)>'
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:59:in `require'
config.ru:5:in `block in <main>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/builder.rb:55:in `instance_eval'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/builder.rb:55:in `initialize'
config.ru:1:in `new'
config.ru:1:in `<main>'
/usr/share/passenger/helper-scripts/rack-preloader.rb:112:in `eval'
/usr/share/passenger/helper-scripts/rack-preloader.rb:112:in `preload_app'
/usr/share/passenger/helper-scripts/rack-preloader.rb:158:in `<module:App>'
/usr/share/passenger/helper-scripts/rack-preloader.rb:29:in `<module:PhusionPassenger>'
/usr/share/passenger/helper-scripts/rack-preloader.rb:28:in `<main>'
Error ID
ff318b0f
dil
April 5, 2020, 3:13pm
4
running foreman-rake apipie:cache --trace generates the same error.
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/application.rb:337:in `require_environment!'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/application.rb:520:in `block in run_tasks_blocks'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:251:in `block in execute'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:251:in `each'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:251:in `execute'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:195:in `block in invoke_with_call_chain'
/opt/rh/rh-ruby25/root/usr/share/ruby/monitor.rb:226:in `mon_synchronize'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:188:in `invoke_with_call_chain'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:217:in `block in invoke_prerequisites'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:215:in `each'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:215:in `invoke_prerequisites'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:194:in `block in invoke_with_call_chain'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:181:in `invoke'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:160:in `invoke_task'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:116:in `each'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:116:in `block in top_level'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:125:in `run_with_threads'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:110:in `top_level'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:83:in `block in run'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:186:in `standard_exception_handling'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:80:in `run'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/exe/rake:27:in `<top (required)>'
/opt/rh/rh-ruby25/root/usr/bin/rake:23:in `load'
/opt/rh/rh-ruby25/root/usr/bin/rake:23:in `<main>'
Tasks: TOP => apipie:cache => environment
This looks peculiar:
We ship version 1.4 of this gem in the foreman software collection. Is it possible this was somehow manually installed on the system?
dil
April 5, 2020, 5:15pm
6
odd not to knowledge I did install hammer_cli_csv and hammer_cli_katello the previous day but I removed them.
[foreman ~]# scl enable rh-ruby25 bash
[foreman ~]# gem list
*** LOCAL GEMS ***
apipie-bindings (0.3.0)
awesome_print (1.8.0)
bigdecimal (1.3.4)
bundler (1.16.1)
clamp (1.1.2)
cmath (default: 1.0.0)
csv (default: 1.0.0)
date (default: 1.0.0)
dbm (default: 1.0.0)
did_you_mean (1.2.0)
domain_name (0.5.20190701)
etc (default: 1.0.0)
fast_gettext (2.0.2)
fcntl (default: 1.0.0)
fiddle (default: 1.0.0)
fileutils (default: 1.0.2)
gdbm (default: 2.0.0)
hammer_cli (2.0.0)
hammer_cli_foreman (2.0.2)
hammer_cli_foreman_bootdisk (0.3.0)
hammer_cli_foreman_docker (0.0.4)
hammer_cli_foreman_tasks (0.0.14)
hashie (4.1.0)
highline (2.0.3)
http-accept (1.7.0)
http-cookie (1.0.3)
io-console (0.4.6)
ipaddr (default: 1.2.0)
json (2.3.0, 2.1.0)
jwt (2.2.1)
little-plugger (1.1.4)
locale (2.1.3)
logging (2.2.2)
mime-types (3.3.1)
mime-types-data (3.2019.1009)
minitest (5.10.3)
multi_json (1.14.1)
netrc (0.11.0)
oauth (0.5.4)
openssl (2.1.2)
powerbar (2.0.1)
psych (3.0.2)
rake (12.3.0)
rdoc (6.0.1)
rest-client (2.1.0)
scanf (default: 1.0.0)
sdbm (default: 1.0.0)
stringio (default: 0.0.1)
strscan (default: 1.0.0)
unf (0.1.4)
unf_ext (0.0.7.7)
unicode (0.4.4.4)
unicode-display_width (1.7.0)
webrick (default: 1.4.2)
zlib (default: 1.0.0)
[foreman ~]# rpm -qa | grep fast_gettex
tfm-rubygem-fast_gettext-1.4.1-3.el7.noarch
dil
April 5, 2020, 5:17pm
7
gem uninstall fast_gettext
You have requested to uninstall the gem:
fast_gettext-2.0.2
hammer_cli-2.0.0 depends on fast_gettext (>= 0)
If you remove this gem, these dependencies will not be met.
Hmm, looks like you installed hammer inside the rh-ruby25 scl. Additionally, hammer 2.0 is not compatible with Foreman 1.24, you should use hammer 0.19. How did you install it? there are packages for hammer in the foreman repositories that handle all of the requirements for you.
dil
April 5, 2020, 6:46pm
9
Thanks, I removed all the hammer gems under scl rh-ruby25.
