I am trying to install Katello on a Cent 7 server. I had foreman on that server before, but I uninstalled it and installing fresh with Katello.
below the error I am getting :
“”""/root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/data_type.rb:31:in `register_type’: Data type Apt::Auth_conf_entry is already registered, cannot be re-registered (ArgumentError)""""
Full Trace:
foreman-installer --scenario katello
18: from /sbin/foreman-installer:8:in `<main>'
17: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/kafo_configure.rb:163:in `run'
16: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/clamp-1.3.0/lib/clamp/command.rb:140:in `run'
15: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/clamp-1.3.0/lib/clamp/command.rb:140:in `new'
14: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/kafo_configure.rb:100:in `initialize'
13: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/kafo_configure.rb:289:in `set_parameters'
12: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/scenario_manager.rb:208:in `load_and_setup_configuration'
11: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/configuration.rb:224:in `preset_defaults_from_puppet'
10: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/configuration.rb:214:in `params'
9: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/configuration.rb:95:in `modules'
8: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/configuration.rb:348:in `register_data_types'
7: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/configuration.rb:348:in `each'
6: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/configuration.rb:349:in `block in register_data_types'
5: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/configuration.rb:349:in `each'
4: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/configuration.rb:350:in `block (2 levels) in register_data_types'
3: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/data_type_parser.rb:20:in `register'
2: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/data_type_parser.rb:20:in `each'
1: from /root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/data_type_parser.rb:22:in `block in register'
/root/.rbenv/versions/2.5.1/lib/ruby/gems/2.5.0/gems/kafo-3.0.0/lib/kafo/data_type.rb:31:in `register_type': Data type Apt::Auth_conf_entry is already registered, cannot be re-registered (ArgumentError)
Any help to resolve is much appreciated. thank You
